node-red-contrib-remote 3.1.0
Remote-RED is an ecosystem to bring remote access, push notification and geofencing to Node-RED. There are also additional functions like directly answer on a notification and homescreen widgets.
npm install node-red-contrib-remote
Remote-RED
Remote-RED is an ecosystem to bring remote access, push notification and geofencing to Node-RED. There are also additional functions like directly answer on a notification and homescreen widgets. It consists of several parts:
  • node-red-contrib-remote: The Node-RED nodes of Remote-RED. Published in this repro.
  • Remote-RED servers: Several servers used for proxying the remote access traffic and sending push notifications.
  • Remote-RED apps: Apps to access the services published by the Remote-RED remote-access node and receiving the push notifications of the remote-notification node. Available or Android, iOS and iPadOS.
  • Remote-RED Linux agent: Alternativ to the Node-RED nodes, binging Remote-RED functions to all Linux based systems.
Installation of Node-RED nodes
You can install the Remote-RED nodes through the Node-RED library. Search for 'node-red-contrib-remote'.
Remote-RED Apps
You can install them from the Google PlayStore or Apple AppStore:
Remote-RED App for Android
Remote-RED App for iOS
Tutorial for Remote-RED
There is a help page describing how the the nodes work together and how to connect the apps.
Help in English
Hilfe in Deutsch
Remote-RED Partner Programm
If you want to scale up, have a look at the Remote-RED Partner Programm. It is made for everyone who does not only use Node-RED for themselves, but builds solutions for others:
  • developers of own IoT projects (Node-RED and also pure Linux projects)
  • installers of smart home and control systems
  • manufacturers and platforms looking for a white label solution
As a partner you offer your customers encrypted access to their dashboards, push notifications and geofencing triggers - without developing your own app and without running your own server infrastructure.
Contact
You will find more information on www.remote-red-com. You can contact me by mail through [email protected].
Version History
Version 3.1.0
  • Direct connection (WebRTC) between app and Node-RED, without port forwarding. Falls back to the Remote-RED server automatically. Can be turned off in the config node.
  • Notifications and Questions with high priority possible.
  • Connection test inside the config node.
Version 3.0.0
  • Support for the Remote-RED Partner Programm
Version 2.0.5
  • Improved reconnect for Starlink users
Version 2.0.4
  • Fix for 'No endpoint detected' message
Version 2.0.3
  • More stable handling of connection losses
Version 2.0.2
  • Crash on Node-RED startup fixed, extended error reporting
Version 2.0.1
  • Possible bug on network connection fixed
Version 2.0.0
  • Enormously faster access to your Node-RED via the Internet
  • macOS app for Apple Silicon (M-Chips)#
  • Status display whether the instances are connected
  • Changes to the configuration are applied without reconnecting the app
  • Connection loss after switching from Wifi to mobile fixed
  • Notifications with full UTF-8 support
  • New instances automatically recognize http/https and the use of Dashboard 2
  • Android: Local network is used again if possible
  • Android: Delete an instance by long press and pull to refresh
  • Reconnecting the instance to my server improved
  • Multiple use of a config node in several access nodes is now recognized
Version 1.6.1
  • Adding instances on Android is be possible again.
Version 1.6.0
  • Compatibility to 'node-red-contrib-remote-cli' version 1.1.0.
Version 1.5.3
  • Improved error logging while the instance registration process.
Version 1.5.2
  • Compatibility to 'node-red-contrib-remote-cli'.
Version 1.5.1
  • Added support for running Node-RED with a self signed https certificate.
  • Notifications and Questions will automatically convert values to string if a string is needed (e.g. title and body).
Version 1.5.0
  • Geofencing! You can add geofences in the apps. Entering and leaving them will trigger a message on the new output of the remote access node.
  • Adding server location in Asia.
  • New instances will have the base url '/ui' again.
  • Error with "Multiple requests" after a missing internet connection fixed.
  • iOS App: Links with target '_blank' will be redirected to iOS.
Version 1.4.0
  • In addition to the QR code, a link is now generated to add an instance in the app.
  • Sending notifications and questions is prevented if msg.playload.send === false.
  • Error catched if a notification or question does not contain a title and body.
Version 1.3.3:
  • Improved compatibility for Windows.
Version 1.3.2:
  • Changed the method to get the installed node version. Thanks hardillb!
Version 1.3.1:
  • Added timeout handling to the heartbeat function.
  • Catches errors when evaluating the title, body or sound of an notification.
Version 1.3.0:
  • A heartbeat function is added to the remote access node. This will automatically reconnect if the connection is interrupted, e.g. due to an unstable internet connection.
Version 1.2.3:
  • The settings base url and port are filled automatically for new config nodes. This is helpful when using alternative installations such as RedMatic.
  • Notifications and Questions can have a computed sound. So you can include the sound based on the incoming message.
  • Notifications and Questions without an body or an title will not be send to the Remote-RED servers.
  • Logs an error message if a notification or question exceeds the size of 3600 bytes.
Version 1.2.2:
  • Better Windows support: Using remote access with 'localhost' will not work on Windows 10 hosts. Now it uses '127.0.0.1' instead.
Version 1.2.1:
  • Fixed a bug that texts was not shown (especially in the notification node).
Version 1.2.0:
  • In iOS you can now use Shortcuts and in Android you can new use a widget to perform actions in Node-RED. This action will be emitted through the new output of the remote access node.
Version 1.1.3:
  • The question node works now well after a new deploy. Before sometimes a Node-RED restart was required.
  • The access node now reduces the ssh connection attempts if it fails to connect for a longer time.
  • The notification and question node has a limit now. It limits the push notifications to 100 per hour and node.
Version 1.1.2:
  • The question node now supports custom httpRoot paths, as it is used e.g. in RedMatic.
Version 1.1.1:
  • Dependency update axios
Version 1.1.0:
  • Added question node to send questions through push notifications. They can be answered directly on the notification level.
  • You can select sounds for the push notifications.
  • Important: Please update your mobile apps to Version 1.1.0 too.
Version 1.0.3:
  • Added the function to activate verbose logging of the SSH tunnel.
Version 1.0.2:
  • Added a button to create a support mail in the config node.
Version 1.0.1:
  • Initial release
Version: 3.1.0
Updated 4 days ago
License: GPL-3.0
Rating: 4.0 9
193 in the last week
  • remote-config
  • remote-access
  • remote-notification
  • remote-question
