node-red-contrib-rpo-suite 1.3.2
Complete GLT building automation node suite for Node-RED by sr.rpo
npm install node-red-contrib-rpo-suite
One-line install for the complete sr.rpo GLT building automation node suite for Node-RED.
Or via Node-RED Palette Manager: Search for rpo-suite
Included Nodes
Node Package Description
age-calculator node-red-contrib-age-calculator Calculate age/duration since a timestamp
hysteresis node-red-contrib-threshold-hysteresis Threshold switching with hysteresis band
sr-latch node-red-contrib-sr-latch Set-Reset latch with configurable priority
pulse-edge node-red-contrib-pulse-edge Edge detection and pulse generation
ton-toff node-red-contrib-ton-toff On-delay and off-delay timers
deadband node-red-contrib-deadband Filter small value changes
multi-stat node-red-contrib-multi-stat Statistics over multiple inputs (min/max/avg/sum)
scale node-red-contrib-scale Linear value scaling between ranges
clamp node-red-contrib-clamp Limit values to min/max range
average node-red-contrib-avg Moving average over count or time window
difference node-red-contrib-difference Calculate difference between two values
logic-combiner node-red-contrib-logic-combiner Combine multiple topics with AND/OR/XOR logic
heat-curve node-red-contrib-heat-curve Heating curve calculation for HVAC systems
pid-controller node-red-contrib-pid-controller-isa Industrial-grade ISA PID with Feed-Forward & Cascade Tracking
Use Cases
  • HVAC control systems
  • Building automation (GLT)
  • Industrial process control
  • Sensor data processing
  • PLC-style logic in Node-RED
Author
sr.rpo
MIT
Version: 1.3.2
Updated 7 months, 3 weeks ago
305 in the last week
  • glt
  • building-automation
  • hvac
  • ddc
  • sr.rpo
