node-red-contrib-shelly 11.12.3
Shelly nodes.
npm install node-red-contrib-shelly
Shelly nodes for node-red
Platform License NPM Known Vulnerabilities Downloads Total Downloads Package Quality Build Open Issues Closed Issues ...
This package contains nodes for controlling shelly devices via the following API: https://shelly-api-docs.shelly.cloud/
Dependencies
This package depends on the following libraries
Supported Devices
The following table lists all Shelly devices that are supported by this package. Devices marked as "true" have been tested and confirmed to work. Devices marked as "not tested" should work but have not been verified yet.
Generation 1 Devices
Device Name Model Type
Shelly 1 SHSW-1 Relay
Shelly 1PM SHSW-PM Relay
Shelly 1L Relay SHSW-L Relay
Shelly 1L Roller SHSW-L Roller
Shelly 2 Relay SHSW-21 Relay
Shelly 2 Roller SHSW-21 Relay
Shelly 2.5 Relay SHSW-25 Relay
Shelly 2.5 Roller SHSW-25 Roller
Shelly I3 SHIX3-1 Button
Shelly EM SHEM Measure
Shelly 3EM SHEM-3 Measure
Shelly UNI SHUNI-1 Relay
Shelly TRV SHTRV-01 Thermostat
Shelly Button 1 SHBTN-1 Button
Shelly Button 2 SHBTN-2 Button
Shelly Plug SHPLG-1 Relay
Shelly Plug E SHPLG2-1 Relay
Shelly Plug S SHPLG-S Relay
Shelly Plug US SHPLG-U1 Relay
Shelly RGBW2 SHRGBW2 RGBW
Shelly Dimmer 1 SHDM-1 Dimmer
Shelly Dimmer 2 SHDM-2 Dimmer
Shelly DUO SHBDUO-1 Dimmer
Shelly Vintage SHVIN-1 Dimmer
Shelly Duo RGBW SHCB-1 RGBW
Shelly Bulb RGBW SHBLB-1 RGBW
Shelly H&T SHHT-1 Sensor
Shelly Flood SHWT-1 Sensor
Shelly Door/Window 1 SHDW-1 Sensor
Shelly Door/Window 2 SHDW-2 Sensor
Shelly Gas SHGS-1 Sensor
Shelly Motion SHMOS-01 Sensor
Shelly Motion 2 SHMOS-02 Sensor
Shelly Smoke SHSM-01 Sensor
Generation 2 Devices
Shelly Plus 1 SNSW-001X16EU Relay
Shelly Plus 1 UL SNSW-001X15UL Relay
Shelly Plus 1PM SNSW-001P16EU Relay
Shelly Plus 1PM UL SNSW-001P15UL Relay
Shelly Plus 2PM SNSW-002P16EU Relay
Shelly Plus 2PM v.1 SNSW-102P16EU Relay
Shelly Plus 2PM UL SNSW-002P15UL Relay
Shelly Plus i4 SNSN-0024X Button
Shelly Plus i4DC SNSN-0D24X Button
Shelly Plus H&T SNSN-0013A Sensor
Shelly Plus Plug IT SNPL-00110IT Relay
Shelly Plus Plug S SNPL-00112EU Relay
Shelly Plus Plug S V2 SNPL-10112EU Relay
Shelly Plus Plug UK SNPL-00112UK Relay
Shelly Plus Plug US SNPL-00116US Relay
Shelly Plus Smoke SNSN-0031Z Sensor
Shelly Plus Wall Dimmer SNDM-0013US Dimmer
Shelly Plus Uni SNSN-0043X Relay
Shelly Plus 0-10V Dimmer SNDM-00100WW Dimmer
Shelly Plus RGBW PM SNDC-0D4P10WW RGBW
Shelly Plus 1 Mini SNSW-001X8EU Relay
Shelly Plus 1PM Mini SNSW-001P8EU Relay
Shelly Plus PM Mini SNPM-001PCEU16 Relay
Shelly Pro 1 SPSW-001XE16EU Relay
Shelly Pro 1 v.0 SPSW-101XE16EU Relay
Shelly Pro 1 v.1 SPSW-201XE16EU Relay
