node-red-contrib-rtlamr 0.0.10
A node for reading from rtlamr.
npm install node-red-contrib-rtlamr
A node red node for listening to rtlamr.
The node allows you to specify the rtl_tcp server and port used by rtlamr. You can use either a hostname or IP address and port (Ex. 192.168.1.5:1234 or myrtltcpserver:1234). If a server is not specified it defaults to 127.0.0.1:1234
Example Node Config
Example Flow
[{"id":"bf73a772.b69008","type":"tab","label":"Flow 3","disabled":false,"info":""},{"id":"838aebc4.f584f8","type":"rtl-amr","z":"bf73a772.b69008","name":"Meter Reader","device":"","x":110,"y":40,"wires":[["80a73d0a.8d815"]]},{"id":"80a73d0a.8d815","type":"debug","z":"bf73a772.b69008","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":270,"y":40,"wires":[]}]
Version: 0.0.10
Updated 6 years, 1 month ago
15 in the last week
  • rtl-amr
  • sdr
  • rtlamr
