node-red-contrib-renault-ze 1.6.0
Node Red nodes for Renault ZE services
npm install node-red-contrib-renault-ze
CLA assistant compile CodeFactor npm version
Renault ZE Services node
Provides functionality to retrieve data from the Renault ZE Services API. Thanks to Muscat's OxBlog for the documentation of the new API. Designed to be installed into Node Red.
Supported Cars:
  • Renault Zoe
  • Dacia Spring
When triggered, the node will login and retrieve the status of the vehicles. It will output multiple messages for battery, cockpit,... payload see the following example:
    "data": {
        "type": "Car",
        "id": "VF1XX000000000000",
        "attributes": {
            "timestamp": "2020-11-15T14:02:00Z",
            "batteryLevel": 86,
            "batteryTemperature": 20,
            "batteryAutonomy": 310,
            "batteryCapacity": 0,
            "batteryAvailableEnergy": 44,
            "plugStatus": 0,
            "chargingStatus": 0,
            "chargingRemainingTime": 30,
            "chargingInstantaneousPower": 11.9
Install via the palette manage in the Node-RED admin ui (no restart needed).
Alternatively run the following command in your Node-RED user directory (typically ~/.node-red):
then restart Node-RED and add an instance of the renault-ze node.
Just send a messages to the node and you will receive a lot of status messages. For details read the following here.
You can simple start with the following flow to fetch some data from your cars:
simple Flow
        "id": "8d884832.0b75d8",
        "type": "renault-ze",
        "z": "35cd1e62.3f2ff2",
        "x": 480,
        "y": 300,
                "22f4a942.cea996"
        "id": "b923017a.ce46",
        "type": "inject",
        "name": "no topic -> charge / cockpit & location",
        "props": [],
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "x": 190,
        "y": 220,
                "8d884832.0b75d8"
        "id": "22f4a942.cea996",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "targetType": "full",
        "statusVal": "",
        "statusType": "auto",
        "x": 630,
        "y": 300,
        "id": "ba475199.d46a9",
        "type": "inject",
        "props": [
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "charge-mode",
        "x": 270,
        "y": 280,
                "8d884832.0b75d8"
        "id": "9282bcf2.18602",
        "type": "inject",
        "props": [
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "hvac-schedule",
        "x": 260,
        "y": 340,
                "8d884832.0b75d8"
        "id": "931c1bd0.7fa698",
        "type": "inject",
        "props": [
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "charge-schedule",
        "x": 260,
        "y": 400,
                "8d884832.0b75d8"
Version: 1.6.0
Updated 5 months, 3 weeks ago
Rating: 5.0 8
51 in the last week
  • renault-ze
  • renault
  • ze
  • watchforstock
