node-red-contrib-sap-odata 0.1.1
Node-RED nodes for SAP Gateway OData V2 / V4: CRUD, function imports, actions, $batch, $metadata, catalog, CSRF and ETag handling
npm install node-red-contrib-sap-odata
ASSERT
ci
Node-RED nodes for SAP Gateway OData V2 and V4 (S/4HANA on-premise and Cloud, ECC with Gateway, BTP ABAP environment, SAP BTP destinations).
Maintained by atlas, a self-evolving agent project run by Alex Adamopoulos at assert.gr.
Unofficial. This is an independent open-source project. It is not affiliated with, endorsed or supported by SAP SE. SAP, S/4HANA, SAP HANA, SAP BTP and other SAP product names are trademarks or registered trademarks of SAP SE in Germany and other countries; they are used here only to say which systems the nodes work with.
  • One sap-odata node for everything: query, read, $count, create, update, delete, function imports, actions (bound and unbound), $batch, $metadata, service catalog and raw requests ($value media, $links, …)
  • Automatic X-CSRF-Token handling bound to the SAP session cookies, with a single refresh on 403 X-CSRF-Token: Required
  • ETag / If-Match for update, delete and bound actions (from msg.etag, the payload, or by reading the entity first)
  • Key and parameter literals typed from $metadata (guid'…', datetime'…', 12.5M, 1L, V4 bare literals, enums …)
  • SAP business messages (sap-message, sap-messages, RAP SAP__Messages) in msg.odata.messages
  • Auth: Basic, OAuth 2.0 (client credentials, password, SAML 2.0 bearer, JWT bearer, refresh tokens), X.509 (PEM or PFX), Kerberos / SPNEGO, SAP BTP destinations (Cloud Connector), Bearer, API Key
  • HTTP(S) proxies: manual or HTTPS_PROXY/NO_PROXY, authentication Basic, NTLMv2 or Kerberos
  • Streaming upload/download of media resources, gzip/deflate/br, custom CA, editor dropdowns for services and entity sets
npm install /path/to/node-red-sap      # or from npm once published
Requires Node.js ≥ 22 and Node-RED 4 or 5 (both tested in CI; Node-RED 5 needs Node.js ≥ 22.9). Two optional packages are needed only for the features that use them:
Feature Install in the Node-RED user directory
Kerberos / SPNEGO (to SAP or to the proxy) npm install kerberos (native; Windows SSPI, GSSAPI elsewhere)
SAP BTP destinations / Connectivity (Cloud Connector) npm install @sap-cloud-sdk/connectivity
sap-connection (config)
Field Meaning
Auth Basic · OAuth 2.0 · X.509 client certificate · Kerberos / SPNEGO · SAP BTP destination · Bearer · API Key (APIKey header, api.sap.com sandbox) · None
Host URL https://host:port only; service paths go on the sap-odata node (not used with a BTP destination)
SAP client / Language sent as sap-client / sap-language on every request
OAuth 2.0 grant (client credentials, resource owner password, SAML 2.0 bearer assertion RFC 7522, JWT bearer RFC 7523), token URL, client id/secret, client authentication (Basic header, body, or client id only for mTLS), scope, assertion. A refresh_token is used when the access token expires
X.509 PEM certificate + key, or PFX/P12 (base64) + passphrase
Kerberos uses the Kerberos credentials of the Node-RED process; SPN defaults to HTTP/<host> (Windows) or HTTP@<host>
BTP destination destination name, optional user JWT (principal propagation). URL, authentication, sap-client, client certificates and the Connectivity proxy with the Cloud Connector location id come from the destination (SAP Cloud SDK)
Proxy none · from environment (HTTPS_PROXY, HTTP_PROXY, ALL_PROXY, NO_PROXY) · manual URL; No proxy for accepts host names (sub domains included), .suffix, wildcards, host:port, IPv4/IPv6 CIDR. Authentication: none / Basic / NTLM (user DOMAIN\user or user@domain) / Kerberos
CA (PEM), Verify certificate for self-signed SAP or proxy certificates
One connection = one SAP session. Session cookies, the CSRF token, the OAuth token, the resolved destination and parsed $metadata are shared by all nodes using it.
sap-odata
Service: a V2 name (API_BUSINESS_PARTNER, ZMY_SRV;v=0002 → /sap/opu/odata/sap/…) or a full path (/sap/opu/odata4/sap/<group>/srvd_a2x/sap/<service>/0001). The OData version is detected from the path (/odata4/ → V4) or set explicitly.
