node-red-contrib-saia-sbus 1.0.0
Node-RED nodes for SAIA PCD EtherSBus communication (Flags, Registers, Inputs, Outputs)
npm install node-red-contrib-saia-sbus
Node-RED nodes for communicating with SAIA PCD controllers via the EtherSBus protocol (UDP port 5050).
Based on protocol reverse-engineering.
Via the Node-RED Palette Manager (recommended): Menu → Manage palette → Install → search for node-red-contrib-saia-sbus.
Via npm, from your Node-RED user directory (usually ~/.node-red):
Then restart Node-RED.
Requirements: Node-RED >= 2.0, Node.js >= 14.
All nodes appear in the SAIA SBus palette category.
🔧 saia-config (Configuration)
Shared connection configuration - reused across all other nodes.
Setting Default Description
Host / IP 192.168.1.100 IP address of the SAIA PCD
UDP Port 5050 EtherSBus port (almost always 5050)
Station 1 SBus station address (0–253)
Timeout 2000 ms Response timeout per request
Important: EtherSBus must be enabled on your PCD (PG5 → Hardware Settings → Ethernet → EtherSBus).
📥 saia-read
Reads one or more items from the PCD. Triggered by any incoming message.
Configure in node:
  • Item Type: flag | input | output | register
  • Address: start address
  • Count: number of items (returns array if > 1)
  • Topic: MQTT-style topic string (auto-generated if blank)
Override per message:
msg.itemType = "register"; // override item type
msg.address = 50; // override address
msg.count = 4; // override count
Output:
msg.payload; // value or array of values
msg.itemType; // 'register'
msg.address; // 50
msg.topic; // 'saia/register/50'
📤 saia-write
Writes one or more items to the PCD.
Input:
msg.payload = 42; // single write
msg.payload = [1, 2, 3]; // multi write (array)
msg.payload = true; // flag/output (boolean)
Notes:
  • Inputs are read-only and cannot be written
  • Registers accept 32-bit signed integers
  • Flags/Outputs accept booleans (packed as bits on the wire)
🔄 saia-poll
Cyclically polls a PCD item at a configurable interval and emits a message each time.
Interval 1000 ms Polling cycle time
Only Changes off When enabled, only emits on value change
An incoming message triggers an immediate extra poll (useful for manual refresh).
Output:
msg.timestamp; // Date.now() at time of read
msg.address; // 0
msg.topic; // 'saia/register/0'
Item Types & SAIA Notation
node-red-contrib type SAIA notation Read Write Data type
flag F ✓ ✓ boolean
input I ✓ ✗ boolean
output O ✓ ✓ boolean
register R ✓ ✓ int32
Example Flow
After installation the examples are available in Node-RED via Menu → Import → Examples → node-red-contrib-saia-sbus.
examples/saia-poll.json polls flag F100 every 500 ms (on change only) and registers R0..R4 every 2 s, with an inject node that triggers an immediate extra poll.
examples/saia-http-api.json exposes a small HTTP API on top of the SAIA nodes:
  • GET /saia/read?type=register&addr=0&count=1 – read items via saia-read
  • POST /saia/write with JSON body { "type", "addr", "value" } – write items via saia-write
SAIA PCD Configuration Tips
  1. Enable EtherSBus: PG5 → Hardware Settings → Ethernet → enable EtherSBus
  2. Use static addresses: Don't use dynamic addressing in PG5.
  3. Station address: Default is usually 1. Check your PCD hardware settings.
  4. Firewall: UDP port 5050 must be open between Node-RED host and PCD.
Protocol Notes
The current implementation is based on:
  • Wireshark decoding of real SAIA traffic
  • Live packet captures from working gateway requests and responses
Confirmed Request Layout
For a simple single-item read request, the wire format is:
Bytes 0-3:   Frame length in bytes (uint32 BE, includes CRC)
Byte 4:      Version
Byte 5:      Protocol type
Bytes 6-7:   Sequence number (uint16 BE)
Byte 8:      Telegram attribute / control (`0x00` for a request)
Byte 9:      Station address
Byte 10:     Command code
Byte 11:     Read count minus 1 (`0x00` for 1 item, `0x02` for 3 items)
Bytes 12-13: Base address (uint16 BE)
Bytes 14-15: CRC16/XMODEM
Example: read register 100 from station 50
00 00 00 10 00 00 01 d4 00 32 06 00 00 64 d1 90
Decoded:
  • Length: 0x00000010 = 16
  • Version: 0x00
  • Protocol type: 0x00
  • Sequence: 0x01d4
  • Attribute: 0x00
  • Station: 0x32 = 50
  • Command: 0x06 = read registers
  • Address: 0x000064 = 100
  • CRC16/XMODEM: 0xd190
Example: read 3 registers starting at 100
00 00 00 10 00 00 00 18 00 32 06 02 00 64 dc 5d
Decoded:
  • Version: 0x00
  • Sequence: 0x0018 = 24
  • Attribute: 0x00
  • R-count: 0x02 = 3 items
  • Base address: 0x0064 = 100
  • CRC16/XMODEM: 0xdc5d
Confirmed Response Layout
For the matching register response, Wireshark showed:
00 00 00 0f 00 00 00 01 01 00 00 03 ed c0 90
Decoded:
  • Length: 0x0000000f = 15
  • Version: 0x00
  • Sequence: 0x0001
  • Telegram attribute: 0x01 (response)
  • Data: 00 00 03 ed
  • CRC16/XMODEM: 0xc090
00 00 03 ed is the S-Bus 32-bit value 1005.
