node-red-contrib-remware-ina3221-sensor 0.1.1
node-red wrapper for the ina3221
npm install node-red-contrib-remware-ina3221-sensor
INA3221 Node-RED Component
This Node-RED custom node reads data from the INA3221 triple-channel voltage and current monitor. It provides six outputs, delivering millivolts and milliamps for each of the three channels.
  • Six Outputs:
    • Output 1: Voltage (millivolts) for Channel 1
    • Output 2: Current (milliamps) for Channel 1
    • Output 3: Voltage (millivolts) for Channel 2
    • Output 4: Current (milliamps) for Channel 2
    • Output 5: Voltage (millivolts) for Channel 3
    • Output 6: Current (milliamps) for Channel 3
  • Configurable I2C address and bus number.
  • Adjustable update interval for reading sensor data.
  1. Clone the Repository or Download Files: Place the files in your local Node-RED custom nodes directory: ~/.node-red/nodes/ina3221
  2. Folder Structure: Ensure the following files are in the directory: ina3221/ ├── ina3221.js // Node logic ├── ina3221.html // Node editor and help ├── hardware.png // Optional: Node icon
  3. Add to a Flow: Drag and drop the INA3221 node into your flow and configure its properties.
Node Properties
Property Description Default Value
Name Optional name for the node. (empty)
I2C Address I2C address of the INA3221 sensor. 0x40
I2C Bus I2C bus number (e.g., 1 for Raspberry Pi). 1
Update Interval Time (in milliseconds) between sensor readings. 1000
Outputs
Output # Description
1 Voltage (millivolts) - Ch1
2 Current (milliamps) - Ch1
3 Voltage (millivolts) - Ch2
4 Current (milliamps) - Ch2
5 Voltage (millivolts) - Ch3
6 Current (milliamps) - Ch3
Example Usage
  1. Add the Node: Drag the INA3221 node into your flow.
  2. Configure the Properties: Set the I2C address, bus number, and update interval in the node editor.
  3. Connect Outputs: Connect the outputs to other nodes (e.g., debug nodes or data storage).
Dependencies
  • Hardware: INA3221 sensor connected to the I2C bus.
  • Node.js Modules:
  • i2c-bus: Install using:
npm install i2c-bus
Troubleshooting
  • Ensure the INA3221 sensor is properly connected to the I2C bus.
  • Check that the I2C address matches the hardware configuration.
  • Use i2cdetect to verify the sensor is detected:
sudo i2cdetect -y 1
This Node-RED component is released under the MIT License.
Contributing
Contributions are welcome! Feel free to submit issues or pull requests.
Acknowledgments
This component uses the i2c-bus library for I2C communication and is based on the INA3221 triple-channel voltage/current monitor.
Version: 0.1.1
Updated 2 years, 2 months ago
  • ina3221
  • ina3221
  • raspi
  • current
  • sensor
  • voltage
