node-red-contrib-s7-rust 1.4.0
Siemens S7 nodes for Node-RED: S7comm and S7CommPlus (S7-1200/1500 symbolic access) clients written in Rust, running in-process (Node-API). Linux x64.
Siemens S7 nodes for Node-RED. The two S7 protocols are written in Rust and run inside the Node-RED process as a Node-API addon:
- S7comm (classic, ISO-on-TCP port 102): S7-200, S7-300, S7-400, S7-1200, S7-1500, LOGO! 8. Absolute addresses, Siemens and nodes7 syntax.
- S7CommPlus (S7-1200/1500): symbolic access to optimized DBs and PLC tags
"DB_Data".speed,Motor_On), absolute I/Q/M/DB addresses, optional TLS 1.3 and password.
There is no external process, no compiler at install time and no runtime npm dependency. The package ships prebuilt binaries for Linux x64 (glibc and musl/Alpine).
This is the next generation of @oriolrius/node-red-contrib-s7.
[!TIP] Reviewers and contributors wanted. The goal is an S7 connector that covers the S7comm and S7CommPlus functions as close to 100% as possible, with every change reviewed by someone other than its author. A single maintainer cannot approve their own pull requests, so the OpenSSF Scorecard Code-Review score stays low. If you know Siemens S7, Rust or Node-RED, please review an open pull request or take a ❌ item of the protocol coverage map. See CONTRIBUTING.md. See Migration.
Contents
- Requirements
- Install
- Nodes
- Protocol coverage
- Prepare the PLC
- Addresses
- Values
- Examples
- Safety
- Performance
- Limits
- Migration from @oriolrius/node-red-contrib-s7
- Build from source
- License
Requirements
| OS / CPU | Linux x86-64 only: glibc ≥ 2.28 (Debian 10+, Ubuntu 20.04+, RHEL 8+) or musl (Alpine, the official nodered/node-red Docker image) |
| Node.js | ≥ 18 (Node-RED 5 needs ≥ 22.9) |
| Node-RED | ≥ 4.0 (tested on 4 and 5) |
Windows, macOS and ARM are not supported. npm refuses to install the package on them
(os and cpu fields).
In the Node-RED editor: Menu → Manage palette → Install, search
node-red-contrib-s7-rust.
Or on the command line, in your Node-RED user directory (usually ~/.node-red):
npm install node-red-contrib-s7-rust
Then restart Node-RED. The nodes are in the network category of the palette.
| Node | Function |
s7 endpoint (config) |
One PLC connection: protocol, host, port. S7comm: CPU family, rack/slot or TSAPs, PDU, gap, byte order. S7CommPlus: remote TSAP, TLS and the check of the PLC certificate, user, password (stored as a credential). |
s7 read |
Reads tags when a message arrives. Output: one value, {tag: value} or an array. |
s7 write |
Writes the tag of the node, the tag in msg.topic, or msg.payload = {tag: value, …} in one request. |
s7 watch |
Sends only the changes. Mode "read cyclically": a Rust thread reads the tags at an interval, with an optional conditional rate ("Fast while" a tag is true). Mode "PLC subscription" (S7CommPlus): the PLC sends the changes. |
s7 alarms |
S7CommPlus: a message when a PLC alarm comes or goes (alarm subscription; the active alarms at start). msg.ack acknowledges alarms. |
s7 info |
Diagnostics. Both protocols: status, cpuState. S7comm: identify, szl, szlList, clock, setClock, syncClock, blocks, listBlocks, blockInfo. S7CommPlus: info, certificate, dbs, browse, alarms, limits, resolve, links. |
s7 bsend |
Sends msg.payload as a block to a PLC BRCV (S7 connection, protocol "S7 partner"). Writes to the PLC. |
s7 brcv |
A message for each block of a PLC BSEND (S7 connection, protocol "S7 partner"). |
s7 usend |
Sends msg.payload (one to four areas) to a PLC URCV (S7 connection, protocol "S7 partner"); not acknowledged. Writes to the PLC. |
s7 urcv |
A message for each PLC USEND (S7 connection, protocol "S7 partner"). |
Every node has full help in the editor sidebar. Bad tags never stop the other tags: they give
null and an entry in msg.s7.errors, or msg.quality = "bad" in a watch.
