node-red-contrib-shadow-check 1.0.2
A Node-RED node for checking if the sun shines into a window
npm install node-red-contrib-shadow-check
A Node-RED node that checks whether the sun currently shines into a configured window.
The node combines a window's dimensions, azimuth, inset and roof overhang settings with sun position input. It can be used to decide whether blinds or roller shutters should be lowered.
This node can be installed by searching for node-red-contrib-shadow-check in the Palette or running the following command in your Node-RED user directory – typically ~/.node-red.
$ npm install node-red-contrib-shadow-check
usage example
Input
The node expects sun position data on msg.payload:
  "azimuth": 180,
  "altitude": 35,
  "sunInSky": true
azimuth and altitude are degrees. sunInSky is optional and defaults to true. If sunInSky is false, the output payload is false.
Output
The node preserves the incoming message and sets:
  • msg.payload: true if the sun shines into the configured window, otherwise false
  • msg.topic: the configured topic, defaulting to sunInWindow
Development
npm ci --ignore-scripts
npm run lint
npm run typecheck
npm test
npm run build
Release versioning is managed with Changesets:
npm run changeset
Version: 1.0.2
Updated 4 months, 1 week ago
Rating: 4.0 1
8 in the last week
