node-red-contrib-scd30 1.0.3
Node-RED node for reading measurements from Sensirion SCD30, the CO2, temperature, and humidity sensor.
npm install node-red-contrib-scd30
Uses scd30-node.
Find the scd30 node in the sensor category in the palette, and use in your flow.
The node replaces the message payload with an object containing the measured values:
  co2Concentration: <number>,
  temperature: <number>,
  relativeHumidity: <number>
Requirements
The SCD30 must be in continuous measurement mode and a measurement must be available when triggering this node.
The measurement interval must be shorter than the interval at which you sample the sensor in Node-RED.
The permission to read the I2C bus device (e.g. /dev/i2c-1) is required.
Usage in Docker on Raspberry Pi
When starting the Node-RED container, use these options:
  • --device /dev/i2c-1 – point to the I2C device to which the SCD30 is connected
  • --group-add <id of i2c group> – make the container process run as a member of the i2c group
For example:
docker run -d \
  -p 1880:1880 \
  -v /home/pi/.node-red:/data \
  --device /dev/i2c-1 \
  --group-add 998 \
  --name nodered \
  nodered/node-red
Version: 1.0.3
Updated 3 years, 2 months ago
5 in the last week
  • scd30
  • scd30
  • co2
  • temperature
  • humidity
  • sensor
