node-red-contrib-schneider-powerlogic 1.0.13
A Node-RED nodes to read Schneider PowerLogic series over Modbus TCP/IP.
npm install node-red-contrib-schneider-powerlogic
Node-RED configurator to read Schneider PowerLogic series over Modbus TCP/IP through Ethernet gateway
You can install these nodes directly from the "Manage Palette" menu in the Node-RED interface.
Alternatively, run the following command in your Node-RED user directory - typically ~/.node-red on Linux or %HOMEPATH%\.nodered on Windows
How to use
meter node
Use the pm3000, pm5000, iem3000, powertag or smartlink node to configure which information you want to request from the gateway.
Wire the output of the pm3000, pm5000, iem3000, powertag or smartlink to the input of the Modbus Flex Getter from 'node-red-contrib-modbus' modules.
Enable check box Keep Msg Properties in the Modbus Flex Getter properties.
With smartlink node it's possible to send commands using Modbus Flex Write from 'node-red-contrib-modbus' modules.
converter node
Use the converter node to prepare data for further use.
Wire the second output of the Modbus Flex Getter to the input of the converter.
Example flow
[{"id":"d2555447b94b0dcc","type":"tab","label":"Schneider PowerLogic ","disabled":false,"info":"","env":[]},{"id":"86ce2a3dedddd570","type":"debug","z":"d2555447b94b0dcc","name":"debug 1","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":1860,"y":320,"wires":[]},{"id":"2ea3581809c148b5","type":"modbus-flex-getter","z":"d2555447b94b0dcc","name":"","showStatusActivities":false,"showErrors":false,"logIOActivities":false,"server":"91f4dcc86c81af04","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":false,"keepMsgProperties":true,"x":640,"y":520,"wires":[[],["72a042193c2a1199"]]},{"id":"e873507c1a4cc2aa","type":"inject","z":"d2555447b94b0dcc","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":220,"y":280,"wires":[["223f593a723a6bfa"]]},{"id":"eadc7e9ee8ac17ba","type":"debug","z":"d2555447b94b0dcc","name":"iC60 commands","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":860,"y":340,"wires":[]},{"id":"c44731d4d5d7b18e","type":"modbus-flex-write","z":"d2555447b94b0dcc","name":"","showStatusActivities":false,"showErrors":false,"server":"91f4dcc86c81af04","emptyMsgOnFail":false,"keepMsgProperties":true,"x":630,"y":340,"wires":[[],["eadc7e9ee8ac17ba"]]},{"id":"223f593a723a6bfa","type":"smartlink","z":"d2555447b94b0dcc","name":"","unitId":"3","mode":"write","channel":"digital-channel-1","device":"rca-ic60-ti24","data":"open","x":400,"y":280,"wires":[["c44731d4d5d7b18e"]]},{"id":"beb5477ee95b5028","type":"inject","z":"d2555447b94b0dcc","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":220,"y":380,"wires":[["7aaccc524ec8845f"]]},{"id":"7aaccc524ec8845f","type":"smartlink","z":"d2555447b94b0dcc","name":"","unitId":"3","mode":"write","channel":"digital-channel-1","device":"rca-ic60-ti24","data":"close","x":400,"y":380,"wires":[["c44731d4d5d7b18e"]]},{"id":"adf54c6286982051","type":"comment","z":"d2555447b94b0dcc","name":"Open iC60","info":"","x":220,"y":240,"wires":[]},{"id":"f36ba135ae795b60","type":"comment","z":"d2555447b94b0dcc","name":"Close