node-red-contrib-scale 1.0.0
Node-RED scale node - maps values from one range to another using linear interpolation
npm install node-red-contrib-scale
Node-RED Scale Node - maps values from one range to another using linear interpolation.
  • Linear mapping from input range to output range
  • Works with inverted ranges (e.g. 100→0)
  • Optional clamping to output range
  • Runtime overrides via msg properties
  • Configurable decimal places (0-10)
Formula
output = (input - inMin) / (inMax - inMin) * (outMax - outMin) + outMin
Examples
0-10 → 0-100:
Input 0  → Output 0
Input 5  → Output 50
Input 10 → Output 100
4-20mA → 0-100%:
Input 4  → Output 0
Input 12 → Output 50
Input 20 → Output 100
Inverted 0-10V → 100-0%:
Input 0  → Output 100
Input 5  → Output 50
Input 10 → Output 0
Property Description Default
Input Min Lower bound of input range 0
Input Max Upper bound of input range 10
Output Min Lower bound of output range 0
Output Max Upper bound of output range 100
Clamp Limit output to range bounds false
Decimals Number of decimal places 2
Input
  • msg.payload - Numeric value to scale
Runtime Overrides
msg.inMin Override input minimum
msg.inMax Override input maximum
msg.outMin Override output minimum
msg.outMax Override output maximum
Output
  "payload": 50,
  "scale": {
    "input": 12,
    "output": 50,
    "inMin": 4,
    "inMax": 20,
    "outMin": 0,
    "outMax": 100,
    "clamped": false,
    "decimals": 2
Use Cases
Application Description
4-20mA Sensor signal to percentage
0-10V Analog signal to engineering units
Inverted Reverse valve position (100%=closed)
Temperature Celsius to Fahrenheit
Node Status
  • 12 → 50.00 - Scaled value
  • 22 → 100.00 (clamped) - Output was clamped
  • Invalid range - inMin equals inMax
Author
sr.rpo
MIT
Version: 1.0.0
Updated 8 months ago
140 in the last week
  • scale
  • scale
  • map
  • range
  • linear
  • interpolation
  • 4-20mA
  • 0-10V
