node-red-contrib-settings-vault 2.0.3
Centralized settings management for Node-RED. Store credentials, API endpoints, database settings, and any other configuration values in one encrypted location with no external dependencies. Perfect for managing multiple environments.
npm install node-red-contrib-settings-vault
A Node-RED module for centralized settings management with encrypted storage. Store credentials, API endpoints, database settings, feature flags, and any other configuration values in one secure location and reuse them across multiple flows.
Compatible with Node-RED v2.0.0 and above | No external dependencies | Uses built-in Node-RED encryption
Table of Contents
Overview
This module provides a centralized approach to managing any configuration values in Node-RED flows. Instead of hardcoding settings in function nodes, scattering them across multiple flows, or managing separate configuration files, you can define all your configuration values once in a secure configuration node and retrieve them wherever needed.
How to Use:
All your settings are stored once in a vault-config configuration node (viewable/editable via menu → Configuration nodes). Once stored, you can retrieve these values in three ways:
  1. Using the vault node - Add vault nodes to your flows to automatically retrieve and populate settings when messages pass through
  2. Using function nodes - Access vault values directly in your JavaScript code using global.get('vault') - no need to add extra nodes to your flow
  3. Using JSONata expressions - Access vault values in any node with JSONata support (change, switch, etc.) using $globalContext('vault') for inline transformations
All methods access the same encrypted configuration, so use whichever approach fits your flow best - or use them together.
What can you store:
  • Credentials (API keys, secrets, tokens)
  • API endpoints and base URLs
  • Database connection strings and settings
  • SMTP server configurations
  • Feature flags and environment settings
  • Timeout values and thresholds
  • Any other configuration data your flows need
How it works:
Think of the vault-config node (where you store values) like a drawer in a filing cabinet. Inside this drawer, you have multiple folders (called "groups"), and each folder contains labeled papers (your configuration values). The vault runtime node then retrieves specific values from this drawer when needed.
For example, a vault-config named "Production Settings" might contain:
  • A folder labeled "apiService" with papers for: baseUrl, apiKey, timeout
  • A folder labeled "database" with papers for: host, port, username, password
  • A folder labeled "emailServer" with papers for: smtp, port, credentials
All values are encrypted using Node-RED's built-in credential encryption mechanism and stored in the flows_cred.json file. This ensures sensitive data never appears in plain text in your flows.json file.
The vault runtime node is what you place in your flows to retrieve values. You configure it by specifying which folder (group) to open, which paper (property) to read, and where to put that value (in msg, flow, or global context). When a message passes through the vault node, it automatically retrieves the configured values from the drawer and makes them available to the rest of your flow.
Why Use Settings Vault
  • Single Source of Truth: All configuration in one place - change once, affects all flows using it
  • Encrypted Storage: Uses Node-RED's built-in credential encryption with no external dependencies
  • Multiple Environments: Create separate vaults for dev, staging, production - same flow logic, different settings
  • Feature Flag Control: Enable/disable/redirect entire flows without modifying flow logic
  • Version Control Friendly: Configuration separate from flow logic, safe to share flows without exposing credentials
  • Environment-Agnostic Flows: Develop with test settings, deploy with production settings by switching vault reference
Via Palette Manager (Recommended)
  1. Open Node-RED editor
  2. Go to Menu → Manage palette → Install tab
  3. Search for node-red-contrib-settings-vault
  4. Click Install
Via npm
Install in your Node-RED user directory (typically ~/.node-red):
Important: Restart Node-RED after npm installation to load the nodes.
Requirements
  • Node-RED v2.0.0 or higher
  • Node.js v14.0.0 or higher
The nodes will appear in the palette:
  • vault-config (created through a vault node, then viewable in Configuration nodes panel via menu)
  • vault in the function category with a key icon
Supported data types:
Type Description Use Case
str String/text Usernames, hostnames, URLs, tokens
cred Masked string Credentials, secrets, API keys (hidden in editor)
num Number Ports, timeouts, IDs, counts
bool Boolean Feature flags, enable/disable settings
json JSON object/array Complex configurations, nested data
date Timestamp Expiration dates, schedule times
Overview:
Create a vault configuration once and use it across multiple flows. Store your settings in groups (e.g., "apiService", "database") with properties inside each group. Once configured, retrieve values using:
  • Vault node - Visual node in your flow
  • Function node - JavaScript API for programmatic access
  • JSONata expressions - Inline access in any node with JSONata support (change, switch, etc.)
