node-red-contrib-simple-array-key-value 0.0.5
A Node-RED node to dynamically add key-value pairs to arrays in msg.payload with an improved UI.
npm install node-red-contrib-simple-array-key-value
Title: Node-RED Contrib Simple Array Key and Value
Description: Simple Array Key and Value is a custom Node-RED node that allows you to dynamically add key-value pairs to an existing array in msg.payload. This node is ideal for building data structures flexibly during flow processing.
Features:
  • Dynamically Add Items: Add key-value pairs to the array in msg.payload configured directly via the node’s interface.
  • Field Validation: Ensures that all required fields (key and value) are correctly filled before processing.
  • Array Management: Initializes arrays in msg.payload if they do not exist, preventing errors during the flow.
Installation: To install this node, you can use NPM directly in your Node-RED directory: Command: npm install node-red-contrib-simple-array-key-value Or, to install globally: Command: npm install -g node-red-contrib-simple-array-key-value
How to Use:
  1. Drag the "Simple Array Key and Value" node into your Node-RED flow.
  2. Configure the key-value pairs you want to add to the array in msg.payload.
  3. Connect the node to your flows to start dynamically adding data.
Inputs:
  • msg.payload: An array where the configured key-value pairs will be added. If it's not an array, the node will initialize it as an empty array.
Outputs:
  • msg.payload: Returns the array with the key-value pairs added as configured.
Example Flow:
    "id": "d6562f38c09bfba5",
    "type": "inject",
    "z": "a790480fed0e10dd",
    "props": [{
        "p": "payload"
        "p": "topic",
        "vt": "str"
    "repeat": "",
    "crontab": "",
    "once": false,
    "onceDelay": 0.1,
    "topic": "",
    "payload": "",
    "payloadType": "date",
    "x": 300,
    "y": 140,
        "122509cc57501a0f"
    "id": "bd34406756bcaa01",
    "type": "debug",
    "name": "debug 25",
    "active": true,
    "tosidebar": true,
    "console": false,
    "tostatus": false,
    "complete": "true",
    "targetType": "full",
    "statusVal": "",
    "statusType": "auto",
    "x": 780,
    "y": 140,
    "id": "122509cc57501a0f",
    "type": "simple-array-key-value",
    "items": [{
        "key": "asd",
        "value": "asd"
        "key": "asd",
        "value": "asd"
        "key": "asd",
        "value": "asd"
        "key": "asd",
        "value": "asd"
        "key": "asd",
        "value": "asd"
        "key": "asd",
        "value": "asd"
    "x": 560,
    "y": 140,
        "bd34406756bcaa01"
Contribution: Feel free to contribute to this project. To get started:
  1. Fork the repository.
  2. Create a new branch for your changes (git checkout -b my-new-feature).
  3. Commit your changes (git commit -m 'Added a new feature').
  4. Push to the branch (git push origin my-new-feature).
  5. Open a Pull Request.
License: Distributed under the ISC license. See LICENSE for more information.
Contact: Lucas Santos - [email protected]
Project Link: https://github.com/lucassantossouza/node-red-contrib-simple-array-key-value
Version: 0.0.5
Updated 2 years, 1 month ago
Rating: 5.0 2
3 in the last week
  • simple-array-key-value
  • node-red-node
  • array
  • key-value
  • dynamic
  • custom-node
