node-red-contrib-rsync 1.1.1
Node Red wrapper for rsync
npm install node-red-contrib-rsync
rsync for Node-Red
This node is a wrapper around the rsyncwrapper module, which is a wrapper around rsync.
It requires that rsync is already installed. If using the Docker image for Node-Red, you can create your own image with rsync installed using the following dockerfile:
FROM nodered/node-red-docker
USER root
RUN apt-get update && apt-get -y install rsync
CMD ["npm", "start", "--", "--userDir", "/data"]
You can then create the image using the following command:
sudo docker build -t node-red-rsync .
And then replace the reference to the standard Node-Red image "nodered/node-red-docker" with your newly created one "node-red-rsync".
Version: 1.1.1
Updated 7 years, 8 months ago
49 in the last week
  • rsync
  • rsync
