node-red-contrib-simplepush 3.0.0
Simplepush tasks, notifications and submissions for Node-RED
npm install node-red-contrib-simplepush
Simplepush nodes for Node-RED.
Send tasks and notifications to Android and iOS, optionally end-to-end encrypted, and get the answers back into your flow: button taps, text, choices, slider values, photos, voice recordings, files and locations. Receive what people send from the app on their own.
npm
Requires Node.js 20 or newer and Node-RED 3 or newer.
Node What it does
simplepush task Sends a task and outputs every answer.
simplepush notification Sends a push with at most one answer, an image or audio clip, or a link.
simplepush in Outputs every submission people send from the app.
Simplepush account Config node with the credentials, shared by all nodes. One connection per account.
Account
  • Personal: API token from the app (Settings > API Token). Optional Personal Password, which encrypts sends to your own devices and decrypts your submissions. Optional topic passwords: a send to a listed topic is encrypted with its password.
  • Organization: integration token, created by an organization admin with sp integration create. Encryption uses the organization's keys, which come with the token.
Topics are created and subscribed to in the app. Leave the topic blank to send to your own devices. An organization send needs exactly one of topic, member or broadcast.
simplepush task
Inputs are set in the node or passed as msg.inputs, in the shape of the TypeScript SDK:
msg.inputs = [
    { type: "actions", actions: ["Approve", "Deny"] },
    { type: "text", description: "Comment", required: false },
    { type: "choice", options: ["Red", "Green", "Blue"], multi: true, maxSelections: 2 },
    { type: "slider", min: 0, max: 14, step: 0.1, unit: "pH" },
    { type: "photo" }, { type: "voiceRecording" }, { type: "file" }, { type: "location" }
required defaults to true. Each type at most once.
Message properties, used when the node's field is blank:
Property
msg.payload The message. Objects are sent as JSON.
msg.topic, msg.member, msg.broadcast The target. member and broadcast are for organizations.
msg.title, msg.tag Title and a label to group or filter by.
msg.priority 1 (silent) to 5 (critical, sounds on a muted phone). Default 3.
msg.expiresIn Seconds until an unanswered task expires.
msg.shared true: one task for all recipients, the first answer completes it. Default: one task per recipient.
msg.markdown true renders the message as Markdown.
msg.links Array of URLs shown with the task.
msg.attachments Array of files: URLs to download, or {filename, data, contentType} with data a Buffer.
msg.autoCommit true (default) saves each input as it is filled, false shows a Submit button.
A boolean on the message wins over the node's checkbox.
Outputs: one message per answer. With actions in the node there is one output per action, otherwise the first output. After those, one output each for tasks that ended without an answer: declined, canceled (withdrawn by the sender), expired. A task that everyone deleted from their list ends without a message.
Property
msg.payload The answer: action, text, choice, choices, slider, location, and photo, voice, file as {data, filename, contentType, size} with data a Buffer. On the outputs for tasks without an answer, the status.
msg.status completed, declined, canceled or expired.
msg.taskId, msg.groupId The task, and the group of tasks when every recipient got their own.
msg.recipient Who answered: publicId, name.
msg.completedAt When the task was completed.
msg.declines On a declined task: who declined, in order, as {recipient, reason, note}. One entry per task sent to one recipient; everyone on a shared task.
msg.note The note left when declining, when one person declined.
A push that does not stay in the app's task list. One answer at most: action buttons or a choice (up to 3 each), or text. Set in the node or as msg.input:
msg.input = { type: "actions", actions: ["Open", "Ignore"] };
msg.image or msg.audio is a URL or {filename, data, contentType}. msg.link adds an Open link button (any scheme, so an app link opens that app); not together with an answer.
A notification does not expire. Answers leave through the first output (msg.status completed). With a timeout, recipients who did not answer in time leave through the second output with msg.status pending. Without one the node waits until everyone answered or the flow is redeployed.
simplepush in
One message per submission: msg.payload has text, location, and photo, file, audio with data a Buffer. msg.sender, msg.submissionId, msg.submittedAt.
Upgrading from 1.x
Flows from 1.x keep working once the node has an account:
  • The old key becomes the topic. The app migration imports every old key as a topic of the same name.
  • event becomes tag, the timeout becomes Expires in, the actions become an actions input with one output per action.
  • salt is gone. Set a password for the topic in the app and add the topic and password to the account. A password saved on a 1.x node keeps working until then.
  • msg.payload of an answer is an object: the tapped action is msg.payload.action.
  • Unanswered tasks leave through their own outputs (declined, canceled, expired) after the action outputs instead of raising an error.
  • msg.key and msg.password raise an error, use msg.topic and the account. msg.salt is ignored.
See simplepu.sh for more details.
Version: 3.0.0
Updated 1 month, 2 weeks ago
Rating: 1.0 1
39 in the last week
  • simplepush-account
  • simplepush
  • simplepush-notification
  • simplepush-in
  • simplepush
  • push notification
  • actionable notification
  • human in the loop
  • approval
  • tasks
  • encrypted
