node-red-contrib-revolution-pi-dio 0.0.4
Revolution Pi DI/DO/DIO access module for use in Node-Red
npm install node-red-contrib-revolution-pi-dio
This is a node.js module to use with node-red. It adds read/write nodes to acces bits of the Revolution Pi DIO Module.
It uses the getBit/setBit function of the piTest c-application.
Access via the ffi-module.
A shortended version of the piTest.c is compiled into a shared Library.
Please note, that there is no out of bounds check on the offset value... segmentation faults can be caused easily.
Idea for using ffi comes from this project: https://github.com/tmuellerWieland/revpi
Source Files for the piTest tool that are compiled into the libPiTest.so : https://github.com/RevolutionPi/piControl
Version: 0.0.4
Updated 9 years, 3 months ago
9 in the last week
  • revpi-read
  • revpi-write
  • revolution
  • pi
