node-red-contrib-scalar-docs 1.1.1
Serve a Scalar API documentation UI for all http-in nodes in Node-RED flows
npm install node-red-contrib-scalar-docs
npm version npm downloads Node.js ≥16 Node-RED ≥3 License: MIT
If you'd like to support me, Ko-fi
Auto-generates and serves a Scalar API documentation UI for all http in nodes in your Node-RED flows.
  • Auto-discovery of all http in nodes across all flows
  • Per-endpoint metadata: summary, description, tags, parameters, request body, response schemas
  • Built-in system endpoints served under /api/scalar/ (/api/scalar/health, /api/scalar/ping, etc.), each individually toggleable
  • Modern interactive UI with multiple Scalar themes
  • Optional Bearer token to protect the docs and the OpenAPI spec
  • Inline button in every http in editor to jump directly to the endpoint config
Requirements
Dependency Version
Node.js >=16
Node-RED >=3.0.0
express >=4.0.0 (already bundled with Node-RED)
@scalar/api-reference >=1.0.0 (bundled — fallback to CDN if missing)
Restart Node-RED after installation.
Quick Start
  1. Open the Node-RED editor
  2. Go to Menu > Configuration nodes and add a new scalar-docs node, or open any http in node and use the Scalar Docs row to create one
  3. Set a UI Path (default: /api-docs) and enable the routes you need
  4. Deploy
  5. Open http://localhost:1880/api-docs
General
Field Default Description
Title Node-RED API API title shown in the UI
Version 1.0.0 API version string
Description — Markdown-supported description
UI Path /api-docs Path where the Scalar UI is served
Base URL — Server base URL written into the OpenAPI spec
Theme default Scalar UI theme
Bearer Token — If set, protects both the UI and the /openapi.json endpoint
Endpoints tab
Lists all http in nodes found in flows. Each entry can be:
  • Excluded from the documentation
  • Expanded to edit: summary, description (Markdown), tags, deprecated flag, parameters (query/path/header/cookie), request body (content-type + JSON Schema), response definitions (status code + description + JSON Schema)
The Cleanup orphans button removes saved configs for nodes that no longer exist in the flow.
Default Routes tab
Toggle built-in diagnostic endpoints individually or use the preset buttons to enable groups.
All default endpoints are served under the /api/scalar root (e.g. /api/scalar/health) to keep the main application root free. The prefix can be changed with the defaultRoutesPrefix option (default: /api/scalar).
Base
Endpoint Description
GET /api/scalar/ping Returns pong — minimal liveness check
GET /api/scalar/health Status, uptime and current timestamp
GET /api/scalar/health/live Liveness probe, always 200 if the process is alive
GET /api/scalar/health/ready Readiness probe, returns 200 only after flows have been deployed
GET /api/scalar/info Node-RED version, Node.js version, OS, hostname, uptime and flow count
Runtime
GET /api/scalar/metrics CPU usage, memory, V8 heap and event loop stats
GET /api/scalar/env Environment variables filtered by a configurable whitelist (NR_* by default)
GET /api/scalar/context Node-RED global context, filtered by a configurable whitelist
Flow Debug
GET /api/scalar/flows Active flows with their ID and label
GET /api/scalar/flows/count Total flow count and node breakdown by type
GET /api/scalar/nodes All installed node type names
GET /api/scalar/nodes/http All http in nodes currently detected in flows
Diagnostics
GET /api/scalar/diagnostics Single aggregated response combining health, metrics and info
GET /api/scalar/logs Last N log entries from the in-memory ring buffer (?limit=100)
GET /api/scalar/logs/errors Same as /api/scalar/logs but filtered to error-level entries only
Dev Tools
POST /api/scalar/echo Returns the received request body — useful for testing HTTP clients
GET /api/scalar/auth/test Verifies the configured Bearer token and returns its validity
GET /api/scalar/dependencies Lists installed npm packages with their current versions
GET /api/scalar/dependencies/outdated Runs npm outdated and returns packages that have available updates
http-in integration
When editing any http in node, a Scalar Docs row is added to the form. Use it to:
  • Select or create a scalar-docs config node to associate with the endpoint
  • Click the pencil icon to open the config and jump directly to the Endpoints tab
  • Click the + icon to create a new scalar-docs config node
The association is saved on the http in node and the scalar-docs label shows the number of linked endpoints.
Example Flow
An importable example is available in examples/example-flow.json.
It contains a scalar-docs config node and three working endpoints:
Method Path Description
GET /api/users Returns a mock list of users (supports ?limit=N)
GET /api/users/:id Returns a single user or 404
POST /api/users Creates a user (requires name and email)
Base diagnostic routes (/api/scalar/ping, /health, /info) and the POST /api/scalar/echo endpoint are also enabled.
How to import:
  1. In Node-RED open Menu (☰) > Import
  2. Paste the contents of example-flow.json or upload the file directly
  3. Click Import, place the nodes, then Deploy
  4. Open http://localhost:1880/api-docs
OpenAPI spec
Available at <UI Path>/openapi.json. The spec is regenerated on every request from the live flow state. Path parameters using :param syntax are auto-detected and merged with any manually defined parameters.
Security
  • /env exposes only variables prefixed with NR_ or NODE_RED_ unless an explicit whitelist is configured
  • /context exposes nothing without a whitelist
  • Set a Bearer token in the General settings to restrict documentation access in production
MIT
Version: 1.1.1
Updated 6 months, 3 weeks ago
601 in the last week
  • scalar-docs
  • scalar
  • openapi
  • swagger
  • api-docs
  • documentation
