node-red-contrib-rpiplc-node 2.0.1
A collection of Node-RED nodes for using analog inputs, analog outputs, digital inputs and digital outputs from Raspberry PLC of Industrial Shields®.
npm install node-red-contrib-rpiplc-node
To install the stable version use the Menu - Manage palette - Install option and search for node-red-contrib-rpiplc-node, or run the following command in your Node-RED user directory, typically ~/.node-red
npm i node-red-contrib-rpiplc-node
Provides four nodes:
  1. Analog Read: Gets the value of an analog input.
  2. Analog Write: Sets a value of an analog output.
  3. Digital read: Gets the value of a digital input.
  4. Digital write: Sets a value of a digital output.
1. Analog Read
Reads the value from the specified analog pin. The Raspberry PLC model and input pin must be selected.
analog-read
2. Analog Write
Writes an analog value (PWM wave) to a pin. The Raspberry PLC model, input pin and a value between 0 and 4095 must be set.
analog-write
3. Digital Read
Reads the value from a specified digital pin, either HIGH or LOW. The Raspberry PLC model and input pin must be selected.
digital-read
4. Digital Write
Writes a HIGH or a LOW value to a digital pin. The Raspberry PLC model, input pin and value must be set.
digital-write
Version: 2.0.1
Updated 4 years, 7 months ago
License: LGPL
6 in the last week
  • rpiplc-config
  • rpiplc-analog-read
  • rpiplc-analog-write
  • rpiplc-digital-read
  • rpiplc-digital-write
  • node-red-contrib-rpiplc-node
  • industrial
  • Industrial Shields
  • raspberry
  • Raspberry PI
