node-red-contrib-sectoralarm-ng 1.0.0
Node-RED nodes for Sector Alarm — works with the current Sector Alarm API (My Pages / omatsivut). Complete rewrite, no dependency on the legacy sectoralarm library.
npm install node-red-contrib-sectoralarm-ng
Node-RED nodes for Sector Alarm — monitor and control your alarm panel, door locks and temperature sensors.
A complete rewrite that works with the current Sector Alarm service (My Pages / omatsivut.sectoralarm.fi / minasidor.sectoralarm.se / minside.sectoralarm.no). It talks directly to the JSON API (mypagesapi.sectoralarm.net) with bearer-token authentication — the same mechanism the official mobile app uses — and has zero runtime dependencies.
The original node-red-contrib-sectoralarm package stopped working when Sector Alarm replaced their old website; it scraped the legacy site with cookie-based logins. This package does not share any code with it.
Requirements
  • Node.js ≥ 18 (native fetch)
  • Node-RED ≥ 3.0
From your Node-RED user directory (~/.node-red):
sectoralarm config (configuration node)
Holds your My Pages credentials (email + password), the optional panel code (needed for disarm/lock/unlock) and the panel ID. After entering credentials, click Fetch panels to pick your panel from a list. All nodes sharing one config node share a single API session — logins happen only when the token expires.
sector status
Polls the armed status on a configurable interval (default 60 s, min 10 s) and emits a message only when the status changes. Optionally emits the current status once on deploy. Any incoming message triggers an immediate query that always emits.
Output:
  topic: "sectoralarm/status",
  payload: {
    status: "armed" | "partialArmed" | "disarmed" | "unknown",
    previousStatus: "disarmed",   // null on first reading
    changed: true,                // false for forced/manual reads without change
    isOnline: true,
    statusTime: "...",
    panelId: "01234567"
  raw: { /* untouched API response */ }
sector control
Arms, disarms and operates door locks. The action can be fixed in the node or come from the message:
msg.payload Effect
"arm" Fully arm
"partialArm" Partial (home) arm
"disarm" Disarm (requires panel code)
{ command: "lock", lockSerial: "..." } Lock a door
{ command: "unlock", lockSerial: "...", code: "1234" } Unlock with explicit code
The panel code defaults to the config node's credential; msg.payload.code overrides it. On success the node outputs { payload: { command, ok: true, panelId } }; on failure no message is sent and the error is raised for Catch nodes (with msg.error = { code, statusCode, message }).
⚠ This node operates a real alarm system — wire it deliberately.
sector query
One-shot reads, triggered by any message. Query type from the node config or msg.payload: status, panel, panels, temperatures, logs ({type:"logs", pageSize: 20, pageNumber: 1}), locks. The payload is the raw API response (shapes vary by panel generation); status is normalized.
Migrating from node-red-contrib-sectoralarm
The old package used a single node with string commands. Equivalents:
Old (msg.payload) New node New input
status, check sector status built-in polling + change events (or send any msg for an immediate read)
arm / partialArm / disarm sector control same payload strings
lock(123) / unlock(123) sector control { command: "lock", lockSerial: "123" }
temperatures, history, locks, info sector query temperatures, logs, locks, panel
annexArm / annexDisarm not supported the new API has no public annex endpoint
4 separate outputs 1 output + Catch node errors carry msg.error.code
Credentials move from the node itself to the shared config node and are stored in Node-RED's encrypted credentials file. The panel code lives there too.
Error handling
All failures carry a stable code:
code meaning
auth_failed wrong email/password, or token rejected twice
timeout request exceeded 15 s
network DNS/connection failure
bad_request HTTP 400 — likely an API contract change
api_error other unexpected HTTP response
code_required / lock_serial_required / invalid_input input validation
After a failed login the client waits 5 minutes before trying again, so a fast poller cannot lock your account out.
Notes & known limitations
  • Temperatures uses the legacy endpoint; the newest "V2" temperature sensors report through a different API and may not appear.
  • Smart plugs, cameras, and housecheck sensors (doors/windows, smoke, leakage) are intentionally out of scope.
  • Sector Alarm may eventually migrate the API login to Auth0 (the web portal already uses it). If login starts failing with bad_request, check this repository for updates.
Development
npm install
npm test            # offline unit + node tests (no real API calls)
npm run smoke       # read-only live test: set SA_EMAIL / SA_PASSWORD first
MIT
Version: 1.0.0
Updated 5 months, 2 weeks ago
  • sectoralarm-ng-config
  • sectoralarm-ng-status
  • sectoralarm-ng-control
  • sectoralarm-ng-query
  • sectoralarm
  • sector alarm
  • alarm
  • home-automation