The endpoint also adds two admin API routes for tools and the editor (Node-RED admin
authentication applies, permission s7rs-endpoint.read):
GET /s7rs/status/:endpointId: connection state, request count, errors, latency percentiles.GET /s7rs/call/:endpointId/:action: a read-onlys7 infoaction (for examplebrowse).
Protocol coverage
This map shows each protocol function and where it is available. It is strict: a function has ✅ only when a node uses it. The Rust tests run every ✅ and 🔒 function against the fake PLCs.
| Mark | Meaning |
| ✅ | Available in the nodes |
| 🔒 | In the Rust crate only. The nodes do not expose it (safety, or not needed) |
| ❌ | Not implemented |
S7comm (crate s7)
| Function | Protocol detail | Status | Node / action |
| ISO-on-TCP connection | TPKT (RFC 1006) + COTP CR/CC, TCP port 102 | ✅ | s7 endpoint |
| Rack/slot addressing | remote TSAP [link type, rack<<5 | slot], link type PG/OP/S7 basic |
✅ | s7 endpoint |
| Explicit TSAPs | local and remote TSAP (S7-200, LOGO! 8) | ✅ | s7 endpoint |
| Setup Communication | job 0xF0, PDU size negotiation | ✅ | s7 endpoint |
| Read Var | job 0x04, multi-item, split at the PDU size, near tags merged ("gap") | ✅ | s7 read, s7 watch |
| Write Var | job 0x05, multi-item, split at the PDU size | ✅ | s7 write |
| Memory areas | I (0x81), Q (0x82), M (0x83), DB (0x84), peripheral PI/PQ (0x80), T (0x1D), C (0x1C), V (= DB1) | ✅ | all |
| Read SZL | userdata group 4 (CPU functions), multi-part replies | ✅ | s7 info: szl, szlList, identify, cpuState |
| Read clock | userdata group 7 (time functions) | ✅ | s7 info: clock |
| Set clock | userdata group 7 (time functions) | ✅ | s7 info: setClock, syncClock (refused by the admin API) |
| List blocks | userdata group 3 (block functions): count per type, list of one type | ✅ | s7 info: blocks, listBlocks |
| Block info | userdata group 3 (block functions) | ✅ | s7 info: blockInfo |
| Block upload | jobs 0x1D, 0x1E, 0x1F | 🔒 | — |
| PLC STOP | job 0x29, PI service P_PROGRAM |
| PLC hot / cold start | job 0x28, PI service P_PROGRAM |
| Block download, delete | jobs 0x1A, 0x1B, 0x1C, PI service _DELE |
| Compress, copy RAM to ROM | PI services _GARB, _MODU |
| Cyclic data | userdata group 2 (an S7-1200/1500 answers 0x8104, not supported: S7-300/400 only) | ❌ | — (s7 watch uses polling; S7CommPlus: mode "PLC subscription") |
| Alarms and messages | userdata group 4 alarm subfunctions, NOTIFY, ALARM_S/ALARM_8 (an S7-1500 answers 0x8104: S7-300/400 only) | ❌ | — (S7-1500: s7 alarms over S7CommPlus) |
| Protection level password | userdata group 5 (security) (an S7-1500 answers 0x8104: S7-300/400 only) | ❌ | — (S7-1500: S7CommPlus legitimation) |
| Programmer commands, force | userdata group 1 | ❌ | — |
| BSEND/BRCV | userdata group 6 (type/group 0x46 / 0x86), fragments of the PDU size, blocks up to 65534 bytes, over an S7 connection (Node-RED active, TSAPs of the connection) | ✅ | s7 bsend, s7 brcv (endpoint protocol "S7 partner") |
| USEND/URCV | userdata with the R_ID in the parameters (syntax id 0x13), one to four areas in one PDU, not acknowledged, on the same S7 connection | ✅ | s7 usend, s7 urcv (endpoint protocol "S7 partner") |
| S7 routing to other subnets | COTP with routing parameters | ❌ | — |
S7CommPlus (crate s7plus)
| Connection | TPKT + COTP, remote TSAP SIMATIC-ROOT-HMI, protocol version 1 for the session creation, version 2 after it |
✅ | s7 endpoint |
| Session | CreateObject 0x04CA (ClientSession), session setup with SetMultiVariables, DeleteObject 0x04D4 at close | ✅ | s7 endpoint |
| TLS 1.3 | InitSsl 0x05B3, TLS inside COTP | ✅ | s7 endpoint (option "TLS") |
