node-red-contrib-sails 0.0.2
Node Red client to work with sails server
npm install node-red-contrib-sails
A Node-RED node to send data to a sails.js server, using the sails.io.js library.
Either use the Menu - Palette Manager - Install, or run the following command in your Node-RED user directory - typically ~/.node-red
    npm i --save node-red-contrib-sails
If Path is not specified the required sails url path should be set by using msg.topic.
msg.payload should contain the data you wish to send.
The default method is post, but you can override this using msg.method.
Sails accepts get, post, put, delete and patch.
You may also set headers by using msg.headers if required.
Version: 0.0.2
Updated 9 years, 5 months ago
2 in the last week
  • sails-config
  • sails-out
  • sails
