node-red-contrib-sds011 0.0.1
Node-RED node to enable a communication with the SDS011 sensor which is connected via UART/serial connection. This node was designed with the RPi in mind but should work with any serial port.
npm install node-red-contrib-sds011
node-red-contrib-sds011-sensor
This is a Node Red node to manage connection to the SDS011 sensor on a Raspberry Pi. It allows you to specify the variables that define the connections to the sensor. This node is added to the Raspberry Pi section.
Version: 0.0.1
Updated 9 years ago
License: GPL-3.0
5 in the last week
  • rpi-sds011
  • sds011
  • pm
  • pm2.5
  • pm10
  • sensor
  • air
  • smog
  • particulates