| PLC certificate verification | pinned SHA-256 fingerprint, or chain to a trusted certificate (the PLC certificate or the TIA project CA) with validity and name (IP address or DNS name) | ✅ | s7 endpoint (option "PLC certificate"), s7 info: certificate |
| Legitimation (access level password) | challenge from GetVarSubStreamed 0x0586, legacy and new response | ✅ | s7 endpoint (password) |
| Read | GetMultiVariables 0x054C, symbolic and absolute addresses | ✅ | s7 read, s7 watch |
| Write | SetMultiVariables 0x0542, symbolic and absolute addresses | ✅ | s7 write |
| Absolute areas | I, Q, M, DB, timers and counters | ✅ | all |
| Type information, DB list, browse | Explore 0x04BB, type info cache | ✅ | s7 info: dbs, browse; symbol resolution in all nodes |
| Symbol to absolute address | from the type information (non-optimized DBs) | ✅ | used inside the nodes |
| CPU operating state | read of the PLC program object | ✅ | s7 info: cpuState |
| Communication limits | read of the PLC limit attributes | ✅ | s7 info: limits, info |
| Active alarms | alarm objects and text libraries | ✅ | s7 info: alarms |
| Alarm subscription | CreateObject alarm subscription (TIA Portal or S7CommPlusDriver layout), DAI notifications | ✅ | s7 alarms |
| Alarm acknowledgement | CreateObject AckJob (class 3636) under the alarm subsystem, AcknowledgementList (dynamic array of struct 7604); the result comes back as an AckJob notification | ✅ | s7 alarms (msg.ack), s7 info: acknowledge |
| Variable subscription | CreateObject subscription with a cycle time, notifications, credit limit | ✅ | s7 watch (mode "PLC subscription") |
| Set CPU operating state (RUN/STOP) | SetVariable 0x04F2 | 🔒 | — |
| Block upload / download, program changes | BeginSequence 0x0556, EndSequence 0x0560, Invoke 0x056B | ❌ | — |
| Object relations (read) | GetLink 0x0524: object id, relation id → linked object ids | ✅ | s7 info: links |
| Object path resolution | GetVariablesAddress 0x0590: OMS object path (ASRoot.PLCProgram.<name>) → object id |
✅ | s7 info: resolve |
| Add / remove relations | AddLink 0x0506, RemoveLink 0x051A | ❌ | — (change the object model; no TIA Portal tool uses them) |
Prepare the PLC
S7comm on S7-1200/1500
- In TIA Portal, CPU properties → Protection & Security: enable Permit access with PUT/GET communication from remote partner.
- In each DB you read: Attributes → clear Optimized block access. S7comm uses absolute
addresses (
DB1.DBW2). - Rack 0, slot 1 (the defaults for these families).
S7comm on S7-300/400: rack 0, slot 2 (default). LOGO! 8: select LOGO! 8 or LOGO! 8 (TSAP) and set up a server connection in LOGO!Soft Comfort.
S7CommPlus (S7-1200/1500): no PUT/GET, optimized DBs are fine. Use symbols. If the CPU has an access level password, set it in the endpoint. TLS needs S7-1500 FW ≥ 2.9 or S7-1200 FW ≥ 4.5. Some CPUs accept only TLS sessions (PLCSIM Advanced V8 with FW S4.1, or a CPU with "Only allow secure PG/PC and HMI communication"): without TLS the connection fails with "the PLC refused the session without TLS". Turn on TLS in the endpoint.
PLC certificate: without a check, TLS protects only against passive capture (a device between Node-RED and the PLC can show its own certificate). In the endpoint, set "PLC certificate" to:
- pinned fingerprint: the SHA-256 of the PLC certificate (more than one, separated by commas, for a change of certificate);
- trusted certificate or project CA: the PLC certificate in PEM, exported from TIA Portal, or the CA of the project. The certificate must be valid now and contain the host (the S7-1500 puts its IP addresses in it); set "Certificate name" when Node-RED uses another address.
