node-red-contrib-saprfc 1.2.3
A node-red node wrapper for node-rfc (SAP Net Weaver Remote Function Call SDK Client).
npm install node-red-contrib-saprfc
Currently in Beta state.
Node-Red (http://nodered.org) nodes for communicating with SAP via node-rfc (https://github.com/SAP/node-rfc).
There are three nodes included:
  • call - used to make a remote function or BAPI call.
  • read table - query a table. a wrapper for RFC_READ_TABLE which allows you to query a table with conditions and returns parsed rows.
  • field list - gets the field list of a table. This is a wrapper for RFC_READ_TABLE which only gets the field list.
Woah cowboy...
This package is a wrapper for node-rfc, which relies on the SAP NW RFC SDK. Make sure you have a working install of node-rfc before continuing.
Okay, I have a working node-rfc install
Run the following command after you have done a global install of Node-RED & node-rfc
npm install -g node-red-contrib-saprfc
You will need the connection parameters for your SAP system, which can usually be obtained from your SAP GUI Logon.
These nodes will appear in their own "sapRFC" catagory on the Node-Red pallet.
Config
After adding the first node, you have to configure the connection to your SAP system.
This node sets up a node-rfc connection pool and an async queue which limits the amount of simultaneous connections to 4. In testing, there does not seem to be a performance gain for using more than 4 connections. The queue is processed first in first out.
Field List
The field list node is the easiest to use. It is a wrapper around RFC_READ_TABLE - you only need to enter the table name for which you would like to get the list of fields and wire it to a debug node to inspect the output.
Use the condense flag to convert the standard output from the RFC to a simple object where each property is the technical name of the table and it's value is the display name.
Read Table
The read table node is a wrapper around RFC_READ_TABLE. It converts the result into a native Array of JS Objects, each representing one result row.
To use the node, enter the table name and click the Fetch Fields button to get all the fields of the table. Then select the fields you wish to include in the output. You will also want to use a function node pass a structure with additional parameters, such as ROWCOUNT, OPTIONS, etc. Here is an example function node which builds the import structure:
var date = new Date();
msg.payload = {
  OPTIONS: ["ERSDA >= '"+date.getFullYear()+""+("0" + (date.getMonth() - 2)).slice(-2)+""+("0" + date.getDate()).slice(-2)+"'"],
  ROWCOUNT: 10
You could also specify the table and field list in the input payload instead of configuring them in the GUI:
msg.payload = {
  QUERY_TABLE: "MARA",
  FIELDS: ["MATNR","ERSDA","ERNAM"],
  ROWCOUNT: 10
Call
The call node allows you to call any SAP RFC you would like. Just like the read table node, you must use a function node to build and pass the import parameters.
This example shows how you would build an import structure for BAPI_USER_CHANGE to update a user's email address:
msg.payload = {
  USERNAME: "SOME_SAP_USER",
  ADDRESS: {
    E_MAIL: "[email protected]"
  ADDRESSX: {
    E_MAIL: "X"
Catching Errors
If an error is encountered by any RFC, an error is throw. In order to see the full content of this error, drag a catch node into your flow and attach it to a debug node. The debug node must be configured to output msg.sapError.
Disclaimer
Use these programs at your own risk.
Author
Paul Wieland, https://github.com/PaulWieland
Feedback and Support
Submit any issues here on github, or ping me @Paul W on the node-red slack channel.
Version: 1.2.3
Rating: 3.0 2
35 in the last week
  • saprfc-config
  • call
  • read table
  • field list
  • sap
  • saprfc
  • node-rfc
