node-red-contrib-servicenow-api-oauth 1.2.1
Node-RED nodes for ServiceNow Table API and Attachment API with OAuth 2.0 authentication. Provides CRUD operations for tables and file attachment management (upload, download, metadata, delete).
npm install node-red-contrib-servicenow-api-oauth
A Node-RED node collection to interact with ServiceNow Table API using OAuth 2.0 authentication. Table API doc.
Option 1: Using Node-RED Palette Manager (Recommended)
  1. Open your Node-RED editor
  2. Click on the menu (top right) → Manage palette
  3. Go to the "Install" tab
  4. Search for node-red-contrib-servicenow-api-oauth
  5. Click "Install"
Option 2: Using npm
Run command on Node-RED installation directory:
or run command for global installation:
npm install -g node-red-contrib-servicenow-api-oauth
After installation, restart Node-RED to load the new nodes.
Table API Nodes
  • Retrieve Records: Retrieves multiple records for the specified table (GET)
  • Retrieve Record: Retrieves the record identified by the specified sys_id from the specified table (GET)
  • Modify Record: Updates the specified record with the request body (PUT)
  • Update Record: Updates the specified record with the name-value pairs included in the request body (PATCH)
  • Create Record: Inserts one record in the specified table (POST)
  • Delete Record: Deletes the specified record from the specified table (DELETE)
Attachment API Nodes
  • Upload Attachment: Uploads a file as an attachment to a ServiceNow record
  • Download Attachment: Downloads a file from ServiceNow attachments
  • Get Attachment Metadata: Retrieves metadata for a ServiceNow attachment
  • Delete Attachment: Deletes a ServiceNow attachment
Config Nodes
servicenow-config
Configuration node for OAuth 2.0 authentication with ServiceNow.
Required Parameters:
  • Name: A descriptive name for this configuration
  • Instance: Your ServiceNow instance URL (e.g., https://yourinstance.service-now.com)
  • Client ID: OAuth client identifier from your ServiceNow OAuth application
  • Client Secret: OAuth client secret from your ServiceNow OAuth application
  • Scope: OAuth scope defining which ServiceNow tables/resources the token can access (e.g., incident, useraccount)
Important Notes:
  • Scope vs Topic: The scope parameter (configured here) defines OAuth permissions for the token. The msg.topic parameter (set in each flow message) specifies which table to operate on. They are different concepts:
    • Scope = "What can my token access?" (OAuth permission)
    • Topic = "Which table am I working with right now?" (API endpoint)
  • A new OAuth token is automatically obtained for each API request
  • Make sure the scope includes all tables you plan to access in your flows
Authentication
This package uses OAuth 2.0 with the client_credentials grant type for authentication.
How it works:
  1. Configure the servicenow-config node with your OAuth credentials (client_id, client_secret, scope)
  2. When a message flows through any operation node (retrieve, create, modify, etc.):
    • The node automatically requests an OAuth access token from ServiceNow (POST /oauth_token.do)
    • ServiceNow responds with an access token valid for ~30 minutes
    • The operation is executed using the Bearer token in the Authorization header
  3. Each API operation automatically handles token acquisition - no manual token management required
OAuth Flow Details:
Token Request:
POST https://yourinstance.service-now.com/oauth_token.do
Content-Type: application/x-www-form-urlencoded
grant_type=client_credentials
&client_id=YOUR_CLIENT_ID
&client_secret=YOUR_CLIENT_SECRET
&scope=YOUR_SCOPE
Token Response:
  "access_token": "...",
  "token_type": "Bearer",
  "expires_in": 1799,
  "scope": "incident"
API Request:
GET https://yourinstance.service-now.com/api/now/table/incident
Authorization: Bearer ACCESS_TOKEN
Attachment API
The package includes nodes for managing file attachments in ServiceNow records.
Upload Attachment
Uploads a file to a ServiceNow record.
Input Message:
msg.topic = "incident";           // Table name (required)
msg.sys_id = "abc123...";         // Record sys_id (required)
msg.filename = "screenshot.jpg";  // File name (required)
msg.payload = Buffer.from(...);   // File content as Buffer (required)
msg.contentType = "image/jpeg";   // MIME type (optional, default: application/octet-stream)
Output:
msg.payload = {
  sys_id: "...",              // Attachment sys_id
  file_name: "...",
  size_bytes: "...",
  content_type: "...",
  download_link: "...",
  table_name: "incident",
  table_sys_id: "abc123..."
