node-red-contrib-rpi-imagecapture 0.0.2
This node allows to take picture from standard USB webcam connected to a Raspberry.
npm install node-red-contrib-rpi-imagecapture
It uses the fswebcam package.
Prerequisites
Install the fswebcam package on the Raspberry
From your node-red directory:
or
in the Node-red, Manage palette, Install node-red-contrib-rpi-imagecapture
The fswebcam configuration needs to be defined into a file stored in the Raspberry.
The available options can be found using the fswebcam -help command.
For example :
device /dev/video0
resolution 640X480
set brightness=70%
set contrast=70%
no-banner
jpeg 95
skip 10
set "Focus, Auto"=False
set "Focus (absolute)"=7
rotate 180
The path to the configuration file needs to be defined into the node properties.
Input
The picture is captured when a msg arrived into the node.
Output
The captured picture is stored in a Buffer object in msg.payload.capturedImg.
MIT License
Version: 0.0.2
Updated 9 years, 7 months ago
11 in the last week
  • imagecapture
  • image capture
  • raspberry
  • usb webcam
