node-red-contrib-sftpco 1.0.17
Node red contrib for CRUD operations on SFTP server, wrapper for ssh2-sftp-client
npm install node-red-contrib-sftpco
An SFTP client for node-red, wrapper for ssh2-sftp-client
BuyMeCoffee
Why anoher node for SFTP connection ?
The other watcher (wfwatcher) check recursively and attach filename to payload... Most of nodes who work with file check msg.filename.
So this plugin attach to msg :
  • file : the name of the file, with extension
  • filedir : Directory of file
  • filename: the complete path to the file
  • payload: the complete path to the file
On configuration side we can :
  • Select the folder to watch (of course ....)
  • Type event : create, update, delete
  • Check for recursively or not
  • ignore file who are in directory are start (or not)
  • ignore files on regex based, only String !, not type the / for regextype (I.E. ^test.(txt|xls) not /^test.(txt|xls)/)
Prerequisites
Have Node-RED installed and working, if you need to install Node-RED see here.
Install via Node-RED Manage Palette
node-red-contrib-watchdirectory
Install via npm
$ cd ~/.node-red
$ npm install node-red-contrib-watchdirectory
# then restart node-red
Contribute
PR are welcome
Version: 1.0.17
Updated 7 years, 1 month ago
10 in the last week
  • SFTP-credentials
  • SFTP-main
  • nodered
  • node red
  • sftp
  • ssh ftp
  • ftp ssh
