node-red-contrib-sht31 0.0.1
Node for SHT31 sensors for SBCs gpios
npm install node-red-contrib-sht31
A node-red custom node wrapper for the nodejs sht31-sensor by @belveder79 . This library uses the outstanding package i2c-bus that enable the communication with I2C devices in most common Linux SBCs. Raspberry Pi, C.H.I.P., BeagleBone, Orange Pi, or Intel Edison are supported by this package.
The package provide a single custom node Sht31 that can be used directly in your flow.
Under your node-red (typically $HOME/.node-red) working directory.
Node palette can be used as well to install the node.
After restarting node-red the "Sht31" node should be available in "input" category.
Prerequisites
Wire your sensor the I2C/TWI of the SBCs. Only four wires are needed. two for power (VCC 3.3V & GND) and two for actual I2C transmission (SLC & SDA).
I2C interface need to be enabled in in your linux distribution.
Caveat: Check your permissions to the /dev/i2c-xx devices. The user running node-red need access to writing and reading. Refer to i2c-bus to find how to grant access to your user to the /dev/i2c-xx device files
Configuration & deployment
After installation place your Sht31 node in any of your flow and configure the following parameters:
  1. Name: Select the name of your sensor for easy identification.
  2. Bus ID: Select the I2C bus to which the sensor is connected. Depending on your wiring and SBC can be different.
  3. I2C address: I2C address (7-bit) hexdecimal address(0x##). SHT31 sensor has fixed 0x44 or 0x45. You can check your sensor id by using i2c-tools typing i2cdetect -y <busnum>
  4. Topic: Topic field set on the output message. If this field is empty, topic will not be included in the output msg. By configuring the node this way input msg topic will be reused.
After configuration and deployment the node will init the sensor. A word of warning! Since the SHT31 does not expose anything like product id at this point in time, the init function does nothing but returning a fake ID. So you don't really know if the sensor is actually there or not. If it gives you no answer, it might not be there, although it shows up as "initialized".
Reading Sensor Data
As in other node-red nodes the actual measurement of sensor data require that an input msg arrive to the node. The input called Trigger will start the reading of sensor data will send the data in the node's output. The input msg is reused so any property on the input msg (with the exception of payload and topic if set) will be redirected without modification to the output.
The output will have the following format:
msg = {
  _msgid: <node-red msg_id>,
  topic: <defined topic>,
  payload: {
    model: "SHT31",
    temperature_C: <float in celsius>,
    humidity: <float in %>
Disclaimer
A lot of code snippets, inspiration and even this README was largely taken from the BME280 contrib module implementation from @ludiazv (actually almost everything). The node was only tested on a RockPro64 board and a custom SHT31 sensor implementation from AR4 GmbH.
Change log
  • 0.0.1 First version
Version: 0.0.1
Updated 6 years, 1 month ago
14 in the last week
  • Sht31
  • rpi
  • raspberry
  • Beaglebone
  • orangepi
  • BBB
  • Edison
  • sensor
  • sensors
  • temperature
  • humidity