Shelly Pro 1 v.1 UL SPSW-201XE15UL Relay
Shelly Pro 1PM SPSW-001PE16EU Relay
Shelly Pro 1PM v.0 SPSW-101PE16EU Relay
Shelly Pro 1PM v.1 SPSW-201PE16EU Relay
Shelly Pro 1PM v.1 UL SPSW-201PE15UL Relay
Shelly Pro 2 v.1 SPSW-202XE16EU Relay
Shelly Pro 2 v.1 UL SPSW-202XE12UL Relay
Shelly Pro 2PM SPSW-002PE16EU Relay
Shelly Pro 2PM v.0 SPSW-102PE16EU Relay
Shelly Pro 2PM v.1 SPSW-202PE16EU Relay
Shelly Pro Dual Cover/Shutter PM SPSH-002PE16EU Relay
Shelly Pro Dimmer 1PM SPDM-001PE01EU Dimmer
Shelly Pro Dimmer 2PM SPDM-002PE01EU Dimmer
Shelly Pro Dimmer 0/1-10V PM SPCC-001PE10EU Dimmer
Shelly Pro 3 SPSW-003XE16EU Relay
Shelly Pro 3EM SPEM-003CEBEU Measure
Shelly Pro 3EM SPEM-003CEBEU120 Measure
Shelly Pro 3EM-400 SPEM-003CEBEU400 Measure
Shelly Pro EM-50 SPEM-002CEBEU50 Measure
Shelly Pro 4PM V1 SPSW-004PE16EU Relay
Shelly Pro 4PM V2 SPSW-104PE16EU Relay
Shelly Pro 4PM V3 SPSW-204PE16EU Relay
Shelly Pro RGBWW PM SPDC-0D5PE16EU RGBW
Shelly Wall Display SAWD-0A1XX10EU1 Relay
Shelly Wall Display X2 SAWD-2A1XX10EU1 Relay
ShellyBLU Gateway SNGW-BT01 BluGateway
Generation 3 Devices
Shelly 1 Gen3 S3SW-001X16EU Relay
Shelly 1PM Gen3 S3SW-001P16EU Relay
Shelly 2PM Gen3 S3SW-002P16EU Relay
Shelly i4 Gen3 S3SN-0024X Button
Shelly H&T Gen3 S3SN-0U12A Sensor
Shelly Dimmer Gen3 S3DM-0A101WWL Dimmer
Shelly Dimmer 0/1-10V PM Gen3 S3DM-0010WW Dimmer
Shelly Plug S MTR Gen3 S3PL-00112EU Relay
Shelly 1 Mini Gen3 S3SW-001X8EU Relay
Shelly 1PM Mini Gen3 S3SW-001P8EU Relay
Shelly PM Mini Gen3 S3PM-001PCEU16 Relay
Shelly DALI Dimmer Gen3 S3DM-0A1WW Dimmer
Shelly EM Gen3 S3EM-002CXCEU Measure
Shelly 3EM-63 Gen3 S3EM-003CXCEU63 Measure
ShellyBLU Gateway Gen3 S3GW-1DBT001 BluGateway
Shelly Outdoor Plug S Gen3 S3PL-20112EU Relay
Shelly AZ Plug Gen3 S3PL-10112EU Relay
Shelly Shutter Gen3 S3SH-0A2P4EU Roller
Shelly 2L Gen3 S3SW-0A2X4EUL Relay
Shelly 1L Gen3 S3SW-0A1X1EUL Relay
Shelly The Pill Gen3 S3SN-0U53X Sensor
Shelly Plug PM Gen3 S3PL-30116EU Relay
Shelly Plug M Gen3 S3PL-30110EU Relay
Shelly Ogemray Smart Relay 25A S3PB-O3AR000001 Relay
Generation 4 Devices
Shelly 1 Gen4 S4SW-001X16EU Relay
Shelly 1PM Gen4 S4SW-001P16EU Relay
Shelly 2PM Gen4 S4SW-002P16EU Relay
Shelly 1 Mini Gen4 S4SW-001X8EU Relay
Shelly 1PM Mini Gen4 S4SW-001P8EU Relay
Shelly EM Mini Gen4 S4EM-001PXCEU16 Measure
Shelly Flood Gen4 S4SN-0071A Sensor
Shelly Power Strip 4 Gen4 S4PL-00416EU Relay
Shelly Plug US Gen4 S4PL-00116US Relay
Shelly Dimmer Gen4 S4DM-0A101WWL Dimmer
Shelly 1 Gen4 ANZ S4SW-001X16ANZ Relay
Shelly 1PM Gen4 ANZ S4SW-001P16ANZ Relay
Shelly 2PM Gen4 ANZ S4SW-002P16ANZ Relay
BLU Devices
Blu devices must be connected to a BlueGateway or any other bluetooth capable shelly.
