node-red-contrib-servicenow-table-api 1.0.0
node-red-contrib-servicenow-table-api ========================
npm install node-red-contrib-servicenow-table-api
A [Node-RED][1] nodes to use Service Now Table API Table API doc.
Run command on Node-RED installation directory.
or run command for global installation.
npm install -g node-red-contrib-servicenow-table-api
  • Retrieve Records: Retrieves multiple records for the specified table (GET)
  • Retrieve Record: Retrieves the record identified by the specified sys_id from the specified table (GET)
  • Modify Record: Updates the specified record with the request body. (PUT)
  • Update Record: Updates the specified record with the name-value pairs included in the request body (PATCH)
  • Create Record: Inserts one record in the specified table. Multiple record insertion is not supported by this method (POST)
  • Delete Record: Deletes the specified record from the specified table. (DELETE)
Config Nodes
  • Servicenow-config: Configure instance, user and password (basic auth)
Message parameters
  • Retrieve Records Properties
Property Use
msg.topic mandatory tableName
msg.sys_parm_query Optional Query Parameters (default '')
msg.sysparm_display_value Optional Query Parameters (default false)
msg.sysparm_exclude_reference_link) Optional Query Parameters (default false)
msg.sysparm_suppress_pagination_header Optional Query Parameters (default false)
msg.sysparm_fields Optional Query Parameters (default 10)
msg.sysparm_limit Optional Query Parameters (default '')
msg.sysparm_view Optional Query Parameters (default '')
msg.sysparm_query_category Optional Query Parameters (default '')
msg.sysparm_query_no_domain Optional Query Parameters (default false)
msg.sysparm_no_count Optional Query Parameters (default false)
Version: 1.0.0
Rating: 4.0 1
27 in the last week
  • servicenow-config
  • create record
  • retrieve record
  • retrieve records
  • modify record
  • patch record
  • delete record
  • servicenow
