node-red-contrib-sht 1.0.1
Node-RED node for reading measurements from Sensirion SHT3x humidity and temperature sensors
npm install node-red-contrib-sht
This node for Node-RED provides easy access to read temperature and humidity values from the Sensirion SHT31 or SHT35 sensors.
Requirements
  • Raspberry Pi
  • I2C must be enabled
  • Sensirion SHT31 or SHT35 sensor
  • Node.js v7.6 or newer
  • sht31-node from Thomas Bouvier
Prereqeuisites
# Run this in your favourite terminal
npm install sht31-node
Highly recommended: Run the Node-Red specific bash script for the Raspberry Pi followed by
npm rebuild
npm update
Installation of node-red-contrib-sht
Just install this module in your node-RED configuration folder
Or globally:
npm install -g node-red-contrib-sht
You will find this node in the i2c bus section of the palette panel or just filter the nodes for "sht".
The msg.payload of the outgoing object will be a object with the key names temperature and humidity and the values, e.g. { "temperature" : 21.9, "humidity" : 37,5 }. Temperature value unit is in °C, humidity in %RH.
The queried I2C address of 0x44 is changable.
Demo Image
Contributing
  1. Fork it
  2. Create your feature branch: git checkout -b my-new-feature
  3. Commit your changes: git commit -am 'Add new feature'
  4. Push to the branch: git push origin my-new-feature
  5. Submit a pull request
Credits
This is just a very basic and simple Node-RED wrapper for Thomas Bouviers excelent sht31-node Node.js library. He deserves all credits.
MIT
Version: 1.0.1
Updated 6 years ago
10 in the last week
  • SHT3x
  • sht
  • sht31
  • sht35
  • sht3x
  • sensirion
  • temperature
  • humidity
  • sensor