iC60","info":"","x":220,"y":340,"wires":[]},{"id":"d56956cbcd834295","type":"pm3000","z":"d2555447b94b0dcc","name":"","unitId":"1","data":"frequency","x":400,"y":520,"wires":[["2ea3581809c148b5"]]},{"id":"1151f5b5a879a296","type":"inject","z":"d2555447b94b0dcc","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":220,"y":580,"wires":[["d56956cbcd834295","2c83317f7f3b3eb1","1fd213413562d295"]]},{"id":"72a042193c2a1199","type":"converter","z":"d2555447b94b0dcc","name":"","unitId":"","data":"","x":860,"y":520,"wires":[["02297c1c19fdb5d3"]]},{"id":"02297c1c19fdb5d3","type":"debug","z":"d2555447b94b0dcc","name":"PM3200 Frequency","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1060,"y":520,"wires":[]},{"id":"1d395d3b376efb5f","type":"modbus-flex-getter","z":"d2555447b94b0dcc","name":"","showStatusActivities":false,"showErrors":false,"logIOActivities":false,"server":"91f4dcc86c81af04","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":false,"keepMsgProperties":true,"x":640,"y":160,"wires":[[],["68f1ac817a330136"]]},{"id":"1e25713ce303215f","type":"inject","z":"d2555447b94b0dcc","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"5","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":230,"y":160,"wires":[["9077db3bf532fcae"]]},{"id":"68f1ac817a330136","type":"converter","z":"d2555447b94b0dcc","name":"","unitId":"","data":"","x":860,"y":160,"wires":[["3265dbba6e88d93c"]]},{"id":"3265dbba6e88d93c","type":"debug","z":"d2555447b94b0dcc","name":"iC60 status ","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1030,"y":160,"wires":[]},{"id":"9077db3bf532fcae","type":"smartlink","z":"d2555447b94b0dcc","name":"","unitId":"3","mode":"read","channel":"digital-channel-1","device":"rca-ic60-ti24","data":"status","x":380,"y":160,"wires":[["1d395d3b376efb5f"]]},{"id":"d202649bd305b530","type":"comment","z":"d2555447b94b0dcc","name":"Read iC60 status","info":"","x":240,"y":120,"wires":[]},{"id":"09a642ec4b385089","type":"comment","z":"d2555447b94b0dcc","name":"Read PM3200","info":"","x":210,"y":540,"wires":[]},{"id":"ec890d91609eadc2","type":"modbus-flex-getter","z":"d2555447b94b0dcc","name":"","showStatusActivities":false,"showErrors":false,"logIOActivities":false,"server":"91f4dcc86c81af04","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":false,"keepMsgProperties":true,"x":640,"y":580,"wires":[[],["55846acf464b4630"]]},{"id":"2c83317f7f3b3eb1","type":"pm3000","z":"d2555447b94b0dcc","name":"","unitId":"1","data":"voltage-LL-Avg","x":400,"y":580,"wires":[["ec890d91609eadc2"]]},{"id":"55846acf464b4630","type":"converter","z":"d2555447b94b0dcc","name":"","unitId":"","data":"","x":860,"y":580,"wires":[["e2d5346923febd25"]]},{"id":"e2d5346923febd25","type":"debug","z":"d2555447b94b0dcc","name":"PM3200 L-L avg","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1050,"y":580,"wires":[]},{"id":"30c1809ee14df422","type":"modbus-flex-getter","z":"d2555447b94b0dcc","name":"","showStatusActivities":false,"showErrors":false,"logIOActivities":false,"server":"91f4dcc86c81af04","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":false,"keepMsgProperties":true,"x":640,"y":640,"wires":[[],["12d78170b9c6d098"]]},{"id":"1fd213413562d295","type":"pm3000","z":"d2555447b94b0dcc","name":"","unitId":"1","data":"current-avg","x":400,"y":640,"wires":[["30c1809ee14df422"]]},{"id":"12d78170b9c6d098","type":"converter","z":"d2555447b94b0dcc","name":"","unitId":"","data":"","x":860,"y":640,"wires":[["919d5d59075cd355"]]},{"id":"919d5d59075cd355","type":"debug","z":"d2555447b94b0dcc","name":"PM3200 