node-red-contrib-scinan 1.0.0
An adaptation of the Scinan device API for Node Red
npm install node-red-contrib-scinan
Node.js CI
A Scinan integration node for Node Red. It provides the ability to control thermostats using the Scinan API
Based on Petter Ruud's implementation for Homey. Check it out: https://github.com/PetterRuud/com.scinan.api/
Supported devices
ProSmart
  • PTS50W
Setup
Use the configuration node to provide credentials for your Smart-E account. The device node can request thermostats from the server.
Available nodes
  • Scinan configuration
  • Scinan device
Scinan node example
Getting status
Retreives the current status of the thermostat. Pass the status property to msg.payload, or set the status property in msg.
Property Type Information
status any Retreive the status of the device
msg.status any Retreive the status of the device (alternate input)
Setting values
Pass set property to msg.payload.
away boolean True/False. Set away
target float Set the target temprature (5-27)
mode string Set opration mode {comfort, auto, day_or_night}
Version: 1.0.0
Updated 6 years, 10 months ago
License: GPL-3.0
3 in the last week
  • scinan-device-config
  • scinan-device
  • node-red-contrib
  • iot
  • scinan
  • prosmart
