node-red-contrib-slack-socketmode 1.0.1
Real-time integration between Slack and Node-RED using Bolt with Socket Mode.
npm install node-red-contrib-slack-socketmode
A Node-RED node that enables real-time bi-directional communication with Slack using the Slack RTM API (Socket Mode).
This node allows you to:
  • Receive messages from any Slack channel, DM or app mention.
  • Send messages from Node-RED to Slack using the same authenticated connection.
  • Run a persistent background Slack RTM client that automatically reconnects.
  • Avoid the need for external tunnels (like ngrok), as Slack Socket Mode requires no public URL.
This package is useful when building:
  • ChatOps automations
  • Monitoring or alerting pipelines
  • IoT β†’ Slack integrations
  • Slack assistants connected to industrial SCADA/PLC systems
  • Internal automation bots without requiring slash commands or HTTP endpoints
πŸ”§ Installation
Using npm
🧩 Node Description
This package provides two main components:
  1. Slack RTM Listener Node
Creates a persistent connection to Slack using your SLACK_APP_TOKEN and receives all Slack messages allowed by your app permissions.
Outputs a msg object like:
{ "type": "slack_event", "event": "message", "user": "U1234567", "text": "hello world", "channel": "C9876543", "ts": "1731530820.239629" }
  1. Slack RTM Sender Node
Allows you to send Slack messages using:
msg.payload = { channel: "CHANNEL_ID", text: "Your message text" };
βš™οΈ Slack Configuration (Required)
Follow these steps to configure Slack:
  1. Create a Slack App
https://api.slack.com/apps
  1. Enable Socket Mode
Slack App β†’ Settings β†’ Socket Mode β†’ Enable
  1. Add Required OAuth Scopes
Bot Token Scopes:
app_mentions:read
channels:history
chat:write
groups:history
im:history
mpim:history
  1. Install the App into Your Workspace
Slack App β†’ Install App β†’ Install
  1. Retrieve Tokens
You will need:
Token Type Purpose SLACK_APP_TOKEN (starts with xapp-) Required for RTM (Socket Mode) SLACK_BOT_TOKEN (starts with xoxb-) Required for sending messages
Insert these tokens in the node configuration inside Node-RED.
πŸš€ Usage Examples
  1. Receiving messages
Connect the Slack RTM Listener node to a debug node.
No payload is required; socket mode starts automatically.
Output example:
{ "type": "slack_event", "event": "message", "user": "U13579", "text": "Temperature is too high!", "channel": "C24680" }
  1. Sending messages from Node-RED
Inject:
{ "channel": "C24680", "text": "Hello from Node-RED!" }
Function node "Format message":
msg.payload = { channel: "C24680", text: "Hello from Node-RED!" }; return msg;
Connect it to Slack RTM Sender.
πŸ”„ Auto-Reconnect Feature
The Slack RTM connection automatically:
Reconnects on network failures
Resumes after computer sleep
Handles Slack server restarts
No user intervention is required.
πŸ›  Advanced Use Cases Trigger flows on keyword if (msg.text.includes("status")) { msg.payload = "System OK"; return msg; } return null;
Forward alerts to Slack
Use MQTT β†’ Function β†’ Slack RTM Sender.
Control Node-RED flows from Slack
Use the Listener node + Switch node.
πŸ§ͺ Testing
You can verify your Slack tokens by running:
node slack-socket.js
You should see:
Slack Bolt connected in Socket Mode…
Version: 1.0.1
Updated 1 year ago
  • slack-socket
  • slack
  • slack-bot
  • slack-rtm
  • socket-mode
  • chatops