Note: Devices marked as "not tested" should work but have not been verified. If you discover a new device or encounter issues, please create an issue on GitHub with the information returned from the /shelly endpoint of the device.
Thanks for your donation
If you want to support this free project. Any help is welcome. You can donate by clicking one of the following links:
Buy Me A Coffee
Credits
  • gerdemann for providing the roller shutter code
  • Gophlin for provider the Dimmer (SL) code
  • minuq for providing pull request for issue #7
  • Paul-Reed for enhancing the dimmer node see issue #21
  • Docjones for providing the skeleton for ShellyRGBW node see pull request #15
  • arvidcarlander for adding all_status feature to cloud node
  • teixemf for testing and fixing gen 2 rpc problems
  • MichaelEFlip for improving the readme
  • Solarer for fixing script overload
  • prpr19xx for adding exception handling to callback script
  • eisenluk for finding and fixing the digest authentication failure on firmware 2.0.0 see issue #296
👥 Contributors
Changelog
Changes can be followed here
General
To check if the node is available in the network, a HTTP GET to /shelly is issued. This route returns a type string which is verified. You can configure an interval for the polling. The default is 5000ms, 0 is off = no polling. Most nodes will call HTTP GET to the /status route after a input is received from the node. This answer is directly available at the output via msg.status. The msg.payload property contains a lightweight version of this status object. The hostname can be left empty in the configuration node. This deactivates polling, too. In this case you must pass the hostname in the msg.payload.hostname. This can be useful, if you want to use one node for several devices or if you want to make use of sub flows. (username and password can be passed in msg.payload, too)
    hostname : '192.168.178.250'
    username : 'user'
    password : 'password'
Hostname or IP address
The hostname field takes either an IP address or a name. Enter the bare host (shelly1-a4cf12.local or 192.168.1.5), optionally with a port. A URL pasted from the browser address bar (http://shelly1-a4cf12.local/) is accepted too: the scheme and the path are stripped before the request is built. This also applies to msg.payload.hostname and to the hostname of the callback server configuration node, and leading and trailing spaces are always removed.
A name only works if the machine running node-red can resolve it — not merely the browser you have the node-red editor open in. The usual pitfall is the device's mDNS name (something like shelly1-a4cf12.local): Windows and macOS resolve those in the operating system, but a Linux host resolves them only with nss-mdns installed, and a docker container normally does not resolve them at all and also uses docker's DNS instead of your router's. If the name works in your browser but not in the node, the node status names the reason: "getaddrinfo ENOTFOUND shelly1-a4cf12.local" is a name resolution problem (use the IP address, or add the name to your DNS server or to /etc/hosts), while "connect ECONNREFUSED" or a timeout means the name resolved and the device did not answer.
callback mode vs polling mode
Unlike generation 2 devices which support scripts the older generation 1 supports only webhooks which are very limited. You can always use polling mode, but some devices like sensors and buttons often sleep to safe energy. In this state the node can not reach the shelly in the local network. This results in a polling error which is not a problem, but often generates confusion when the user sees error messages in the node-red debugger or console. To avoid this you can try to enable callback mode. In callback mode a webhook is configured to the shelly which notifies to the node when sensor data changed. The node needs to open a network port to be able to receive these messages. You must configure this network port, make sure that it is not already in use. If node-red runs inside a docker container or any other bridged network then you should also configure the hostname under that the shelly device can reach the node-red server (Leave this field empty if you run inside the same network segment). The node retries to set the webhook if the device is sleeping as long as it succeeds. As soon as the status shows "Connected" the webhook is set. Note that gen2+ devices that have bluetooth support can act as a bluetooth gateway for shelly BLU devices. To activate that feature you must use callback node and check the bluetooth checkbox.