Download Attachment
Downloads a file from ServiceNow. Automatically retrieves metadata (filename, content-type) before downloading.
Input Message:
msg.sys_id = "attachment_sys_id";  // Attachment sys_id (required)
Output:
msg.payload = Buffer;              // File content as Buffer
msg.filename = "screenshot.jpg";   // Original filename
Retrieves metadata for an attachment without downloading the file.
Input Message:
Output:
msg.payload = {
  sys_id: "...",
  file_name: "...",
  size_bytes: "...",
  table_name: "...",
  table_sys_id: "...",
  sys_created_on: "...",
  compressed: "true/false"
Delete Attachment
Deletes an attachment from ServiceNow.
Input Message:
Output:
msg.payload = {};                  // Empty object
msg.statusCode = 204;              // Success indicator
Example Flow: Upload and Download
// Upload example
const fs = require('fs');
msg.sys_id = "incident_sys_id_here";
msg.filename = "report.pdf";
msg.payload = fs.readFileSync('/path/to/report.pdf');
msg.contentType = "application/pdf";
// Download example (use attachment sys_id from upload response)
msg.sys_id = "attachment_sys_id_from_upload";
// Save downloaded file
fs.writeFileSync('/path/to/downloaded_' + msg.filename, msg.payload);
Message parameters
Retrieve Records Properties
Property Use
msg.topic mandatory tableName
msg.sys_parm_query Optional Query Parameters (default '')
msg.sysparm_display_value Optional Query Parameters (default false)
msg.sysparm_exclude_reference_link Optional Query Parameters (default false)
msg.sysparm_suppress_pagination_header Optional Query Parameters (default false)
msg.sysparm_fields Optional Query Parameters (default 10)
msg.sysparm_limit Optional Query Parameters (default '')
msg.sysparm_view Optional Query Parameters (default '')
msg.sysparm_query_category Optional Query Parameters (default '')
msg.sysparm_query_no_domain Optional Query Parameters (default false)
msg.sysparm_no_count Optional Query Parameters (default false)
Retrieve Record Properties
Property Use
msg.sys_id mandatory sys_id identifier
Modify Record Properties
Property Use
msg.sysparm_input_display_value Optional Query Parameters (default false)
msg.sysparm_suppress_auto_sys_field Optional Query Parameters (default false)
Update Record
Property Use
Create Record
Property Use
Delete Record
Property Use
Flow Example
Copy and import in your node-red
[{"id":"421fdc9c.1f8134","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"b3866e5.796909","type":"debug","z":"421fdc9c.1f8134","name":"Show response","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":580,"y":260,"wires":[]},{"id":"19cab4c4.6cc5f3","type":"modify record","z":"421fdc9c.1f8134","name":"","server":"","x":340,"y":420,"wires":[["b3866e5.796909"]]},{"id":"7dc62c36.8083ac","type":"inject","z":"421fdc9c.1f8134","name":"Set","props":[{"p":"topic","vt":"str"},{"p":"sys_id","v":"b8736e31871030107aa7cbb9cebb354e","vt":"str"},{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"incident","payload":"{\"short_description\":\"Modify Record Node\"}","payloadType":"json","x":150,"y":420,"wires":[["19cab4c4.6cc5f3"]]},{"id":"1fc4e6ea.8ab849","type":"delete record","z":"421fdc9c.1f8134","name":"","server":"","x":330,"y":500,"wires":[["b3866e5.796909"]]},{"id":"1180f57d.8defb3","type":"inject","z":"421fdc9c.1f8134","name":"Set","props":[{"p":"topic","vt":"str"},{"p":"sys_id","v":"e0650148871070107aa7cbb9cebb35cb","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"incident","x":150,"y":500,"wires":[["1fc4e6ea.8ab849"]]},{"id":"c3f5775a.df0978","type":"patch