Operation HTTP Notes
query GET /Set $filter $select $expand $orderby $top $skip, search, inline count, custom options; optional "follow next links"
get GET /Set(key)[/nav]
count GET /Set/$count only $filter and search are sent
create POST /Set deep insert = nested JSON in msg.payload
update V2 MERGE, V4 PATCH (or PUT) If-Match handling; optional MERGE tunnelling via POST + X-HTTP-Method
delete DELETE /Set(key) If-Match handling
function V2 function import: GET|POST /Name?P='x' · V4 function: GET /Name(P='x') · V4 action: POST /Name + JSON HTTP method and parameter types from $metadata; bound operations via "Bound to" (Product('1')), bound actions sent with If-Match
batch POST /$batch multipart/mixed (V2 and V4) or OData 4.01 JSON (V4); consecutive writes in one atomic change set (configurable)
metadata GET /$metadata parsed model in msg.payload, XML in msg.metadataXml
catalog Gateway V2 + V4 catalog list of services
request any msg.method, msg.path (relative to the service or /sap/…); msg.uploadFile / msg.downloadFile stream a file; binary answers as a Buffer
Input (overrides node settings)
msg.operation, msg.service, msg.entitySet, msg.key ("1000", {SalesOrder:"1",SalesOrderItem:"10"}, or raw "SalesOrder='1'"), msg.navigation, msg.query ({filter, select, expand, orderby, top, skip, search, count, …custom}), msg.payload (body / function parameters / batch list), msg.params, msg.etag, msg.headers, msg.fetchAll, msg.functionName, msg.bindingPath, msg.method, msg.path, msg.uploadFile, msg.downloadFile, msg.atomic, msg.batchFormat, msg.odataVersion, msg.refresh.
Output
  • msg.payload – entity, array, number, function result, Buffer, {file, bytes} for a download, or for batch [{status, ok, headers, body, data, messages}] in request order (a failed change set's error is repeated for each of its requests)
  • msg.odata – {operation, version, service, statusCode, count, nextLink, etag, location, url, messages, …}; messages are SAP's business messages (info, warnings) of a successful call
Errors go to a catch node; msg.error = {message, statusCode, code, details[], url, method} taken from the SAP error body (V2 error.message.value + innererror.errordetails, V4 error.message + details, or XML).
$batch example
msg.payload = [
  { entitySet: "A_BusinessPartner", query: { top: 1 } },                    // GET
  { method: "POST",  entitySet: "A_BusinessPartner", body: { /* … */ } },   // ┐ one
  { method: "MERGE", entitySet: "A_BusinessPartner", key: "11",             // │ change
    body: { /* … */ }, headers: { "If-Match": "*" } },                      // ┘ set
  { method: "GET", url: "A_BusinessPartner('11')/to_BusinessPartnerAddress" }
A changeset: "<label>" property on a request groups requests explicitly; dependsOn is passed on in the JSON format.
Protocol rules implemented
Rule Source
V2 literals: 'str' (quotes doubled), guid'…', datetime'yyyy-mm-ddThh:mm[:ss]', datetimeoffset'…', time'PT…', 1L, 1.5M, 1.5d, 1.5f, X'…' OData 2.0 URI conventions §6
V4 literals: bare Guid / DateTimeOffset / Date / TimeOfDay / numbers, duration'…', binary'…', Ns.Enum'Member' OData 4.0 ABNF
V2 partial update = MERGE, V4 = PATCH; PUT = full replace OData 2.0 / 4.0 protocol
V2 $inlinecount=allpages + __count, __next; V4 $count=true + @odata.count, @odata.nextLink OData 2.0 / 4.0
V2 has no $search: search is sent as SAP custom query option; V4 uses $search SAP Gateway
V2 function import parameters in the query string; V4 function parameters in the path; V4 action parameters as JSON body OData 2.0 / 4.0
An action bound to an entity with an ETag is sent with If-Match OData 4.01 §11.5.4.1, enforced by SAP RAP
$batch multipart/mixed, application/http parts, Content-Transfer-Encoding: binary, Content-ID in change sets, GETs never inside change sets; JSON batch with atomicityGroup and dependsOn OData 2.0 §2.2.7.6 / 4.0 §11.7 / 4.01 JSON §19
CSRF: GET with X-CSRF-Token: Fetch, token sent with the same session cookies, refresh once on 403 + X-CSRF-Token: Required SAP Gateway
Request target sent verbatim (no re-encoding of ' to %27)
A response to HEAD has no body whatever its Content-Length (proxy NTLM handshake) RFC 9110 §9.3.2
V2 /Date(ms)/ → ISO 8601 (optional) SAP JSON format
Verified against SAP
The live tests run the node in a Node-RED runtime against real systems:
  • npm run test:trial – a local ABAP Cloud Developer Trial (ABAP Platform 2025), 21 checks, writes included: V2 GWSAMPLE_BASIC create, read with typed key and ETag, $filter + $inlinecount, MERGE with ETag read automatically, a stale ETag rejected (412), an expired CSRF token refreshed, a function import (POST), errors parsed; V2 API_TRAVEL_U_V2 $batch with an atomic change set; V4 /DMO/TRAVEL_U create, PATCH with @odata.etag, bound action (If-Match), multipart $batch, delete.
  • npm run test:live – read-only against sandbox.api.sap.com (S/4HANA Cloud API_BUSINESS_PARTNER V2, API_PRODUCT V4), including gzip answers and composite keys.
Found on the way and handled: SAP's ABAP Gateway does not support the JSON $batch format (415 on ABAP Platform 2025, any headers) – the node says to use multipart; JSON batch remains for other OData V4 servers such as SAP CAP. GWSAMPLE_BASIC answers every change set with "Missing response data in changeset deferred processing mode" – a limitation of that demo service, not of the request.
Kerberos, NTLM proxies and BTP destinations are covered by the unit tests (NTLMv2 checked cryptographically by the mock proxy, the destination through a mock of the SAP Cloud SDK), not by a live system.
Tests
npm test             # unit + Node-RED runtime tests (CI: Node 22, 24 and 26, each with Node-RED 4 and 5; see .github/workflows/ci.yml)
npm run test:ci      # the same, and coverage/lcov.info written in the same run against a mock SAP Gateway and mock proxies, 100 % line/branch/function coverage enforced
npm run test:trial   # live, writes: local ABAP trial (SAP_URL, SAP_USER, SAP_PASSWORD or sap-trial-credentials.txt)
npm run test:live    # live, read-only: sandbox.api.sap.com (SAP_SANDBOX_API_KEY or sap-api-key-sandbox.txt)
npm run coverage:lcov && npm run coverage:report   # what is not covered, with its source line
The credential files are git-ignored.
Sandbox systems
  • SAP Business Accelerator Hub – https://api.sap.com → log in → Show API Key. Base URL https://sandbox.api.sap.com, service e.g. /s4hanacloud/sap/opu/odata/sap/API_BUSINESS_PARTNER, Auth = API Key. Read-only.
  • ABAP Cloud Developer Trial – a complete ABAP system in Docker (sapse/abap-cloud-developer-trial), with the EPM (GWSAMPLE_BASIC, SEPMRA_*) and Flight/Travel (/DMO/) demo services; its demo license lasts three months (renew with a minisap key for system A4H). The Flight/Travel data is regenerated with the class /DMO/CL_FLIGHT_DATA_GENERATOR (run it from ADT).
  • SAP BTP ABAP environment (trial / free tier) – your own RAP services with write access.
  • (The former SAP Gateway demo system ES5 was decommissioned in 2025.)
Limitations
  • $batch answers and non-streamed bodies are held in memory; use msg.downloadFile for large media
  • Browser-based SAML 2.0 single sign-on (redirect to an IdP login page) cannot work for unattended flows; use the OAuth 2.0 SAML bearer grant, X.509 or Kerberos instead
  • NTLM is supported for proxies (SAP's ICM does not offer NTLM)
Example flow: examples/sandbox-business-partner.json (Import → Examples in Node-RED).
About the maintainer
Alex Adamopoulos is the founder of assert.gr - Empowering the Physical World with Intelligence - and the engineer behind the atlas self-evolving AI agent platform, which co-authors this project. Connecting Node-RED to SAP is part of the same work: putting plant-floor and edge automation in reach of the business systems that run alongside it.
Connect:
Version: 0.1.1
Updated 4 days ago
Rating: 5.0 2
  • sap-connection
  • sap-odata
  • sap
  • odata
  • s4hana
  • gateway
  • btp
  • proxy
  • ntlm
  • kerberos
  • oauth2
