node-red-contrib-siemens-sentron 0.0.41
Node-RED nodes to read electrical measures from Siemens SENTRON series over Modbus TCP/IP
npm install node-red-contrib-siemens-sentron
Node-RED nodes to read electrical measures from Siemens SENTRON series over Modbus TCP/IP.
Table of Contents
You can install these nodes directly from the Manage Palette menu in the Node-RED interface.
Alternatively, run the following command in your Node-RED user directory - typically ~/.node-red on Linux or %HOMEPATH%\.nodered on Windows
You must also install node-red-contrib-modbus directly from the Manage Palette menu in the Node-RED interface or run the following command in your Node-RED user directory
    npm install node-red-contrib-modbus
How to use
measure node
Use the measure node to configure which information you want to request from the device.
Wire the output of the measure to the input of the Modbus Flex Getter from 'node-red-contrib-modbus' modules.
Enable check box Keep Msg Properties in the Modbus Flex Getter properties.
getter node
Use the getter node to convert the values from the modbus response into human readable numbers.
Wire the second output of the Modbus Flex Getter to the input of the getter.
Supported devices
Measuring devices
  • PAC1200
  • PAC1600
  • PAC2200
  • PAC3100
  • PAC3120
  • PAC3200
  • PAC3220
  • PAC3200T
  • PAC4200
  • PAC5200
  • SEM3
Transfer controller
  • ATC6300
Molded case circuit breakers
  • 3VA
Dataserver
  • 7KN Powercenter 1000
RF devices
  • 5SL6 COM
  • 5SV6 COM
  • 5ST3 COM
  • 3NA COM
Example flow
[{"id":"ac42dc3cfc737a41","type":"tab","label":"Siemens SENTRON","disabled":false,"info":"","env":[]},{"id":"ba83206eb52d59f2","type":"inject","z":"ac42dc3cfc737a41","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"10","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":190,"y":180,"wires":[["9edbc9242d918b94","209122aaf081e90d"]]},{"id":"9edbc9242d918b94","type":"measure","z":"ac42dc3cfc737a41","name":"","unitId":"1","device":"pac2200","deviceProtection":"5st3com","data":"voltageLL-avg","x":400,"y":140,"wires":[["0a2ba7e6c1721f97"]]},{"id":"56cf05bc9733a65f","type":"getter","z":"ac42dc3cfc737a41","name":"","unitId":"","data":"","x":790,"y":140,"wires":[["be3da888d87fa30f"]]},{"id":"0a2ba7e6c1721f97","type":"modbus-flex-getter","z":"ac42dc3cfc737a41","name":"","showStatusActivities":false,"showErrors":false,"logIOActivities":false,"server":"50fc5c2a64d40a1e","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":false,"keepMsgProperties":true,"x":590,"y":140,"wires":[[],["56cf05bc9733a65f"]]},{"id":"be3da888d87fa30f","type":"debug","z":"ac42dc3cfc737a41","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":950,"y":140,"wires":[]},{"id":"209122aaf081e90d","type":"measure","z":"ac42dc3cfc737a41","name":"","unitId":"1","device":"pac2200","deviceProtection":"5st3com","data":"current-avg","x":400,"y":220,"wires":[["e1621552b6017614"]]},{"id":"b1dcc45732697c41","type":"getter","z":"ac42dc3cfc737a41","name":"","unitId":"","data":"","x":790,"y":220,"wires":[["3ece6051729284e5"]]},{"id":"e1621552b6017614","type":"modbus-flex-getter","z":"ac42dc3cfc737a41","name":"","showStatusActivities":false,"showErrors":false,"logIOActivities":false,"server":"50fc5c2a64d40a1e","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":false,"keepMsgProperties":true,"x":590,"y":220,"wires":[[],["b1dcc45732697c41"]]},{"id":"3ece6051729284e5","type":"debug","z":"ac42dc3cfc737a41","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":950,"y":220,"wires":[]},{"id":"358e4fca54d8b667","type":"comment","z":"ac42dc3cfc737a41","name":"PAC2200","info":"","x":400,"y":100,"wires":[]},{"id":"50fc5c2a64d40a1e","type":"modbus-client","name":"","clienttype":"tcp","bufferCommands":true,"stateLogEnabled":false,"queueLogEnabled":false,"tcpHost":"192.168.1.113","tcpPort":"502","tcpType":"DEFAULT","serialPort":"/dev/ttyUSB","serialType":"RTU-BUFFERD","serialBaudrate":"9600","serialDatabits":"8","serialStopbits":"1","serialParity":"none","serialConnectionDelay":"100","serialAsciiResponseStartDelimiter":"0x3A","unit_id":"1","commandDelay":"1","clientTimeout":"1000","reconnectOnTimeout":true,"reconnectTimeout":"2000","parallelUnitIdsAllowed":true}]
Device type
device-config
Meter data
data-config
Circuit protection device
circuit-protection-device
Circuit protection data
Message object
message-format
Sample flow
sample-flow
Application examples
SENTRON 7KN Powercenter 1000 push messages with Node-RED
Meters data
List of PAC2200 meter data:
Measure Units Type
Voltage L1-N V Float 32
Voltage L2-N V Float 32
Voltage L3-N V Float 32
Voltage L1-L2 V Float 32
Voltage L2-L3 V Float 32
Voltage L3-L1 V Float 32
Current L1 A Float 32
Current L2 A Float 32
Current L3 A Float 32
Apparent power L1 VA Float 32
Apparent power L2 VA Float 32
Apparent power L3 VA Float 32
Active power L1 W Float 32
Active power L2 W Float 32
Active power L3 W Float 32
Reactive power L1 var Float 32
Reactive power L2 var Float 32
Reactive power L3 var Float 32
Power factor L1 - Float 32
Power factor L2 - Float 32
Power factor L3 - Float 32
Frequency Hz Float 32
Average voltage L-N V Float 32
Average voltage L-L V Float 32
Average current A Float 32
Total apparent power VA Float 32
Total active power W Float 32
Total reactive power var Float 32
Total power factor - Float 32
Neutral current A Float 32
Active energy import Wh Float 32
Reactive energy import varh Float 32
Active energy export Wh Float 32
Reactive energy export varh Float 32
Active energy import tariff 1 kWh Double
Active energy import tariff 2 kWh Double
Active energy export tariff 1 kWh Double
Active energy export tariff 2 kWh Double
Reactive energy import tariff 1 kvarh Double
Reactive energy import tariff 2 kvarh Double
Reactive energy export tariff 1 kvarh Double
Reactive energy export tariff 2 kvarh Double
Apparent energy tariff 1 kVAh Double
Apparent energy tariff 2 kVAh Double
List of 7KN Powercenter 1000 meter data:
Measure Units Type
Current temperature °C Float 32
Average temperature °C Float 32
Actual current L A Float 32
Average current L A Float 32
Maximum current L A Float 32
L-N voltage V Float 32
Line frequency Hz Float 32
Active power L W Float 32
Apparent power L VA Float 32
Reactive power L var Float 32
Power factor L - Float 32
Imported active energy kWh Float 64
Exported actie energy kWh Float 64
Imported reactive energy kvarh Float 64
Exported reactive energy kvarh Float 64
Protection device status - Unsigned int 16
Alarms status - Unsigned int 32
Mechanical operating cycles - Float 32
Tripping operations - Float 32
Short-circuit trips - Float 32
Set unit IDs (1 .. 24) for paired circuit protection devices.
Equipment compatibility
Compare the values obtained with the measures on the installed device and report any bugs such as:
  • measured value error
  • measured value format
  • unit of measure
These modules have been developed and tested on:
  • SENTRON PAC2200
  • 7KN Powercenter 1000 with 5SL6 COM
Version: 0.0.41
Rating: 5.0 5
12 in the last week
  • measure
  • getter
  • siemens
  • sentron
  • energymonitoring
