node-red-contrib-sax1johno-function-npm 0.4.1
A function node for Node-RED with npm load capabilities. This version is regularly updated.
npm install node-red-contrib-sax1johno-function-npm
node-red-contrib-function-npm
Node red function node with capability to install and use packages from npm
From your node-red directory
npm install node-red-contrib-function-npm
The function-npm node behaves like a normal function node, with the exception of allowing the use of npm modules within the script inside the block. It scans the script for any require statements and downloads the modules specified in the require statements. The module is automatically cleaned from the disk when the node-red process closes.
//syntax to install a specific version
var lowerCase = require('[email protected]')
//if no version specified the latest version is installed
var upperCase = require('upper-case');
msg.payload = {
    upper: upperCase('Hello World'),
    lower: lowerCase('Hello World')
Project Info
URLs
Name Link
Github Repo https://github.com/ntsaini/node-red-contrib-function-npm
NPM Package https://www.npmjs.com/package/node-red-contrib-function-npm
Contributions
If you'd like to contribute to this project, feel invited to commit to this repository!
This work is licensed under the Apache License, Version 2.0.
Credits
Project : node-red-contrib-npm (https://github.com/jthomas/node-red-contrib-npm)
License : MIT License
Author  : James Thomas
For providing the inspiration of the idea and code for installing npm packages dynamically
Project : node-red (https://github.com/node-red/node-red/blob/master/nodes/core/core/80-function.js)
License : Apache License 2.0
Author  : Node-RED team
For the base function node code.
Project : parse-package-name (https://github.com/egoist/parse-package-name)
Author  : Egoist
For package name parsing regex
Version: 0.4.1
Updated 7 years, 5 months ago
11 in the last week
  • function-npm
  • function-npm