Shelly Node (Generation 1)
See also https://shelly-api-docs.shelly.cloud/gen1/#shelly-family-overview The node can communicate with several shelly types. You must select the correct device type from the combobox when configuring the node. Devices are grouped as follows:
Settings
You can configure your shelly from within the web interface. But there is also the possibility to change the settings from with a flow. Simply pass one or more settings objects in msg.settings:
    device : 'ext_temperature',
    index : 0,
    attribute : 'overtemp_threshold_tC',
    value : 90
    index : 0,
    attribute : 'overtemp_act',
    value : 'relay_on'
To understand the properties please have a look at: https://shelly-api-docs.shelly.cloud/gen1/#shelly1-1pm-settings-ext_temperature-index It always follows the same scheme "/settings//?="
Examples
shelly settings flow
Relays (Shelly 1, 2, 1PM, 1L, Plug, PlugS, Uni)
The node is able to turn on and turn off a shelly switch. It outputs the status of all relays after every interaction with the shelly device. Turning on is done by sending the following payload into the input. The relay number is optional and defaults to 0. Note that the UNI can also deliver the ADCS values in the status.
    relay : 0,
	timer : 1,
	on : true
or you can make use of the alternative notation:
    relay : 0,
	timer : 1,
	turn : 'toggle'
turn can be one of the following: 'toggle', 'on', 'off' timer is optional flip back timer in seconds
Right after having sent the request to the shelly device a status request is done. The relays property of the response is output on output 1.
If you only want to get the current status of the switch without turning on or off you should leave the msg.payload blank. This is useful, when you want to poll for the status cyclically.
The output of the node is an array of status objects for every relay of the switch:
relays : [
        ison : true,
        ison : true,
meters : [
inputs : [
adcs : [
Examples
shelly switch flow shelly uni flow
Measure (Shelly EM, EM3)
    relay : 0,
	timer : 1,
	on : true
    relay : 0,
	timer : 1,
	turn : 'toggle'
relays : [
        ison : true,
        ison : true,
meters : [
Download of historical data
Devices like the EM and EM3 store data. You can download the historical time series data as follows:
        download : [0, 1, 2],
The download variable contains a list of channels that should be downloaded. This can be either one or more numbers. Note that downloading from the device can take some seconds as it depends on the size of the gathered data. Data is sent to output 2.
Examples
shelly EM flow
shelly EM download CSV flow
Roller Shutter (Shelly 2, Shelly 2.5)
A node that controls a shelly roller shutter device (Shelly 2.5). The relay number is optional and defaults to 0. The following object for open or close the roller shutter:
    roller : 0,
	go : 'open'
    roller : 0,
	go : 'close'
    roller : 0,
	go : 'to_pos',
	roller_pos: 50
If device is in relay mode: Turning on is done by sending the following payload into the input. The relay number is optional and defaults to 0.
    relay : 0,
	on : true
    relay : 0,
	turn : 'toggle'
Right after having sent the request to the shelly device a status request is done. The roller property of the response is output on output 1.
The output of the node is an array of status objects for every roller and every relay of the roller shutter:
rollers : [
            state : 'open',
			current_pos: 50,
relays : [
		    ison : true,
meters : [
Examples:
shelly roller flow
shelly roller2 flow
shelly roller3 flow
Dimmer (Shelly Dimmer 1/2, Shelly Bulb Duo, Vintage)
The node is able to turn on and turn off a shelly dimmer or shelly bulb duo and set its brightness. It outputs the status of all lights after every interaction with the shelly device. Turning on is done by sending the following payload into the input. The light number is optional and defaults to 0. The brightness can be set between 0 and 100.
    light : 0, // default = 0 (not needed for bulb duo)
    on : true,
    brightness: 100,
	white: 100, // for bulb duo
	temp : 2700, // for bulb duo (same as white but in K 2700 - 6500)
	transition : 0 // for bulb duo (0..5000ms),
	timer : 1, // flip back timer in seconds,
	dim : 'up', // up, down, stop
	step : 10, // dim step in %
Like in the switch node you can replace on with turn and choose a value from the following: 'toggle', 'on', 'off'
You can also control the shelly state and brightness independently.
on: true
and
brightness: 100
This feature can optionally be disabled by unticking the status checkbox in the node configuration options.