I-avg","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1040,"y":640,"wires":[]},{"id":"91f4dcc86c81af04","type":"modbus-client","name":"PowertagLink","clienttype":"tcp","bufferCommands":true,"stateLogEnabled":false,"queueLogEnabled":false,"failureLogEnabled":true,"tcpHost":"192.168.100.50","tcpPort":"502","tcpType":"DEFAULT","serialPort":"/dev/ttyUSB","serialType":"RTU-BUFFERD","serialBaudrate":"9600","serialDatabits":"8","serialStopbits":"1","serialParity":"none","serialConnectionDelay":"100","serialAsciiResponseStartDelimiter":"0x3A","unit_id":"1","commandDelay":"1","clientTimeout":"1000","reconnectOnTimeout":true,"reconnectTimeout":"2000","parallelUnitIdsAllowed":true}]
Meters data
PowerLogic series
List of PM3000/PM5000 meter data:
Measure Units Type
I1: phase 1 current A Float32
I2: phase 2 current A Float32
I3: phase 3 current A Float32
Current Avg A Float32
Voltage L1-L2 V Float32
Voltage L2-L3 V Float32
Voltage L3-L1 V Float32
Voltage L-L Avg V Float32
Voltage L1-N V Float32
Voltage L2-N V Float32
Voltage L3-N V Float32
Voltage L-N Avg V Float32
Active power phase 1 kW Float32
Active power phase 2 kW Float32
Active power phase 3 kW Float32
Total active power kW Float32
Reactive power phase 1 kVAR Float32
Reactive power phase 2 kVAR Float32
Reactive power phase 3 kVAR Float32
Total reactive power kVAR Float32
Apparent power phase 1 kVA Float32
Apparent power phase 2 kVA Float32
Apparent power phase 3 kVA Float32
Total apparent power kVA Float32
Power factor phase 1 - Float32
Power factor phase 2 - Float32
Power factor phase 3 - Float32
Power factor total - Float32
Load type (capacitive, inductive) - String
Current unbalance I1 % Float32
Current unbalance I2 % Float32
Current unbalance I3 % Float32
Current unbalance worst % Float32
Voltage unbalance L1-L2 % Float32
Voltage unbalance L2-L3 % Float32
Voltage unbalance L3-L1 % Float32
Voltage unbalance L-L Worst % Float32
Voltage unbalance L1-N % Float32
Voltage unbalance L2-N % Float32
Voltage unbalance L3-N % Float32
Voltage unbalance L-N worst % Float32
Tangent phi total - Float32
Frequency Hz Float32
Temperature °C Float32
Total active energy import Wh Int64
Total active energy export Wh Int64
Total reactive energy import VARh Int64
Total reactive energy export VARh Int64
Total apparent energy import VAh Int64
Total apparent energy export VAh Int64
Partial active energy import Wh Int64
Partial reactive energy import VARh Int64
Partial apparent energy import VAh Int64
Active energy import phase 1 Wh Int64
Active energy import phase 2 Wh Int64
Active energy import phase 3 Wh Int64
Reactive energy import phase 1 VARh Int64
Reactive energy import phase 2 VARh Int64
Reactive energy import phase 3 VARh Int64
Apparent energy import phase 1 VAh Int64
Apparent energy import phase 2 VAh Int64
Apparent energy import phase 3 VAh Int64
Rate 1 active energy import Wh Int64
Rate 2 active energy import Wh Int64
Rate 3 active energy import Wh Int64
Rate 4 active energy import Wh Int64
Meter data
data-config
Order data
control-config
Sample Measure flow
sample-flow
Sample Order flow
sample-order-flow
Equipment compatibility
Compare the values obtained with the measures on the installed device and report any bugs such as:
  • measured value error
  • measured value format
  • unit of measure
These modules has been developed and tested on:
  • PowerLogic PM3250
  • Ethernet Gateway Link150
Version: 1.0.13
Updated 3 years, 9 months ago
Rating: 5.0 2
13 in the last week
  • pm3000
  • pm5000
  • iem3000
  • powertag
  • smartlink
  • converter
  • schneider
  • pm3000
  • pm5000