Read from the PLC in the endpoint editor (or s7 info action certificate) shows the
certificate of the deployed endpoint: compare it with TIA Portal before you trust it. When the
check fails, the endpoint stays disconnected and the error shows the fingerprint it got; Read
from the PLC then shows the refused certificate with a warning (refused: true), so a new PLC
certificate can be checked and taken over.
S7 partner (BSEND/BRCV, USEND/URCV): the PLC program sends and receives data blocks with
BSEND / BRCV, and up to four areas without acknowledgement with USEND / URCV, over an S7
connection; Node-RED is the partner. In TIA Portal, add an S7 connection to an
unspecified partner (Devices & networks → Connections), with the active connection establishment on
the partner side, clear "SIMATIC-ACC" to get numeric TSAPs, and set the partner address to the
address the PLC sees for Node-RED. Load the hardware configuration (the connection is part of it).
In the endpoint select "S7 partner" and enter the TSAPs of the connection: local = the partner
TSAP (for example 03.00), remote = the PLC TSAP (for example 10.01). The instructions use the
connection ID of TIA Portal and an R_ID that both sides agree on. A URCV of an S7-1500 takes the
data of s7 usend only when each area has the exact length of its RD_i (for example 100 bytes
for an Array[0..99] of Byte); USEND has no acknowledgement, so check NDR in the PLC.
Addresses
One address per line in the node, or in msg.tags / msg.topic.
Siemens syntax (S7comm and S7CommPlus)
DB1.DBX0.3 DB1.DBB0 DB1.DBW2 DB1.DBD4 also DB1.X0.3, DB1.B0, DB1.W2, DB1.D4
M0.0 MB0 MW0 MD0 I0.0 IB0 IW0 ID0 (E = I) Q0.0 QB0 QW0 QD0 (A = Q)
PIB0 PIW0 PQW0 (peripheral) T0 C0 (Z = C)
V10.3 VB10 VW20 VD30 LOGO! 8 / S7-200 V memory (= DB1)
Optional suffixes: [n] for an array of n elements, and :type:
| Group | Types |
| Bit and integer | bool, byte, char, word, int, dword, dint, lword, lint, bcd, lbcd |
| Real | real, lreal |
| Text | string[N], wstring[N], wchar |
| Date and time | dt, dtz, dtl, dtlz, date, tod, time, ltime, ltod, ldt |
Examples: DB1.DBW2:int, MD12:real, MW120[4], DB1.DBB10:string[20], DB2.DBB0:dtl.
Without a type, the size gives one: X bool, B byte, W word, D dword.
nodes7 syntax (S7comm and S7CommPlus): DB1,REAL4, DB5,X0.1, DB2,S7.10, MI14, MR38,
DB1,INT0.5 (5 INTs). Types with an R prefix (RWORD, RDI) are little-endian.
Symbols (S7CommPlus only): "DB_Data".speed, "DB_Data".values[2], "DB_Data".mat[1,2],
"DB_Data".st.x, PLC tag names (Motor_On), or any name with the sym: prefix. Use
s7 info → browse to list all symbols. Symbols and absolute addresses mix in one request.
Values
| PLC type | JavaScript |
| BOOL | boolean |
| integers up to 32 bit, REAL, LREAL | number |
| LINT, LWORD | number, or string outside ±2^53 |
| STRING, WSTRING, CHAR | string |
DT, DTL, DATE, LDT and the z (UTC) variants |
ISO 8601 string |
| TIME, LTIME, TOD (S7comm) | number: TIME in ms, LTIME in ns, TOD in ms of the day |
arrays ([n]) |
array |
For writes, the node also accepts Date, BigInt, Buffer (for byte arrays) and numeric strings.
Examples
Import them in the editor: Menu → Import → Examples → node-red-contrib-s7-rust.
| Example | Shows |
| 01 - Read and write (S7comm) | cyclic read to an object, single and multi-tag writes |
| 02 - Watch with conditional rate | change-only watch, faster while a tag is true |
| 03 - S7CommPlus symbolic access | symbols and absolute addresses in one read, browse |
| 04 - PLC diagnostics | status, cpuState, identify |
All examples use the address 192.168.0.1. Change it in the endpoint.
