node-red-contrib-rxdb 1.0.4
A Node-RED custom node package for integrating RxDB with MongoDB
npm install node-red-contrib-rxdb
A custom Node-RED node set for building low-code, reactive database flows using RxDB backed by MongoDB.
Overview
This package includes Node-RED nodes that:
  • Dynamically manage RxDB collections and schemas at runtime
  • Support reading, writing, watching, and replicating changes
  • Use MongoDB as a durable, developer-friendly backend
  • Allow full flow-based control -- no static schemas required!
Included Nodes
Node Purpose
rxdb-read Query documents from one or more collections
rxdb-write Insert documents into a collection
rxdb-watch Stream real-time changes from a collection
rxdb-add-collections Dynamically add collections + enable replication
Prerequisites
To use this project with MongoDB:
1. Install MongoDB via Docker
If Docker is not already installed, follow instructions from https://docs.docker.com/get-docker/
Then pull and run a MongoDB container:
docker pull mongo
docker run --name mongodb -d -p 27017:27017 -v /var/lib/mongodb:/data/db --restart always mongo
2. Create an Admin User
Enter the Mongo shell:
docker exec -it mongodb mongosh
Then set up authentication:
use admin
db.createUser({
  user: "your_username",
  pwd: "your_password",
  roles: [{ role: "root", db: "admin" }]
exit
3. Restart with Auth Enabled
docker stop mongodb
docker rm mongodb
docker run --name mongodb -d -p 27017:27017 -v /var/lib/mongodb:/data/db --restart always mongo mongod --auth
From local directory:
npm install /path/to/node-red-contrib-rxdb
Then restart Node-RED:
node-red-restart
Node Usage
rxdb-read
Reads one or more collections:
  "rxdb": {
    "collections": ["tickets"],
    "limit": 10
rxdb-write
Writes a document to a collection:
  "rxdb": { "collection": "tickets" },
  "payload": {
    "id": "t-001",
    "subject": "Test ticket"
rxdb-watch
Watches a collection for live updates:
Output:
  "payload": {
    "event": "INSERT",
    "doc": { ... }
Dynamically register collections:
  "calendarEvents": {
    "schema": { ... },
    "replicate": true,
    "replicationUrl": "https://myhost/tickets/0"
  • MongoDB support via RxDB adapters
  • Dynamic schema injection at runtime
  • Replication support (RxDB replication-server plugin)
  • Smart instance caching (one shared RxDB connection)
  • No external DB config nodes -- flow-driven logic only
UNLICENSED
No warranties. No attribution required. No restrictions.
Version: 1.0.4
Updated 10 months ago
License: Unlicense
198 in the last week
  • rxdb-read
  • rxdb-write
  • rxdb-watch
  • rxdb-add-collections
  • rxdb-delete
  • rxdb
  • foundationdb
  • database
  • custom-node