Creating a Vault Configuration
  1. Drag a "vault" node into your flow and double-click to open settings
  2. Click the pencil icon (✏️) next to the Vault dropdown to create a new vault-config
  3. Name it (e.g., "Production Settings")
  4. Add groups (e.g., "apiService") and properties within each group (e.g., baseUrl, apiKey, timeout)
  5. Click "Add" to save
Note: Vault configurations can only be created through a vault node. Once created, view/edit them via menu → Configuration nodes.
Retrieving Values
Using Vault Node
Add a vault node to your flow and configure it to retrieve values when messages pass through:
Configure vault node:
- Vault: Select "Production Settings"
- Group: "apiService"
- Property: "apiKey"
- Output to: msg.apiKey
Multiple properties can be retrieved in a single vault node.
Using Function Node
Function Node Examples (click to expand)
const vault = global.get('vault');
// Using getProperty() method
const apiKey = vault('Production Settings').getGroup('apiService').getProperty('apiKey');
// Direct property access
const apiKey = vault('Production Settings').getGroup('apiService').apiKey;
// Get entire group
const api = vault('Production Settings').getGroup('apiService');
const url = api.baseUrl + '/endpoint';
// Destructure multiple properties
const { baseUrl, apiKey, timeout } = vault('Production Settings').getGroup('apiService');
// Get all properties as object
const config = vault('Production Settings').getGroup('apiService').getAll();
Note: global.get('vault') is required - 'vault' is the registered name of the API.
Using JSONata
In any node with JSONata support (change, switch, etc.), set expression type to "JSONata" (J:):
Basic JSONata Examples (click to expand)
$globalContext('vault')('Production Settings').getGroup('apiService').getProperty('apiKey')
$globalContext('vault')('Production Settings').getGroup('apiService').apiKey
// Access multiple properties
$globalContext('vault')('Production Settings').getGroup('database').host & ":" &
$globalContext('vault')('Production Settings').getGroup('database').port
Advanced: Dynamic Environment Switching (click to expand)
Use a single property to control which environment's credentials are used across all flows.
Vault Structure:
Vault: "Settings"
  Group: "config"
    - currentEnvironment: "production"  (str)
  Group: "production"
    - username: "prod_user"
    - password: "prod_pass_123"
    - endpoint: "https://api.prod.example.com"
  Group: "staging"
    - username: "staging_user"
    - password: "staging_pass"
    - endpoint: "https://api.staging.example.com"
Get single value based on environment:
  $env := $globalContext('vault')('Settings').getGroup('config').currentEnvironment;
  $globalContext('vault')('Settings').getGroup($env).username
Get all environment values at once:
  $group := $globalContext('vault')('Settings').getGroup($env);
    "username": $group.username,
    "password": $group.password,
    "endpoint": $group.endpoint
Benefit: Change currentEnvironment from "production" to "staging" once, and all your flows automatically use staging credentials!
Use Cases
API Integration
Store API credentials and endpoints together, then use them in HTTP requests.
[vault] → [http request]
Vault retrieves baseUrl and apiKey from apiService group and stores them in msg.baseUrl and msg.apiKey.
Database Connections
Retrieve database credentials and connection settings for database nodes.
[vault] → [mysql/postgres/mongodb]
Vault retrieves host, user, and password from database group and stores them in msg.host, msg.user, and msg.password.
Feature Flags
Control flow behavior dynamically without modifying flow logic.
[vault] → [switch: check flag] → route based on configuration
Vault retrieves maintenanceMode and useTestAPI from features group and stores them in flow.maintenance and flow.testMode.
Examples:
  • Enable/disable flows based on maintenance mode
  • Route to different APIs (production/test/mock) based on configuration
  • Adjust thresholds or limits without redeploying flows
Shared Configuration
Store settings in flow or global context for access across multiple flows.
[vault] → stores to flow.apiUrl
Multiple flows read flow.apiUrl without duplicating vault nodes
Multiple Configuration Sets
You can create multiple vault-config nodes for different environments or use cases:
  • Separate environments: Development, staging, and production configurations
  • Different clients: Customer A settings vs Customer B settings
  • Testing scenarios: Production data vs test data vs mock data
  • Regional configurations: US servers vs EU servers
Example workflow for multi-environment deployment:
  1. Create "Dev Settings" vault with test endpoints and credentials
  2. Build and test flow using dev vault
  3. Create "Production Settings" vault with production endpoints and credentials
  4. Switch vault reference in node → Deploy
  5. Same flow logic, different configuration
To update values in an existing vault:
  1. Open the vault-config node
  2. Edit the property values
  3. Click "Update" and deploy
All vault nodes using that configuration will use the updated values.
Security
Built-In Encryption
All vault data is encrypted using Node-RED's built-in credential encryption mechanism and stored in flows_cred.json. This is the same proven encryption system Node-RED uses for username/password fields in core nodes.
