node-red-contrib-senec-cloud-v2 1.3.4
Node-RED nodes for SENEC Cloud API integration - supports new API, CCU RedMatic optimized
npm install node-red-contrib-senec-cloud-v2
Node-RED nodes for SENEC Cloud API integration - supports the current SENEC app API (2026), optimized for CCU RedMatic.
  • ✅ SENEC Cloud API Integration - Works with the current SENEC app API (June 2026 endpoints)
  • ✅ Backward Compatible - Drop-in replacement for existing flows
  • ✅ CCU RedMatic Optimized - Low resource usage, tested on CCU hardware
  • ✅ Automatic Error Recovery - Exponential backoff retry logic
  • ✅ Image Generation - Create PNG images for TRMNL e-ink displays
  • ✅ Secure - Credentials encrypted using Node-RED's credential system
Via Node-RED Palette Manager (Recommended)
  1. Open Node-RED editor
  2. Click menu (☰) → Manage palette
  3. Go to "Install" tab
  4. Search for senec-cloud-v2
  5. Click "Install"
Via npm
node-red-restart
On CCU RedMatic
  1. Open CCU WebUI
  2. Navigate to RedMatic add-on
  3. Open Node-RED editor
  4. Use Palette Manager as described above
Quick Start
1. Add Configuration Node
  1. Drag a senec-data node into your flow
  2. Double-click to edit
  3. Click the pencil icon next to "SENEC Config"
  4. Enter your SENEC Cloud credentials:
    • Username: Your SENEC Cloud username/email
    • Password: Your SENEC Cloud password
  5. Click "Test Connection" to verify
  6. Click "Add" to save
2. Configure Data Node
  1. Set poll interval (default: 60 seconds, recommended 120s for CCU)
  2. Enable/disable automatic polling
  3. Deploy your flow
3. Use the Data
The node outputs energy data in msg.payload:
  steuereinheitState: "online",
  gridimport: { today: 2.5, now: 150 },      // kWh, W
  powergenerated: { today: 18.5, now: 3200 }, // kWh, W
  consumption: { today: 12.3, now: 1800 },    // kWh, W
  gridexport: { today: 8.2, now: 1400 },      // kWh, W
  acculevel: { now: 85 }                      // %
senec-config
Configuration node for SENEC Cloud credentials. Shared across multiple data nodes.
Configuration:
  • Username (required)
  • Password (required)
  • Test Connection button
senec-data
Retrieves energy data from SENEC Cloud.
Configuration:
  • SENEC Config: Reference to config node
  • Poll Interval: Seconds between automatic updates (default: 60)
  • Enable Polling: Automatic periodic updates
Input: Any message triggers immediate data retrieval (independent of polling)
Output: msg.payload contains SENEC energy data
Status Indicators:
  • 🟢 Connected - Successfully connected and retrieving data
  • 🟡 Retrying - Temporary error, retrying automatically
  • 🔴 Error - Persistent error, check credentials or connection
senec-image
Generates PNG images from SENEC data for displays.
Configuration:
  • Template: trmnl, compact, or detailed
  • Width/Height: Image dimensions
  • Output Format: buffer, base64, or file
  • Color Scheme: monochrome (e-ink) or color
Input: msg.payload with SENEC data
Output: PNG image as Buffer, base64 string, or file path
Examples
Basic Monitoring
[senec-data] → [debug]
TRMNL Display
[inject: every 5 min] → [senec-data] → [senec-image: TRMNL] → [http response]
CCU Homematic Integration
[senec-data] → [function: extract battery] → [ccu-value: battery variable]
Automation Example
// In a function node after senec-data
var battery = msg.payload.acculevel.now;
var solar = msg.payload.powergenerated.now;
if (battery > 80 && solar > 2000) {
    // Excess solar available - turn on devices
    return { payload: true };
Configuration Tips
For CCU RedMatic
  • Use poll interval of 120 seconds (2 minutes) to reduce resource usage
  • Monitor memory usage in CCU WebUI
  • Disable polling if only triggered retrieval needed
For Raspberry Pi / Standard Node-RED
  • Default 60 second interval works well
  • Can use shorter intervals if needed (minimum 10 seconds)
For TRMNL Displays
  • Use senec-image node with TRMNL template
  • Set dimensions to 800x480 (or your display size)
  • Use monochrome color scheme for e-ink
  • Serve via HTTP endpoint for TRMNL to fetch
Troubleshooting
Authentication Failed
  • Verify credentials in config node
  • Check SENEC Cloud account is active
  • Try logging in to SENEC web portal to confirm credentials
Connection Timeout
  • Check internet connectivity
  • Verify firewall allows HTTPS outbound
  • SENEC Cloud may be temporarily unavailable (automatic retry)
Rate Limited
  • Reduce poll frequency
  • Default backoff will handle this automatically
  • Check for multiple flows polling the same account
High Memory Usage on CCU
  • Increase poll interval to 120-300 seconds
  • Disable polling, use triggered retrieval only
  • Check for other resource-intensive flows
API Changes
This package supports the current SENEC app API. SENEC changed it twice:
  • August 2025: new Keycloak login (OAuth2/PKCE) and app-gateway.prod.senec.dev.
  • June 2026: the gateway was replaced by separate proxy hosts. Since v1.3.4 the package reads systems from senec-app-systems-proxy.prod.senec.dev and the dashboard from senec-app-measurements-proxy.prod.senec.dev. If you see "SENEC Cloud service error" with an older version, update to 1.3.4 or later.
The payload structure did not change.
Migration from old package:
  • Payload structure is identical - existing flows work without changes
  • Simply replace old nodes with new ones
  • Update credentials in config node
Requirements: Node.js 18 or newer. The optional native canvas package (v3) speeds up image rendering; without it the image node falls back to pureimage.
Development
Setup
git clone https://github.com/aunovis-fitting/node-red-contrib-senec-cloud-v2.git
cd node-red-contrib-senec-cloud-v2
npm install
Build
npm run build
Test
npm test
npm run test:coverage
Local Testing in Node-RED
npm run build
npm link
npm link node-red-contrib-senec-cloud-v2
node-red-restart
Architecture
See docs/00-ARCHITECTURE_SUMMARY.md for complete architecture documentation.
Contributing
Contributions welcome! Please:
  1. Fork the repository
  2. Create a feature branch
  3. Make your changes
  4. Add tests
  5. Submit a pull request
Support
MIT License - see LICENSE file
Acknowledgments
  • SENEC for their solar energy storage systems
  • Node-RED community
  • CCU RedMatic project
  • Original senec-cloud package contributors
Disclaimer
This is an unofficial integration. Not affiliated with or endorsed by SENEC GmbH.
Status: ✅ Released
Current Version: 1.3.4 (see CHANGELOG.md)
Version: 1.3.4
Updated 2 weeks, 1 day ago
13 in the last week
  • senec-config
  • senec-data
  • senec-weather
  • senec-image
  • senec
  • solar
  • battery
  • energy
  • home-automation
  • ccu
  • redmatic
  • photovoltaics
  • energy-storage