If you only want to get the current status of the dimmer without turning on or off you should leave the msg.payload blank. This is useful, when you want to poll for the status cyclically.
The output of the node is an array of status objects for every light of the dimmer:
lights : [
        ison : true,
		brightness: 100
        ison : true,
		brightness: 100
meters : [
Examples:
shelly dimmer flow
shelly bulb duo flow
Thermostat (Shelly TRV)
The node is able to control a shelly TRV. It outputs the status of all thermostats after every interaction with the shelly device. Turning on is done by sending the following payload into the input.
    position : 0..100, // 0 = closed
	temperature : 4..31, // target temperature in C
    schedule : true,
	scheduleProfile : 1..5,
	boostMinutes : 0..n
Right after having sent the request to the shelly device a status request is done. The thermostats property of the response is output on output 1.
If you only want to get the current status of the TRV leave the msg.payload blank. This is useful, when you want to poll for the status cyclically.
Examples:
shelly TRV flow
RGBW (Shelly RGBW2, Shelly Bulb RGWB)
The node is able to control a RGBW LED light strip or a bulb RGBW.
If you only want to get the current status of the node without turning on or off you should leave the msg.payload blank. This is useful, when you want to poll for the status cyclically.
The node accepts the following input
    red : 0,
    green : 0,
	blue : 0,
	white : 0,
	temp : 5000, // bulb
	gain : 0,
	brightness : 0, // bulb
	effect : 1,
	on : true,
	timer : 0,
	transition : 0, // bulb
red, green, blue, white can be between 0 and 255. gain can be a value between 0 and 100. brightness can be a value between 0 and 100. effect = 0 means no effect. timer can be a value in seconds to flip back on/off transition can be a value in milliseconds between 0 and 5000 temp can be a value in K between 3000 and 6500 for white
lights : [
		light : 0,
		on : true,
		brightness: 100,
		timer : 0,
light 0 .. 3 is the number of the strip. brightness can be a value between 0 and 100. timer can be a value in seconds to flip back on/off
Examples:
shelly RGBW2 color flow
shelly RGBW2 color effect flow
shelly RGBW2 white flow
shelly bulb RGBW flow
Sensor (Shelly Window/Door Node 1/2, Shelly Flood, Shelly H&T, Shelly Motion 1/2 )
The node is able to poll a shelly window/door, motion, gas, ... sensor. It outputs the sensor status together with battery and sensor values on every change sensor status. Note that some sensors sleep when nothing is detected and is thus not accessible via REST.
The output of the window, door sensor is as follows:
    sensor
		state: 'close',
		is_valid: true
	lux
		value: 150,
		illumination: 'twilight',
		is_valid: true
	bat
		value: 100,
		voltage: 6.01
The output of the motion sensor is as follows:
    sensor
		motion: true,
		vibration: true,
		timestamp: 12345,
		active: true,
		is_valid: true
	lux
		value: 150,
		is_valid: true
	bat
		value: 100,
		voltage: 6.01
Examples:
shelly door flow
shelly motion flow
Button (Shelly Button, I3)
The node is able to control a shelly button. It outputs the status of all inputs after every interaction with the shelly device. Turning on is done by sending the following payload into the input. The input number defaults to 0.
    input : 0,
	event : 'S'
Event can be one of the following S=short push, SS=double short push, SSS=triple short push, L=long push (and LS=long short and SL=short long for the I3). Right after having sent the request to the shelly device a status request is done. The inputs property of the response is output on output 1.
Note that the button is not always reachable as it falls to sleep. This is not the case for the I3.
Examples:
shelly button flow
Shelly Node (Generation 2, Generation 3, Generation 4)
See also https://shelly-api-docs.shelly.cloud/gen2/ See also https://shelly-api-docs.shelly.cloud/gen2/Devices/ShellyPlus1PM The node can communicate with several shelly types. You must select the correct device type from the combobox when configuring the node. The msg.payload property can be used to issue commands (see examples below). Note that you can send multiple commands at once by creating an array in msg.payload.
