node-red-contrib-sap-hana 1.2.4
Node-RED node to access SAP HANA database
npm install node-red-contrib-sap-hana
Node-RED nodes to work with a SAP HANA database
Change Log
v1.2.3 - Split the node in separate files & readme updates
v1.2.2 - Bugfix : removed node type that is not used
v1.2.1
  • Feature added : New node type table_insert for inserts receiving an array of objects (from http-in node)
  • BIG CHANGE/INCOMPATIBILITY : Node type names have changed/simplified and may be found in different group sap hana now.
v1.1.1 - Feature added : New node type saphanatablemonitor with configurable interval and query that may be used to monitor when #no-of-records in a table is changing
v1.0.5 & v1.0.6- Readme update : User has to be SCHEMA OWNER or to have HDI ADMIN user priviledges (not the users seen in XSA Environment *_RT, *_DT)
v1.0.4 - Readme fix
v1.0.2 - Feature added : Insert in msg.payload an Array of sql script commands (Example flows updated also)
v1.0.1 - INSERT, UPDATE, DELETE and other SQL script sql commands work
Install from npm or install from Manage Pallete in Node-RED
cd $HOME/.node-red/
Do not forget to edit /etc/hosts for default hxehost replacing X.Y or whole IP address if you're using hxehost as hostname
192.168.X.Y hxehost
This package contains one node to run a sql command, call a procedure or a select statement for SAP HANA database using the office @sap/hana-client Node.JS driver.
Example flows here :
  1. sap_hana_config node
Create a new SAP HANA user from SAP Hana Studio and you'll get a schema with the same name created by the system.
Use this new user and all the content will be saved in his schema as he's the owner.
Node config parameters :
  • Database host name
  • Database host port
  • User name to access the database
  • Password for the user name above
  1. run_query node
To run a command or a query input to saphana node the folowing message :
msg.topic = "SQL"; // or lower case 'sql'
msg.payload = "SELECT * FROM DUMMY";
Also it works with an array of queries
msg.payload = [
	'SELECT * FROM DUMMY',
	'INDERT INTO "table_name" ("col1", "col2") VALUES (\'val1\', \'val2\')'
The returned data will be stored in msg.payload and it will contain the @sap/hana-client response.
As an OK response you'll receive on the run_query response:
	topic : "RESULT_IN_PAYLOAD",
	payload : [{"DUMMY":"X"}];
Error response example :
	topic : "ERROR",
	payload : {
  1. table_monitor node
  • query to run at each iteration with setInterval function
  • interval delay time (in seconds)
At each interval Error response example :
	"topic":"RESPONSE_IN_PAYLOAD",
	"payload":{
		"lastCount":1,
		"newCount":1,
		"trigger":false
  1. table_insert node
For input : forward from an http-in node or from another node type an array of objects
  • Table Name
  • Columns (property names from the js objects found in array) to be used in the SQL INSERt query
Other Informations
Currently, only SAP HANA Express has been tested.
Please let me know if you have any issue.
Authors
Version: 1.2.4
Updated 5 years, 9 months ago
License: Apache
Rating: 5.0 2
34 in the last week
  • sap_hana_config
  • run_query
  • table_monitor
  • table_insert
  • sap
  • sap-hana
  • hana
  • Radu Simen