record","z":"421fdc9c.1f8134","name":"","server":"","x":330,"y":460,"wires":[["b3866e5.796909"]]},{"id":"6a58d6f5.b710a8","type":"inject","z":"421fdc9c.1f8134","name":"Set","props":[{"p":"topic","vt":"str"},{"p":"sys_id","v":"e0650148871070107aa7cbb9cebb35cb","vt":"str"},{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"incident","payload":"{\"short_description\":\"patch Record Node\"}","payloadType":"json","x":150,"y":460,"wires":[["c3f5775a.df0978"]]},{"id":"fb46a6ec.4b376","type":"retrieve records","z":"421fdc9c.1f8134","name":"","server":"","x":340,"y":260,"wires":[["b3866e5.796909"]]},{"id":"bd788f44.140e9","type":"inject","z":"421fdc9c.1f8134","name":"Set","props":[{"p":"topic","vt":"str"},{"p":"sysparm_query","v":"","vt":"str"},{"p":"sysparm_limit","v":"10","vt":"str"},{"p":"display_value","v":"false","vt":"jsonata"},{"p":"msg.sysparm_exclude_reference_link","v":"false","vt":"jsonata"},{"p":"sysparm_fields","v":"","vt":"str"},{"p":"sysparm_view","v":"view","vt":"str"},{"p":"sysparm_query_category","v":"category","vt":"str"},{"p":"sysparm_query_no_domain","v":"false","vt":"jsonata"},{"p":"sysparm_no_count","v":"false","vt":"jsonata"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"incident","payloadType":"str","x":140,"y":260,"wires":[["fb46a6ec.4b376"]]},{"id":"66469ea0.544bc8","type":"inject","z":"421fdc9c.1f8134","name":"Set","props":[{"p":"topic","vt":"str"},{"p":"sysparm_limit","v":"40","vt":"num"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"incident","payloadType":"str","x":140,"y":300,"wires":[["fb46a6ec.4b376"]]},{"id":"fb91ffdc.266a9","type":"comment","z":"421fdc9c.1f8134","name":"Nodes for ServiceNow Table API","info":"","x":190,"y":220,"wires":[]},{"id":"1221d549.6b2b63","type":"retrieve record","z":"421fdc9c.1f8134","name":"","server":"","x":340,"y":340,"wires":[["b3866e5.796909"]]},{"id":"7c99af4c.a240c8","type":"inject","z":"421fdc9c.1f8134","name":"Set","props":[{"p":"topic","vt":"str"},{"p":"sys_id","v":"4c806e31871030107aa7cbb9cebb35dd","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"incident","x":150,"y":340,"wires":[["1221d549.6b2b63"]]},{"id":"fdbcd7c1.5f5af8","type":"create record","z":"421fdc9c.1f8134","name":"","server":"","x":330,"y":380,"wires":[["b3866e5.796909"]]},{"id":"574b92d4.99624c","type":"inject","z":"421fdc9c.1f8134","name":"Set","props":[{"p":"topic","vt":"str"},{"p":"payload"},{"p":"display_value","v":"true","vt":"jsonata"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"incident","payload":"{\"short_description\":\"Create Record Node\"}","payloadType":"json","x":150,"y":380,"wires":[["fdbcd7c1.5f5af8"]]},{"id":"56253416.c9be7c","type":"create record","z":"421fdc9c.1f8134","name":"","server":"","x":680,"y":660,"wires":[[]]}]´´
Contributing
### Feature Requests
Do you need a specific ServiceNow API that is not currently implemented?
**Please open an issue on GitHub!**
We welcome feature requests for additional ServiceNow APIs. When opening an issue, please include:
- **API Name**: Which ServiceNow API you need (e.g., Import Set API, Aggregate API, etc.)
- **Use Case**: Briefly describe what you want to accomplish
- **API Documentation**: Link to the official ServiceNow API documentation if available
**[Open a Feature Request Issue](https://github.com/siphion/node-red-contrib-servicenow-api-oauth/issues/new)**
Your feedback helps us prioritize which APIs to implement next!
ISC License
See [LICENSE](LICENSE) file for details.
Version: 1.2.1
Updated 1 year, 1 month ago
77 in the last week
  • servicenow-config
  • create record
  • retrieve record
  • retrieve records
  • modify record
  • patch record
  • delete record
  • get attachment metadata
  • delete attachment
  • upload attachment
  • download attachment
  • servicenow
  • service-now
  • attachment
  • file-upload
  • oauth2
