node-red-contrib-scenario 1.1.0
Node-Red Node that can be configured to send a list of output messages with delays between them
npm install node-red-contrib-scenario
Buy Me A Coffee
Node-Red Node that can be configured to send a list of output messages with differents delays between them
  • msg.payload = "start" to start the scenario
  • msg.payload = "stop" to stop the scenario.
  • msg.payload = "init" to init the scenario with your own scenes (see example flow below).
The node will start to output scenes value added in node configuration, scenes value can be String, Number, JSON or Bool each scene has a time of duration (in millisecond).
Example
Copy and paste this flow to see how this node works
[{"id":"c24ce6a1.ba4d88","type":"inject","z":"73c97195.f4e8f","name":"","topic":"","payload":"start","payloadType":"str","repeat":"","crontab":"","once":false,"x":154,"y":528,"wires":[["60f46835.b48228"]]},{"id":"60f46835.b48228","type":"scenario","z":"73c97195.f4e8f","name":"","scenes":[],"x":489,"y":543,"wires":[["cb9a3fad.fc0ed","ffd6c424.d8d0e8"]]},{"id":"122b4c16.0569c4","type":"inject","z":"73c97195.f4e8f","name":"","topic":"","payload":"stop","payloadType":"str","repeat":"","crontab":"","once":false,"x":153,"y":573,"wires":[["60f46835.b48228"]]},{"id":"78353467.46e54c","type":"function","z":"73c97195.f4e8f","name":"","func":"msg.payload = \"init\";\nmsg.scenes = [{value: \"AABBCCDD\", time: 2000},\n             {value: 123456, time: 2000},\n             {value: [{id:\"lamp0\", value: true}, {id:\"lamp1\", value:false}], time: 4000},\n             {value: true, time: 3000}];\nreturn msg;","outputs":1,"noerr":0,"x":326,"y":620,"wires":[["60f46835.b48228"]]},{"id":"75c82685.2c4b68","type":"function","z":"73c97195.f4e8f","name":"","func":"msg.payload = \"init\";\nmsg.scenes = [{value: [{id:\"lamp0\", value: false}, {id:\"lamp1\", value:false}], time: 4000},\n             {value: [{id:\"lamp0\", value: false}, {id:\"lamp1\", value:true}], time: 3000},\n             {value: [{id:\"lamp0\", value: true}, {id:\"lamp1\", value:false}], time: 2000},\n             {value: [{id:\"lamp0\", value: true}, {id:\"lamp1\", value:true}], time: 2000},];\nreturn msg;","outputs":1,"noerr":0,"x":328,"y":664,"wires":[["60f46835.b48228"]]},{"id":"cb9a3fad.fc0ed","type":"split","z":"73c97195.f4e8f","name":"","splt":"","x":618,"y":543,"wires":[["8b734850.ee55c8"]]},{"id":"ffd6c424.d8d0e8","type":"debug","z":"73c97195.f4e8f","name":"","active":true,"console":"false","complete":"false","x":660,"y":633,"wires":[]},{"id":"d5d28940.6e3388","type":"inject","z":"73c97195.f4e8f","name":"init - random","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"x":174,"y":620,"wires":[["78353467.46e54c"]]},{"id":"dd770332.31ab2","type":"inject","z":"73c97195.f4e8f","name":"init - lamps","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"x":166,"y":664,"wires":[["75c82685.2c4b68"]]},{"id":"8b734850.ee55c8","type":"switch","z":"73c97195.f4e8f","name":"","property":"payload.id","propertyType":"msg","rules":[{"t":"eq","v":"lamp0","vt":"str"},{"t":"eq","v":"lamp1","vt":"str"}],"checkall":"true","outputs":2,"x":736,"y":543,"wires":[["1a883801.cd80e8"],["58547bad.de2f14"]]},{"id":"1a883801.cd80e8","type":"change","z":"73c97195.f4e8f","name":"value","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.value","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":875,"y":501,"wires":[["183bc4c6.36b9bb"]]},{"id":"58547bad.de2f14","type":"change","z":"73c97195.f4e8f","name":"value","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.value","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":876,"y":576,"wires":[["25bbc7bc.9bd2f8"]]},{"id":"183bc4c6.36b9bb","type":"ui_switch","z":"73c97195.f4e8f","name":"","label":"lamp0","group":"ae68a6.90419758","order":0,"width":0,"height":0,"passthru":true,"decouple":"false","topic":"","style":"","onvalue":"true","onvalueType":"bool","onicon":"","oncolor":"","offvalue":"false","offvalueType":"bool","officon":"","offcolor":"","x":1010.5,"y":501,"wires":[[]]},{"id":"25bbc7bc.9bd2f8","type":"ui_switch","z":"73c97195.f4e8f","name":"","label":"lamp1","group":"ae68a6.90419758","order":0,"width":0,"height":0,"passthru":true,"decouple":"false","topic":"","style":"","onvalue":"true","onvalueType":"bool","onicon":"","oncolor":"","offvalue":"false","offvalueType":"bool","officon":"","offcolor":"","x":1012,"y":576,"wires":[[]]},{"id":"ae68a6.90419758","type":"ui_group","z":"","name":"Lamps","tab":"89e88935.7363d8","disp":true,"width":"6"},{"id":"89e88935.7363d8","type":"ui_tab","z":"","name":"Scenario","icon":"home","order":1}]
Version: 1.1.0
Updated 6 years, 6 months ago
5 in the last week
  • scenario
  • robertsLando
  • scenario
  • timing
  • scene
