node-red-contrib-sm-16relind 1.0.0
A Node-RED node to control Sequent Microsystems 16-Relays board
This is the node-red node to control Sequent Microsystems 16-RELAYS Stackable Card for Raspberry Pi.
Manual Install
Clone or update the repository, follow the instructions from the first page.
In your node-red user directory, tipicaly ~/.node-red,
~$ cd ~/.node-red
Run the following command:
~/.node-red$ npm install ~/16relind-rpi/node-red-contrib-sm-16relind
In order to see the node in the palette and use-it you need to restart node-red. If you run node-red as a service:
~$ node-red-stop
~& node-red-start
After install and restart the node-red you will see on the node palete, under Sequent Microsystems category the "8relind" and "8relindrd" nodes.
16relind node
This node will turn on or off a relay or all relays as a 16 bits bitmap. The card stack level and relay number can be set in the dialog screen or dinamicaly thru msg.stack and msg.relay. The output of one relay or all 16 relays if you set the the relay number to 0, can be set dynamically using msg.payload.
16relindrd node
Thi node will read one relay state or all relays states as a 16 bits bitmap. The card stack level and relay number can be set in the dialog screen or dinamicaly thru msg.stack and msg.relay and the state is output as msg.payload .If you set the relay number to 0 the node will output the state of all relays.
Important note
This node is using the I2C-bus package from @fivdi, you can visit his work on github here. The inspiration for this node came from @nielsnl68 work with node-red-contrib-i2c.We thank them for the great job.
