node-red-contrib-salus-control 1.0.5
Manage and control a salus-it500 device.
npm install node-red-contrib-salus-control
node-red-contrib-salus-it500
Custom node to use with a salus it-500.
Example
This custom node provides the following nodes:
  • obtain a valid token and device ID
  • set temperature
  • get current temperature info
  • set auto / off
The token and device ID are used in the set & get which basically means that it's required.
There are also flow context variables you can use to get the values found by these nodes. These are:
  • setTemp
  • currentTemp
  • auto - gets the auto status of the thermostat
  • heatStatus - gets the status of whether the thermostat has triggered the heating system
Version: 1.0.5
Updated 4 years, 2 months ago
9 in the last week
  • Retrieve ID and Token
  • Set temperature
  • Current temperature
  • Set Auto
  • Heat Status
  • salus
  • it500