Unlike generation 1 devices the new generation supports the usage of scripts. In polling mode the node just behaves like the generation 1 node. In callback mode a script is uploaded to the shelly which sends all notification events to the node. The node needs to open a network port to be able to receive these messages. You must configure this network port, make sure that it is not already in use. If node-red runs inside a docker container or any other bridged network then you should also configure the hostname under that the shelly device can reach the node-red server (Leave this field empty if you run inside the same network segment).
Relay (Plus 1, Plus 1 PM, Plus 2 PM, Plus UNI, Pro 1, Pro 1 PM, Pro 2, Pro 2 PM, Pro 4 PM, Plug US, Mini, 1PM Mini, PM Mini, Shelly Wall Display)
The node is able to turn on and turn off a shelly switch. It outputs the status after every interaction with the shelly device. Turning on is done by sending the following payload into the input. The relay number is optional and defaults to 0.
    method : 'Switch.Set',
	parameters : {
        on : true,
        toggle_after : 2 // optional flip back time in seconds
or you can make use of the alternative toggle command:
    method : 'Switch.Toggle'
Note that toggle_after is optional. The unit is seconds. Right after having sent the request to the shelly device a status request is done.
The output of the node is the full status object of the device. See https://shelly-api-docs.shelly.cloud/gen2/Overview/CommonServices/Shelly
For further rpc commands see the shelly documentation.
The arguments may be given as parameters (as above) or as params, which is the spelling used by the official Shelly RPC documentation. Both are accepted, so a JSON-RPC frame copied straight out of the Shelly docs can be used as msg.payload unchanged. Before 11.11.3 only parameters was read and a payload using params lost its arguments, which the device answered with Request failed with status code 400.
Examples:
shelly switch gen 2 flow shelly rollerplus flow (Shelly Plus 2 PM)
Dimmer (Plus Dimmer 0-10V)
The node is able to turn on and turn off a shelly dimmer. It outputs the status after every interaction with the shelly device. Turning on is done by sending the following payload into the input. The light number is optional and defaults to 0.
    method : 'Light.Set',
	parameters : {
        on : true,
		brightness : 100,
		transition_duration : 1, // optional transition time in seconds
    method : 'Light.Toggle'
If you only want to get the current status of the light without turning on or off you should leave the msg.payload blank. This is useful, when you want to poll for the status cyclically.
Examples:
shelly dimmer gen 2 flow
RGBW PM (Plus RGBWr 12/24V)
The node is able to turn on and turn off a shelly RGBW PM Plus. It outputs the status after every interaction with the shelly device. Turning on is done by sending the following payload into the input. The light number is optional and defaults to 0. The device can be operated in color and white mode. For color mode you can use the following example:
    method : 'RGBW.Set',
	parameters : {
        on : true,
		brightness : 100,
    method : 'RGBW.Toggle'
For white mode you can use the following example:
	parameters : {
        on : true,
		brightness : 100,
Examples:
shelly RGBW plus PM gen 2 flow
Button (Shelly Plus I4)
The node is able to control a shelly button. It outputs the status of all inputs after every interaction with the shelly device. See https://shelly-api-docs.shelly.cloud/gen2/Components/FunctionalComponents/Input
Examples:
shelly button plus flow
Sensor (Shelly Plus H&T, Plus Smoke)
The node is able to control a shelly sensor. Usually sensors sleep all the time to save energy. Hence you will get an error when polling for the status but sometimes when the device wakes up you will receive valid data. Another possibility is to use the callback mode. Unlike other 2. generation devices sensors do often not support scripts. Therefore webhooks are installed as soon as the device is not sleeping. When the shelly calls the webhook, the node gets the status and sends it to the output. You can wake up your device manually on redeploy to speed up initialization. Otherwise errors will be generated in the debugging pane telling you that installation of the webhook failed.
