node-red-contrib-s7-dynamic 0.4.2
Nó para comunicação com PLC S7 configurável dinamicamente
npm install node-red-contrib-s7-dynamic
S7 Dynamic Node for Node-RED
This is a dynamic Node-RED node designed for communication with Siemens S7 PLCs using the node-snap7 library. It allows you to read and write data from various addresses (inputs, outputs, memory), dynamically handle connection parameters (IP, rack, slot), and more.
  • Dynamic Connection: Supports dynamic connection to Siemens S7 PLCs by specifying IP, rack, and slot.
  • Input Reading: Reads inputs based on specified addresses.
  • Memory Read/Write: Reads and writes to memory addresses in the PLC.
  • Output Writing: Supports writing to outputs by dynamically setting boolean values (true/false or 1/0).
  • Custom Address Parsing: Handles custom address formats such as M0.1 for memory addresses.
Requirements
  • Node-RED environment.
  • Node.js (>= 12.x recommended).
  • Siemens S7 PLC or compatible device.
  • node-snap7 library.
To use this node, you must install the Node-RED contribution from the Node-RED palette or manually add it to your package.json:
``bash npm install node-red-contrib-s7-dynamic.
Example for Reading Inputs
  "payload": {
    "type": "input",
    "ip": "192.168.0.1",
    "rack": 0,
    "slot": 1,
    "addresses": [I1, I2, I3]
Example for Writing Outputs
  "payload": {
    "type": "output",
    "rack": 0,
    "slot": 1,
    "addresses": {
      "Q0": true,
      "Q1": false
Example for Memory Read/Write
  "payload": {
    "type": "memory",
    "rack": 0,
    "slot": 1,
    "addresses": ["M0.1", "M10.0"]
Contributing
Feel free to fork this repository, contribute to the code, and open pull requests with new features or bug fixes.
Authors
Eberson M. - Creator - EbersonM
Acknowledgements
Thanks to the developers of node-snap7 for the core library to interface with Siemens S7 PLCs. Node-RED community for providing the platform for creating powerful IoT applications.
Version: 0.4.2
Updated 1 year, 9 months ago
Rating: 5.0 3
36 in the last week
  • s7-dynamic
  • siemens
  • s7
  • plc
  • automacao