What is encrypted:
  • Group names
  • Property names
  • All property values
What is NOT encrypted:
  • Vault configuration name (stored in flows.json)
Best Practices
For Security:
  1. Backups: Always backup both flows.json and flows_cred.json together
  2. Access Control: Enable Node-RED's admin authentication to prevent unauthorized access
  3. Cred Type: Use the "cred" type for sensitive values to mask them in the editor
  4. Separate Environments: Use different credentialSecret values for dev, staging, and production
For Configuration Management:
  1. Organize by Group: Organize related settings together (e.g., all API settings in one group)
  2. Descriptive Names: Use clear names for vaults (e.g., "Production Settings" not "Vault1")
  3. Document Values: Add comments in your flow documentation about which vault settings are used where
  4. Consistent Naming: Use consistent property names across environments (e.g., always use "baseUrl" not sometimes "url")
Limitations
Security Limitations:
  • Values are encrypted at rest but decrypted when Node-RED loads flows
  • Anyone with admin access to Node-RED can view and edit all configuration values
  • This is not a replacement for enterprise secret management systems (like HashiCorp Vault or AWS Secrets Manager)
  • For highly sensitive production environments, consider using environment variables with Node-RED's ${ENV_VAR} syntax
Design Considerations:
  • Configuration changes require redeploying flows to take effect
  • All values stored in memory while Node-RED is running
  • Not designed for frequently-changing values (use context store for that)
  • Not designed for large amounts of data (use database for that)
Error Handling
The vault node includes comprehensive error handling:
Errors Prevent Message Flow
The following errors will stop the message from being forwarded:
  1. No Vault Configured: No vault-config node selected
  2. No Properties Configured: No property retrievals configured in the node
  3. Invalid Property Configuration: One or more property rows are incomplete
  4. Group Not Found: The specified group doesn't exist in the vault-config
  5. Property Not Found: The specified property doesn't exist in that group
  6. Invalid Output Format: Output must be in format: context.property (e.g., msg.apiKey)
  7. Invalid Context Type: Context must be msg, flow, or global
  8. Set Property Failed: Unable to set the value to the specified location
Error Messages
Errors appear in the Node-RED debug panel with descriptive messages:
Group not found: apiService
Property "apiKey" not found in group: apiService
Invalid context type "env", must be msg, flow, or global
Additionally, the node displays a red status indicator with a brief error description.
Debugging
  1. Enable debug logging in settings.js: logging: { console: { level: "debug" } }
  2. Use debug nodes after the vault node to inspect output
  3. Verify vault configuration in the Configuration nodes panel
  4. Check that groups and property names match exactly (case-sensitive)
Troubleshooting
Issue: "Group not found" error
Cause: Group name in vault node doesn't match group name in vault-config
Solution:
  • Check spelling and case (names are case-sensitive)
  • Open vault-config and verify the group exists
  • Use the dropdown in vault node (prevents typos)
Issue: Dropdowns appear empty in vault node
Cause: Vault-config node hasn't been saved yet or doesn't contain any groups
Solution:
  • Open the vault-config node and verify groups and properties exist
  • Make sure you clicked "Update" to save the vault-config
  • Dropdowns will show your saved selections even if the vault-config hasn't been opened yet
Issue: Values not appearing in flow/global context
Cause: Flow/global context may not be configured
Solution:
  • Check settings.js for contextStorage configuration
  • Default (memory-only) context works but doesn't persist across restarts
  • For persistence, configure file-based or Redis context storage
Issue: "Module not found" after installation
Cause: Node-RED hasn't been restarted
Solution:
  • Always restart Node-RED after installing nodes
  • If using Docker, restart the container
  • Check npm install completed without errors
Issue: Vault node doesn't appear in palette
Cause: Node-RED needs to be restarted or module wasn't installed correctly
Solution:
  • Verify installation: npm list node-red-contrib-settings-vault in your Node-RED directory
  • Restart Node-RED completely
  • Check Node-RED logs for loading errors
  • Look for "vault" in the function category (key icon)
Issue: Function API not working
Cause: Vault function not registered or incorrect vault name
Solution:
  • Ensure at least one vault-config node exists and is deployed
  • Use exact vault name: vault('Production Settings') - names are case-sensitive
  • Check Node-RED logs for registration errors
  • Verify global.get('vault') returns a function in your function node
MIT
Support
For issues, questions, or contributions, please visit the GitHub repository.
Version: 2.0.3
Updated 1 year ago
647 in the last week
  • vault-config
  • vault
  • node-red-contrib
  • configuration
  • config
  • settings
  • vault
  • credentials
  • secrets
  • environment
  • encrypted
  • centralized
  • multi-environment
