node-red-contrib-slack-socket 0.1.0
A Node-RED node to interact with the Slack Socket Mode.
npm install node-red-contrib-slack-socket
Requirements
Run the command in the root directory of Node-RED
npm install --save node-red-contrib-slack-socket
Slack Listen node
The Slack Listen node listens Slack events.
Note: Slack Socket Mode accepts "Events API" events.
Example output:
    "payload": {
        "client_msg_id": "...",
        "type": "app_mention",
        "text": "...",
        "user": "...",
        "ts": "1611812562.007700",
        "team": "...",
        "blocks": [
                "type":" rich_text",
                "block_id": "...",
                "elements": [
                        "type": "rich_text_section",
                        "elements": [
                            {"type": "user", "user_id": "..."},
                            {"type": "text", "text": "..."}
        "thread_ts": "1611123575.001100",
        "parent_user_id": "...",
        "channel":"...",
        "event_ts":"1611812562.007700"
Developers
dev-Requirements
  • Node v12 LTS and higher
  • Docker 20.10 and higher
  • docker-compose 1.27 and higher
Setup
  1. Create test/mocha.env.js file
    process.env.SLACK_APP_TOKEN = 'xapp-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX';
  2. Create .env file
    SLACK_APP_TOKEN=xapp-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
Test
  1. Edit test/*_spec.js test files
  2. Execute npm command
    $ npm run test
Run on Node-RED
  1. Build Docker container image
    $ docker-compose build
  2. Run container
    $ docker-compose up -d
  3. Stop container
    $ docker-compose stop
Version: 0.1.0
Updated 5 years, 8 months ago
3 in the last week
  • slack-controller
  • slack-listen
  • slack
  • socket-mode