Safety
- The nodes cannot stop or start the CPU and cannot upload blocks. The Rust crates have these functions, but the addon does not expose them.
setClockandsyncClockchange the PLC clock. The admin API refuses them.s7 alarmsacknowledges alarms when a message withmsg.ackarrives (a write to the PLC), never by itself.s7 infoactionacknowledgedoes the same; the admin API refuses it.s7 bsendands7 usendsend data to aBRCV/URCVof the PLC program (the program decides what to do with it).s7 writewrites to the PLC at once. Test on a simulator (for example PLCSIM Advanced) before you write to a machine.
Performance
The protocol work (frame building, request optimization, value decoding, change detection) is in Rust. Node-RED gets ready-made JavaScript values, and a watch sends nothing when nothing changed. Reads of tags that are near each other go in one request ("gap" setting).
Measured in-process against the fake CPU of the test suite (p50, Linux x64):
| Operation | 1 tag | 1 000 tags | 10 000 tags | 100 000 tags |
| read | 0.12 ms | 0.70 ms | 5.8 ms | 64 ms |
On a real network the PLC response time is the limit (for example ~2 ms per S7comm read on an S7-1200 on the same LAN).
Limits
- The addon runs in the Node-RED process. A fatal error in native code stops Node-RED. The code is safe Rust; the Node-API layer is the only FFI.
s7 watch, mode "PLC subscription": the cycle time is the interval (100 ms or more; S7-1500 FW V4.x sends no changes without a cycle time). Each subscription uses one of the PLC subscription resources (s7 info→limits); when the PLC refuses it, the node reads cyclically.- S7CommPlus: the PLC certificate is not verified by default (TLS then protects against passive capture only); set "PLC certificate" in the endpoint. No revocation check (CRL / OCSP).
The two packages can be installed together: the node types are different.
| @oriolrius/node-red-contrib-s7 | This package |
s7 endpoint |
s7 endpoint (type s7rs-endpoint) |
s7 in, mode "Single variable" |
s7 watch with one tag, or s7 read |
s7 in, mode "All variables, one per message" |
s7 watch, output "one message per tag" |
s7 in, mode "All variables" |
s7 watch, output "one message with all tags" |
| "Emit only when value changes (diff)" | s7 watch, "send only values that changed" (on by default) |
s7 out |
s7 write |
s7 control |
no direct equivalent: the watch interval is set in the node, the tags in the node or in msg.tags of s7 read |
variable table (name → address) |
addresses directly in the nodes; use msg.topic / object keys as names |
Addresses in nodes7 syntax (DB1,REAL4) work without change.
Build from source
You need Rust (stable), Node.js ≥ 18 and, for the release binaries, cargo-zigbuild
(pip install cargo-zigbuild, or uv; the script uses uvx when it is not on PATH).
npm install # dev dependencies (Node-RED and the test helper)
npm run build # addon for this host -> bin/linux-x64-<gnu|musl>/s7napi.node
npm test # Rust unit tests + Node-RED tests against fake PLCs
npm run build:release # both published binaries (glibc 2.28 and musl)
npm run lint # rustfmt + clippy
npm run validate # node-red-dev scorecard checks
Repository layout:
crates/s7 S7comm client (Rust)
crates/s7plus S7CommPlus client (Rust)
crates/s7napi Node-API addon
lib/ JavaScript bridge to the addon, shared helpers
nodes/ Node-RED nodes (.js runtime, .html editor), locales/ (labels, help), icons/
examples/ example flows for the Node-RED import menu
test/ Node-RED tests (node-red-node-test-helper)
scripts/ build and packaging checks
docs/ release process
S7RS_NAPI=/path/to/s7napi.node makes the nodes load another addon build.
GNU Lesser General Public License v3.0 only (LGPL-3.0-only). The LGPL adds
permissions to the GNU GPL v3.0. See NOTICE.
You can use the package in closed-source flows and applications. If you distribute a changed version of the Rust crates or of the addon, you must publish the source code of the changes under the same license.
Siemens, SIMATIC, S7-1200, S7-1500, LOGO! and TIA Portal are trademarks of Siemens AG. This project is not affiliated with or endorsed by Siemens AG.