For a 3-register response, Wireshark showed:
00 00 00 17 00 00 00 01 01 00 00 00 01 00 00 00 15 00 00 11 c1 09 29
Decoded:
  • Length: 0x00000017 = 23
  • Version: 0x00
  • Sequence: 0x0001
  • Data[0]: 00 00 00 01 = 1
  • Data[1]: 00 00 00 15 = 21
  • Data[2]: 00 00 11 c1 = 4545
  • CRC16/XMODEM: 0x0929
Confirmed Write Register Request Layout
For a single register write request, Wireshark showed:
00 00 00 14 00 00 00 0d 00 32 0e 05 00 65 00 00 5f e7 82 a8
Decoded:
  • Length: 0x00000014 = 20
  • Version: 0x00
  • Sequence: 0x000d = 13
  • Telegram attribute: 0x00 (request)
  • Destination: 0x32 = 50
  • Command: 0x0e = write registers
  • W-count raw: 0x05
  • Base address: 0x0065 = 101
  • Data: 00 00 5f e7 = 24551
  • CRC16/XMODEM: 0x82a8
For register writes, the currently confirmed payload format is:
Byte 11:     W-count raw = 1 + 4 * number_of_values
Bytes 14..:  32-bit values (int32 BE)
For a multi-register write request, Wireshark showed:
00 00 00 20 00 00 00 01 00 32 0e 11 00 64 00 00 00 01 00 00 00 02 00 00 00 03 00 00 00 04 15 bf
Decoded:
  • Length: 0x00000020 = 32
  • Version: 0x00
  • Sequence: 0x0001
  • W-count raw: 0x11 = 17
  • Data[1]: 00 00 00 02 = 2
  • Data[2]: 00 00 00 03 = 3
  • Data[3]: 00 00 00 04 = 4
  • CRC16/XMODEM: 0x15bf
For a single flag write request, Wireshark showed:
00 00 00 12 00 00 00 01 00 32 0b 03 00 64 00 01 34 c5
Decoded:
  • Length: 0x00000012 = 18
  • Version: 0x00
  • Sequence: 0x0001
  • Command: 0x0b = write flags
  • W-count raw: 0x03
  • FIO / bit payload: 0x0001
  • CRC16/XMODEM: 0x34c5
For flag writes, the currently confirmed payload format is:
Byte 11:     W-count raw = 3 for a single flag write
Bytes 14-15: FIO / packed bit payload (uint16 BE)
For a multi-flag write request, Wireshark showed:
00 00 00 12 01 00 d2 ff 00 32 0b 03 00 64 04 0a f1 33
Decoded:
  • Version: 0x01
  • Sequence: 0xd2ff = 54015
  • W-count raw: 0x03
  • FIO count minus 1: 0x04 = 5 bits
  • Packed bits: 0x0a
  • CRC16/XMODEM: 0xf133
For multi-flag writes, the currently confirmed payload format is:
Byte 11:     W-count raw = 2 + number_of_data_bytes
Byte 14:     FIO count minus 1
Bytes 15..:  Packed bit payload
The same binary write payload structure is also confirmed for outputs. Wireshark showed this output write request:
00 00 00 14 00 00 00 01 00 32 0d 05 00 20 10 94 29 01 0b 62
Decoded:
  • Version: 0x00
  • Sequence: 0x0001
  • Command: 0x0d = write outputs
  • W-count raw: 0x05
  • Base address: 0x0020 = 32
  • FIO count minus 1: 0x10 = 17 bits
  • Packed bits: 94 29 01
  • CRC16/XMODEM: 0x0b62
Confirmed Write ACK Layout
For a successful write acknowledgment, Wireshark showed:
00 00 00 0d 00 00 00 01 02 00 00 4e b0
Decoded:
  • Length: 0x0000000d = 13
  • Version: 0x00
  • Sequence: 0x0001
  • Telegram attribute: 0x02 = ACK/NAK
  • ACK/NAK code: 0x0000 = ACK
  • CRC16/XMODEM: 0x4eb0
For a single flag response, Wireshark showed:
00 00 00 0c 00 00 00 01 01 00 56 6a
Decoded:
  • Length: 0x0000000c = 12
  • Version: 0x00
  • Sequence: 0x0001
  • Data: 00
  • CRC16/XMODEM: 0x566a
In this case, the returned flag value is false.
CRC
The checksum matches CRC16/XMODEM over the complete frame except the final 2 CRC bytes.
Example:
  • frame without CRC: 00 00 00 10 00 00 01 d4 00 32 06 00 00 64
  • CRC16/XMODEM: d1 90
Current Status Of This Repository
At the moment, the implementation in nodes/sbus-protocol.js is confirmed to work for:
  • single and multi-item reads for registers, flags, inputs and outputs
  • CRC validation on received frames
  • single and multi-item writes for registers, flags and outputs
  • automatic chunking of oversized reads (32 for 32-bit values, 128 for bit values)
  • automatic chunking of oversized writes (32 for 32-bit values, 256 for bit values)
Current limitations:
  • timer and counter write behavior still needs confirmation with captures
  • the exact multi-read request semantics are inferred from captures and should be validated with additional Wireshark traces
These notes should be treated as reverse-engineered findings, not official SAIA documentation.
MIT
Version: 1.0.0
Updated 2 days ago
  • saia-config
  • saia-read
  • saia-write
  • saia-poll
  • saia
  • sbus
  • ethersbus
  • pcd
  • plc
  • automation
  • hvac
  • building-automation
  • node-red-contrib
  • saia-burgess
  • sbus-udp
