node-red-contrib-sleep-timer 1.0.2
A timer that works like a TV sleep timer.
npm install node-red-contrib-sleep-timer
This node implements the behaviour (logic) of a TV sleep timer, it it designed to be used with nodes that provide communications to TV's.
The project homepage is https://github.com/fizzyade/node-red-contrib-sleep-timer
  • Easy to use, specicifically designed to operate as a TV sleep timer and requires no extra logic to be added which would be required when using a generic timer module.
  • Provides methods for starting, stopping, querying, incrementing and decrementing the timer.
  • Has 3 outputs to enable easy interfacing
    • Control - the control output provides state change messages.
    • Tick - the tick output provides information as the timer counts down.
    • Set - the set output provides information when the timer duration is set.
Behaviour
The logic on the sleep timer is as follows:
  • When a start message is received the timer will be set to either the default or payload timeout period (if supplied).
    Notes:
    The timer will NOT be set if the current value is greater than the requested timeout.
    If the timer is set, then the Control output will send a message with the payload started. If the timer is already running, then this message will not be output.
    A message containing the new timeout value will be output on the Set output.
  • When a stop message is received the timer will be stopped.
    Notes:
    If the timer is running then a stopped message will be sent on the control output, if the timer is not running then no message will be output.
  • When a increment message is received the timer will be incremented by either the default adjustment or payload timeout period (if supplied).
    Notes:
    If the timer is running then the current timeout will be adjusted by the provided period.
    If the timer is not running, then the timer will be started and set to the adjustment period, a started message will be output on the Control output.
  • When a decrement message is received the timer will be decremented by either the default adjustment or payload timeout period (if supplied).
    Notes:
    If the timer is not running then nothing will happen.
    If the timer is running and the current timeout value is less than the adjustment period, then the timer is stopped and a stopped message is output on the Control output. Otherwise the the timer will be decremented by the given amount.
    A message containing the new timeout value will be output on the Set output providing the timer was not stopped by the decrement command.
  • When a remaining message is received, the timer will output the current timeout value
The node provides default settings for:
  • Default Period - the default time (in minutes) that the sleep timer will run for when no value is provided in the control payload.
  • Default Adjustment - the default adjustment time (in minutes) that the sleep timer will be adjustmed by when no value is provided in the control payload.
This project is open source and is released under the MIT License
Distributed as-is; no warranty is given.
Version: 1.0.2
Updated 7 years, 1 month ago
11 in the last week
  • sleep-timer
