node-red-contrib-samsung-smartthings 1.0.0
Node-RED nodes for Samsung SmartThings device control and automation via the SmartThings REST API
npm install node-red-contrib-samsung-smartthings
Professional Node-RED nodes for Samsung SmartThings device control and automation.
This package provides a complete set of nodes to interact with the SmartThings REST API, enabling you to manage locations, rooms, devices, scenes, and execute device commands directly from Node-RED flows.
  • Full SmartThings API coverage — Locations, Rooms, Devices, Status, Commands, Scenes, and Events
  • Real-time event monitoring — Polling-based change detection that outputs messages only when device values change
  • Dynamic & static configuration — Use editor dropdowns for quick setup, or override any parameter via msg properties at runtime
  • Shared configuration — A single config node securely stores your API token and is shared across all SmartThings nodes
  • Energy monitoring — Read energy and power meter data from compatible devices
  • Cascading dropdowns — Device, capability, and command selectors populate dynamically based on your SmartThings account
  • Professional error handling — Rate limiting, retry logic, and visual node status indicators
Install via the Node-RED Palette Manager, or run:
Prerequisites
You need a SmartThings Personal Access Token (PAT) for authentication:
  1. Navigate to https://account.smartthings.com/tokens
  2. Sign in with your Samsung account
  3. Generate a new token with the required scopes (Devices, Locations, Scenes)
  4. Copy the token — you will need it for the configuration node
Note: For production integrations, use OAuth 2.0. PATs are intended for testing and personal use.
Node Description
smartthings-config Configuration node — stores API token and base URL (shared by all nodes)
smartthings-locations Retrieve SmartThings locations
smartthings-rooms Retrieve rooms within a location
smartthings-devices List and filter devices by location, room, or capability
smartthings-status Get device status including energy/power meter readings
smartthings-command Execute commands on devices (switch, dim, color, lock, etc.)
smartthings-scenes List and execute SmartThings scenes
smartthings-events Monitor device changes in real-time via intelligent polling
Quick Start
  1. Drag a smartthings-devices node onto your flow
  2. Double-click and create a new SmartThings Config — enter your API token
  3. Select a location filter (optional) and deploy
  4. Connect an inject node to trigger it and a debug node to see the output
  5. Deploy and click the inject button to retrieve your devices
Dynamic Usage
Every node supports dynamic override via msg properties. Static dropdown values serve as defaults; msg values always take priority.
Example: Dynamic device command
    "deviceId": "xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx",
    "component": "main",
    "capability": "switch",
    "command": "on",
    "arguments": []
Send this as the msg object to a smartthings-command node (with no static configuration) and it will execute the command dynamically.
Event Monitoring
The smartthings-events node monitors a device and outputs a message only when its status changes. This provides a subscription-like experience using intelligent polling.
Setup:
  1. Select a device, optionally filter by component/capability
  2. Set the polling interval (default: 10 seconds)
  3. Connect to a debug node or downstream flow
Dynamic control via input:
    "action": "start",
    "deviceId": "your-device-id",
    "capability": "energyMeter",
    "interval": 5
Send { "action": "stop" } to pause monitoring.
API Reference
This package communicates with the SmartThings REST API v1:
Apache-2.0 — Copyright 2026 Layer-IT
Version: 1.0.0
Updated 8 months, 3 weeks ago
80 in the last week
  • smartthings-config
  • smartthings-locations
  • smartthings-rooms
  • smartthings-devices
  • smartthings-status
  • smartthings-command
  • smartthings-scenes
  • smartthings-events
  • smartthings
  • samsung
  • iot
  • home-automation
  • smart-home
  • devices
  • energy
