node-red-contrib-signal-interval 0.0.3
Node-RED node to aggregate pairs of signals into intervals
The purpose of this node is to identify pairs of signals/payloads and return the time distance (interval) between them.
A pair of signals consists of an on signal followed by an off signal. Upon arrival of the off signal, the node will emit a payload which includes information about the duration of the on period which is defined as the interval between the signals.
Example:
Input: on--off-----on------------off---
Output: interval: 0.2 s interval: 1.2 s
Payload format
Input
The expected input for the node takes the form
cmd: 'on' | 'off'
i.e. the on/off value is expected on the cmd
property by default; a different property name can be specified on the node configuration if needed (only top-level properties supported, no nesting).
Output
The output format looks like
type:"actual" | "dummy",
duration:0.618
with the duration in seconds and the type explained below.
Noise
Generally transmissions can be noisy and signals can be blocked along the way. In our case, the effect of this would be that one (or multiple) signals are dropped and don't reach the node. If we miss out on an entire pair of signals (i.e. the on and the off signals are dropped) there is nothing we can do. If, however, the environment is not too noisy we can assume most of the signals coming through and we only have to compensate for a missing on or off signal every now and then. We can detect this situation by two consecutive on or two consecutive off signals. In this case, we know that we have missed a signal but don't know when, so we just assume a default interval duration. This is indicated by type: "dummy"
with the default/dummy duration being configurable in the node configuration (also check the tests in spec.js
for some examples).
