node-red-contrib-salesforce-chatter 1.0.6
A processing node of Node-RED nodes for Salesforce Chatter.
npm install node-red-contrib-salesforce-chatter
NPM
Pre-requisites
The node-red-contrib-salesforce-chatter requires Node-RED to be installed.
Restart your Node-RED instance, the force node appears in the palette and ready for use.
Overview
node-red-contrib-salesforce-chatter contains the following modules.
force chatter content node
Post a message to Chatter. The message to be posted is set in msg.payload using the following structure:
msg.payload = [
            text: "This is the message 1",
            mention: "[email protected]"//email to mention
            text: "Message 2 without mentioning"
You can also post image which is set in msg.binaryBuffer and msg.filename (include image extension).
Tip: For more information on connected apps, see Create a Connected App in the Salesforce Help.
Acknowledgements
The node-red-contrib-salesforce-chatter uses the following open source software:
Version: 1.0.6
Updated 6 years, 6 months ago
9 in the last week
  • salesforce
  • force-chatter content
  • chatter
  • salesforce
