node-red-contrib-school-holidays-de 1.0.3
A Node-RED node to retrieve school holidays for Germany
npm install node-red-contrib-school-holidays-de
A Node-RED node to retrieve school holidays for all German federal states (Bundesländer).
This node provides easy access to school holiday information for Germany, allowing you to query current, next, or upcoming holidays, filter by state, year, and holiday type.
Or install directly through the Node-RED palette manager.
Prerequisites
You will need an API key from schulferien.app to use this node.
  • Retrieve school holidays for all 16 German federal states
  • Filter holidays by year and type (e.g., summer holidays, winter holidays)
  • Quick access modes: current, next, or upcoming holidays
  • Flexible output formats (array or object with metadata)
  • Dynamic state override via incoming message
  • Visual status indicators for API call states
Basic Configuration
  1. Drag the "Schulferien DE" node from the function category into your flow
  2. Double-click to configure:
    • API Key (required): Your API key from schulferien.app
    • Bundesland: Select a German state or "Alle" for all states
    • Jahr: Select the school year (e.g., 2024/25)
    • Ferienart: Select holiday type or "Alle" for all types
    • Output Format: Choose between array or object format
Quick Access Mode
Enable "Nur folgende Treffer zeigen" to quickly access:
  • Aktuell: Current holidays
  • Nächste: Next holiday period
  • Kommende: Upcoming holidays
Input Message
Trigger the node by sending any message. You can override configuration values:
msg.state = "BY"; // Override state (e.g., Bavaria)
msg.year = "2024"; // Override year
msg.type = "Sommerferien"; // Override holiday type
Output Message
Array Format (default)
msg.payload = [
    start: "2024-07-25",
    end: "2024-09-06",
    state: "BY",
  // ... more holidays
Object Format
msg.payload = {
  state: "BY",
  holidays: [
      end: "2024-09-06",
      state: "BY",
  fetched: "2024-11-03T10:30:00.000Z",
Supported States (Bundesländer)
Code State
BW Baden-Württemberg
BY Bayern (Bavaria)
BE Berlin
BB Brandenburg
HB Bremen
HH Hamburg
HE Hessen (Hesse)
MV Mecklenburg-Vorpommern
NI Niedersachsen (Lower Saxony)
NW Nordrhein-Westfalen (North Rhine-Westphalia)
RP Rheinland-Pfalz (Rhineland-Palatinate)
SL Saarland
SN Sachsen (Saxony)
ST Sachsen-Anhalt (Saxony-Anhalt)
SH Schleswig-Holstein
TH Thüringen (Thuringia)
Holiday Types (Ferienarten)
  • Herbstferien - Autumn holidays
  • Weihnachtsferien - Christmas holidays
  • Winterferien - Winter holidays
  • Osterferien/Frühjahrsferien - Easter/Spring holidays
  • Himmelfahrt/Pfingsten - Ascension Day/Pentecost
  • Sommerferien - Summer holidays
Example Flow
    "id": "example-flow",
    "type": "school-holidays-de",
    "name": "Bayern Holidays",
    "apikey": "your-api-key",
    "state": "BY",
    "year": "2024",
    "holidayType": "all",
    "outputFormat": "array"
Use Cases
  • Home Automation: Adjust heating/lighting schedules during school holidays
  • Calendar Integration: Sync school holidays with personal calendars
  • Travel Planning: Get notified about upcoming holiday periods
  • Educational Apps: Display holiday information in school-related applications
  • Smart Home Scenes: Activate "holiday mode" automatically
Status Indicators
The node provides visual feedback:
  • Blue dot: Fetching data from API
  • Green dot: Successfully retrieved holidays
  • Red ring: Error occurred (check debug panel)
Error Handling
The node will display warnings for:
  • Missing API key
  • Missing state selection
  • API connection errors
  • Invalid API responses
Check the debug panel for detailed error messages.
Requirements
  • Node-RED version 1.0 or higher
  • Node.js version 14.0 or higher
  • Active internet connection
  • Valid API key from schulferien.app
API Information
This node uses the schulferien.app API to retrieve holiday data. Please ensure you have a valid API key and comply with their terms of service.
Repository
Author
Marco Eberlein
ISC
Changelog
1.0.0
  • Initial release
  • Support for all 16 German federal states
  • Flexible filtering by year and holiday type
  • Multiple output formats
  • Quick access modes for current/next/upcoming holidays
Support
For issues, questions, or contributions, please visit the GitHub repository.
Related Nodes
Version: 1.0.3
Updated 1 year, 1 month ago
  • school-holidays-de
  • school
  • holidays
  • germany
  • vacation
