node-red-contrib-sm-16inputs 1.0.2
A Node-RED node to control Sequent Microsystems 16Inputs board
npm install node-red-contrib-sm-16inputs
This is the node-red node to control Sequent Microsystems 16-INPUTS Stackable Card for Raspberry Pi.
Manual Install
Clone or update the repository, follow the instructions fron the first page.
In your node-red user directory, tipicaly ~/.node-red,
~$ cd ~/.node-red
Run the following command:
~/.node-red$ npm install ~/16inputs-rpi/node-red-contrib-sm-16inputs
In order to see the node in the palette and use-it you need to restart node-red. If you run node-red as a service:
~$ node-red-stop
~$ node-red-start
After install and restart the node-red you will see on the node palete, under Sequent Microsystems category the "16inputs" node.This node will return the state of one of 16 inputs. The card stack level and channel number can be set in the dialog screen or dinamicaly thru msg.stack and msg.channel.
Important note
This node is using the I2C-bus package from @fivdi, you can visit his work on github here. The inspiration for this node came from @nielsnl68 work with node-red-contrib-i2c.Thank both for the great job.
Version: 1.0.2
Updated 5 years ago
2 in the last week
  • 16inputs
  • node-red-contrib
  • i2c
  • opto
  • digital