BLU Gateway (Shelly BLU Gateway)
The node is able to control a shelly BLU gateway. This node should be only used with callback mode and event output. It uploads two scripts: one for the callback like in all other gen 2 devices and one that scans for bluetooth signals. This script was taken from https://github.com/ALLTERCO/shelly-script-examples/blob/main/ble-shelly-blu.js and is licensed under the apache 2.0 license!
The output of the node is an event object. Bluetooth event objects have the event name "shelly-blu".
msg.payload.info.event === "shelly-blu"
You can take the mac-address to find out what BLU device sent the messages:
msg.payload.info.data.address
Examples:
shelly BLU gateways flow
Some notes about BLU Support
Almost all gen2+ device support bluetooth and can be used as blu gateway by using callback mode and activating the gateway support in the config node. Messages from the BLU devices are in BTHomeV2 format: https://bthome.io/format/
BLU RC Button 4
The node is able to control a shelly RC button 4. This device communicates via bluetooth. You must use at least one shelly as bluetooth gateway to be able to receive message in node-red from that device. This gateway node should be only used with callback mode and event output. It uploads two scripts: one for the callback like in all other gen 2 devices and one that scans for bluetooth signals. This script was taken from https://github.com/ALLTERCO/shelly-script-examples/blob/main/ble-shelly-blu.js and is licensed under the apache 2.0 license!
BLU devices contain a detailed description about the types that are used: E.g. the documenation for the shelly RC button 4 can be found here: https://shelly-api-docs.shelly.cloud/docs-ble/Devices/wall_us/ Type 0x3A is tranmitted if a button is pressed. The value can be on of the following: 0x00 - none (button not pressed) 0x01 - press 0x02 - double press 0x03 - triple press 0x04 - long press 0xFE - hold The buttons are transmitted as an array with the values mentioned above.
Examples:
shelly BLU RC button 4 flow
Shelly REST API
For a complete documentation see also https://shelly-api-docs.shelly.cloud/#common-http-api
Shelly Cloud API
See also https://shelly-api-docs.shelly.cloud/cloud-control-api/communication The node can communicate with your shellies via cloud API. You need to create an authentication key in your shelly app and enter it into the config node. Generate it in the Shelly Cloud app under User settings -> Authorization cloud key; the server URI is shown on the same page, and both are account specific. See the Shelly Cloud Control API documentation for details.
Two API versions are supported. Shelly has deprecated the v1 API above and replaced it with v2.0-beta. Pick the version on the cloud server config node: new configurations default to v2, while configurations made before this option existed keep using v1, so updating the package never changes an existing flow. The commands below are the v1 vocabulary — v2 uses different payloads, see the migration guide and the shelly cloud flow (API v2) example. All devices have unique IDs. You can configure the ID in the config node or send it into the node, just as you prefer. Note that the cloud API is limited to 1 call per second. If you call too fast you will likely receive an error 401. You can get the status of a device by simply triggering the node using a msg.payload as follows contains the id of the device
	type : 'status',
    id : 'your device id here in hex',
Listing all devices
Similar to retrieving the status of a device, you can retrieve the status of all devices by changing the type to "status_all" and removing the "id" line:
	type : 'status_all'
Relay
You can control relays as follows:
    type : 'relay',
	channel : 0,
	turn : on | off
Examples
shelly cloud flow (API v1)
Roller
You can control rollers as follows:
    type : 'roller',
	direction : open | close | stop
	pos : 0..100
Please use direction or pos here.
Examples
Light
You can control lights as follows:
    type : 'light',
	channel : 0,
	turn : on | off
	white : 0..255
	red : 0..255
	green : 0..255
	blue : 0..255
	gain : 0..255
	brightness : 0..255
Please see documentation. It depends on if you have RGBW or White lights.
Examples
Bulk Control
You can turn on|off many relays or rollers with one single call as follows:
    type : 'relays',
    turn : on | off,
	devices : [
		  channel : 0
Author: Karl-Heinz Wind
The MIT License (MIT) Copyright (c) 2019 by Karl-Heinz Wind
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
Version: 11.12.3
Updated 2 months, 2 weeks ago
Rating: 4.8 26
883 in the last week
  • shelly-gen1-server
  • shelly-gen1
  • shelly-gen2-server
  • shelly-gen2
  • shelly-cloud-server
  • shelly-cloud
  • shelly
