node-red-contrib-selfnotify 1.0.0
Node-RED node to send push notifications via SelfNotify
npm install node-red-contrib-selfnotify
A Node-RED node that sends push notifications to your iOS or Android devices via SelfNotify.
From the Node-RED palette manager
Search for selfnotify in the Node-RED palette manager (hamburger menu → Manage palette → Install).
Manually
Then restart Node-RED.
  1. Install the SelfNotify app on your iPhone or Android device.
  2. Copy your token from the app's main screen.
  3. Drop a selfnotify node onto your flow.
  4. Open the node and create a new SelfNotify account config — paste your token.
  5. Wire any inject/function/trigger node into it. The node sends a push notification whenever it receives a message.
Quick example
Simple text notification
Wire an inject node (with a string payload) directly into the selfnotify node:
[Inject: "Hello from Node-RED"] → [selfnotify]
The inject's msg.payload becomes the notification body.
Dynamic notification from a function node
msg.title      = "Server Alert";
msg.payload    = "/var is 94% full";
msg.alertLevel = "time-sensitive";
msg.sound      = "snd08";
msg.group      = "infrastructure";
msg.custom     = { server: "web-01", partition: "/var", usage: "94%" };
Input properties
All properties except msg.payload are optional and override the defaults configured in the node's editor panel.
Property Type Description
msg.payload string Notification body (required if Message field is blank).
msg.token string Overrides the account token for this message only.
msg.title string Bold heading displayed above the body.
msg.subtitle string Secondary line below the title.
msg.alertLevel string active (default), passive, time-sensitive, or critical.
msg.sound string Sound name without extension: snd01–snd16 or cs1, cs2 …
msg.group string Category label for filtering in the app.
msg.custom object Key/value pairs attached as custom attributes and shown in the notification detail view.
msg.custom_* string Alternatively set individual msg.custom_xxx keys directly.
Output properties
The original msg is passed through with one extra property added:
msg.selfnotify object { statusCode, body } — raw response from the SelfNotify API.
Alert levels
Value Behavior
active Plays sound and shows a heads-up banner (default).
passive Silent delivery — appears in notification center / shade only.
time-sensitive Breaks through Focus / Do Not Disturb if the app is allowed.
critical Highest priority, may bypass DND entirely. Use sparingly.
Example flows
Import this JSON into Node-RED (File → Import)
    "id": "sn-inject",
    "type": "inject",
    "name": "Test",
    "props": [{ "p": "payload" }],
    "payload": "Hello from Node-RED!",
    "payloadType": "str",
    "wires": [["sn-node"]]
    "id": "sn-node",
    "type": "selfnotify",
    "name": "Push notification",
    "configNode": "sn-config",
    "title": "Node-RED",
    "alertLevel": "active",
    "wires": [["sn-debug"]]
    "id": "sn-debug",
    "type": "debug",
    "name": "Response",
    "active": true,
    "tosidebar": true,
    "complete": "selfnotify"
    "id": "sn-config",
    "type": "selfnotify-config",
    "name": "My SelfNotify account"
Set your token in the selfnotify-config node before deploying.
Troubleshooting
Status shown on node Likely cause
no token Token not set in config node and msg.token not provided.
empty message msg.payload is not a string and no default message is configured.
invalid token Token does not match the app. Verify it and re-paste if needed.
daily limit reached Free tier allows 20 notifications per day.
rate limited Too many requests in a short window — add a delay node.
Links
Version: 1.0.0
Updated 5 months, 3 weeks ago
  • selfnotify-config
  • selfnotify
  • selfnotify
  • push notification
  • notification
  • alert
  • mobile
