node-red-contrib-rollun-common 1.0.16
## Nodes List of nodes: - Foreach node (foreach-start, foreach-end, foreach-break) - Array map node (array-map-end, array-map-end-sync, array-map-break, array-map-start, array-map-start-sync) - Deep merge node (deep-merge) - Elastic logger node (elastic-l
npm install node-red-contrib-rollun-common
Common utils for rollun node-red
List of nodes:
  • Foreach node (foreach-start, foreach-end, foreach-break)
  • Array map node (array-map-end, array-map-end-sync, array-map-break, array-map-start, array-map-start-sync)
  • Deep merge node (deep-merge)
  • Elastic logger node (elastic-logger)
To install the stable version use the Menu - Manage palette - Install option and search for node-red-contrib-rollun-common, or run the following command in your Node-RED user directory, typically ~/.node-red
Version: 1.0.16
Updated 3 years, 7 months ago
8 in the last week
  • array-map-start
  • array-map-start-sync
  • array-map-end
  • array-map-end-sync
  • array-map-break
  • array-map-start
  • array-map-end
  • array-map-break
  • array-map-start
  • array-map-end
  • array-map-break
  • array-map-start
  • array-map-end
  • array-map-break
  • array-map-start
  • array-map-end
  • array-map-break
  • deep-merge
  • elastic-logger
  • elastic-logger-config
  • foreach-start
  • foreach-end
  • foreach-break
  • foreach-start
  • foreach-end
  • foreach-break
  • foreach-start
  • foreach-end
  • foreach-break
